Gen5DIY
Camaro DIY & HOW-TO instructions & discussions All DIY projects & discussions
Old 05-22-2011, 02:41 PM   #126
2SSRS
On a list for a 2014 Z28
2SSRS's Avatar
Drives: 2010 Camaro 2SS M6
If you remove the connecter on the the mirror and see if you have power to pin 9 of the 16 pins, its the pin at the bottom left if your looking at it and its has the tab's up.
2SSRS is offline   Reply With Quote
Old 05-22-2011, 02:46 PM   #127
jtzako
Drives: 2010 IBM Camaro SS
I was testing for power at the red wire where it spices from the long harness to the mirror harness. Is that not the right place to check?
Also, when I use my meter it seems to be working oddly. If I touch the powered wire and a metal part of the car nothing happens, but if I touch the powered wire + negative side of battery it dows the voltage. This seems unusual to me.
Can you confirm that on the long harness the Pink and Dark Blue wires are the right ones? I tried both, 1 at a time and neither worked so I'm not sure if they are the right ones. Or should I be powering the red wire directly?
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 05-22-2011, 02:53 PM   #128
STINGS
Live for On Ramps!
STINGS's Avatar
Drives: 2010 Camaro/2LT/RS/T.F./6M "naomi"
You can also use small push pins, available at most hardware stores to mount the camera. (5/32 hole size)
Joe
Cut opening with utility knife. Note: Better if you push the tip of the utility knife into the bumper, rocking the blade back and forth untill you get through the material. Once you are through the bumper, it works better if you use more of a sawing/rocking motion to finish the cut. Using the scoring method, if it slips you will drag the blade across the bumper outside of the cutting area.
STINGS is offline   Reply With Quote
Old 05-22-2011, 02:54 PM   #129
BrandonB956
BrandonB956's Avatar
Drives: RS (11/15/10)
Nice
TEAM LLT
Nov.15th 2010 -- Check out my build thread
http://www.camaro5.com/forums/showthread.php?t=116235
BrandonB956 is offline   Reply With Quote
Old 05-23-2011, 02:50 PM   #130
jtzako
I got mine wired up yesterday and finished it today. I cut a square hole so I could put the camera in from the inside. I used some trim fasteners to push through the 4 holes in the camera assembly then sealed it all with clear silicon adhesive.
Tips for installing this on a 1SS using the OEM style harness/camera:
1) There are no existing wires in the A-pillar to tie wires to, so get some stick-on zip tie fasteners to make it easier and keep things away from the airbag.
2) You have to tap the reverse light power since 1SS models do not have power in the mirror harness already. The reverse light wire is the light green wire found in the large connector in the driver side tail light assembly. You then connect that wire/tap to the Dark Blue or Pink wire in the harness that connects to the camera.
Old 05-23-2011, 07:36 PM   #131
STINGS
Live for On Ramps!
STINGS's Avatar
Vehicles with the sunroof have a harness down the drivers side A pillar. Passenger side A pillar has the overhead console harness running down it. So if you have a sunroof you can run it down either side and have something to tie it to!
(Someone who has the sunroof can verify this)
Joe
Old 05-24-2011, 06:33 PM   #132
jimmyh
jimmyh's Avatar
Drives: 2011 1LT => 2010 2SS
"Bolivia's Auto Sales" FTW
jimmyh is offline   Reply With Quote
Old 05-24-2011, 10:36 PM   #133
Gene Culley
Gene Culley's Avatar
Drives: 2010 Inferno Orange Metallic 2SS/RS
Smile
Joe
I really like the photos you've provided and the clean job you have done. Can you tell me approximately the size of hole you used? I have a GM camera as well, from Ofer, and I am about to do it this weekend.
Founder Of GM Parts House
Home Of The Camaro Parts And GM Parts Specialist
Please Visit GM Parts House Online or Call 484.949.2099.
Gene Culley is offline   Reply With Quote
Old 05-25-2011, 03:41 AM   #134
bigwayne3000
Drives: 2011 Camaro LS
Does the GM camera have the green, yellow, red lines on it or no? Also Gene, if I were to buy this down the road would you be willing to give me a hand if I drive out there? Ill supply the beer!
bigwayne3000 is offline   Reply With Quote
Old 05-25-2011, 08:00 AM   #135
jtzako
Mine doesnt have lines, and it is black and white display also, not sure if that is what all of them are.
Old 05-25-2011, 02:56 PM   #136
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
Mine is color.
Old 05-25-2011, 03:09 PM   #137
GTAHVIT
One Lucky Guy.
GTAHVIT's Avatar
Drives: #22 Tom Henry Racing 2010 2SS/RS
Mine is color with no lines and Night Vision.
Old 05-25-2011, 03:15 PM   #138
jtzako
Do you guys have the "OEM" one or some other? I believe mine is an OEM one.
Old 05-25-2011, 03:28 PM   #139
2SSRS
2SSRS's Avatar
Darth_Emma is a Sony camera and GTAHVIT is the same as yours.
Old 05-25-2011, 03:29 PM   #140
2SSRS
2SSRS's Avatar
The OEM camera do not have the lines.
Old 05-25-2011, 03:34 PM   #141
jtzako
Huh, OK. I'll have to check it again. It is temp rigged until the replacement harness comes, but I'm pretty sure it is not in color. (I havent checked for night vision but not sure exactly what that looks like)
Old 05-26-2011, 12:31 PM   #142
jtzako
Finally had a chance to check it last night. It is in color, I just couldnt tell initially because nothing behind me at the time was particularly colorful.
Also, I noticed that as I backed into the garage the image changed as I transitioned from sunlight to garage. That might be the 'night vision' that was mentioned.
Old 05-27-2011, 12:15 AM   #143
The IOM Ninja
Drives: 10' IOM 2SS/RS, 13' GB Shelby GT500
Hey Ofer, you were right, it was that damned diode. I destroyed it and now the rearview camera is all set up.
The IOM Ninja is offline   Reply With Quote
Old 05-27-2011, 07:34 AM   #144
2SSRS
2SSRS's Avatar
Grate to here, Post pics and have a good weekend.
Old 05-28-2011, 09:00 AM   #145
Gene Culley
Smile
Yes, of course. Let me get mine finished up and then I'll be ready to help you out!
Old 05-28-2011, 06:56 PM   #146
The IOM Ninja
I'd like to thank you for keeping up with the stupidity of me on the phone I immediately went and got a soldering gun and put the harness back together the way it was supposed to be hahaha. Anyway here are those photo's!
Thought you might like this photo
I'll hopefully be installing my heritage grill this week, all depends on if it is done getting painted
Also Stings have you noticed the screwy design of our bumpers? It kinda looks stupid how the camera is off centre even though it is completely centred
Old 05-28-2011, 07:03 PM   #147
jtzako
Yeah, it is weird how they did not center the license plate lights under the bumper lip. It isnt too far off, maybe 1 cm, but enough you can tell if you are looking there.
Old 05-28-2011, 07:46 PM   #148
2SSRS
2SSRS's Avatar
Love that pic, both the cars look grate.
Old 05-28-2011, 11:28 PM   #149
Jocoo26
Jocoo26's Avatar
Drives: 2011 Camaro 2SS
I cannot seem to get my mirror screen to turn on. How does the camera know when the car is in reverse?
Jocoo26 is offline   Reply With Quote
Old 05-29-2011, 09:13 AM   #150
Gene Culley
Smile
It is hooked up to a wire that is hot only when the car is in reverse and less than 12MPH. I may be a little off on the MPH.
Rear view camera and LCD mirror install on my vert. SUX2BU Camaro Convertible Forum 62 08-18-2012 06:40 PM
Backup camera install help. meschwenk Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 04-05-2011 08:16 AM
