04-25-2011, 06:53 PM | #1 |
Drives: 2008 Z06 Join Date: Apr 2009
oil leak
check out these pictures. I get a drop every so often in the garage, but oil level is still good. i had my friend tighten the oil cooler bolts, but i still get this small leak. what do you think it can be?
04-25-2011, 07:46 PM | #2 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
There's a TSB for the oil cooler adaptor gasket replacement. Bring it in for warranty repair. I had the same thing!
04-25-2011, 08:08 PM | #3 |
my only problem is....i have a supercharger.....they might deny it
04-25-2011, 08:39 PM | #4 |
Drives: 2SS Join Date: May 2009
they wont if they are cool, mine replaced it with the SC no questions asked.
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
04-26-2011, 08:12 AM | #5 |
is there a TSB?
04-26-2011, 04:32 PM | #6 |
Drives: SuperCharged 2SS/RS IOM MN6 Join Date: May 2009
This is a well known and documented issue. Do a search and you will get all the information you need rather than waiting for folks to trickle in their 10 cents here and there..unless you are just really lazy.
05-10-2011, 12:53 PM | #7 | |
anyways problem solved it was a rear main seal leak and the dealer took care of it today.
Similar Threads | ||||
First oil change? | Fogey | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 27 | 09-18-2010 06:50 AM |
My oil leak wasn't an oil leak.... | yzfmik | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 7 | 05-10-2010 01:17 PM |
synthetic motor oil? | bigd1276 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 71 | 01-29-2009 12:28 PM |
Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 09:47 AM |
