sjm autoprod
Old 04-26-2011, 02:11 PM   #1
simon.w
Drives: 2011 2SS RS 6M Inferno Orange
My $32 home made catch can ... not simply a tin with fittings
Before you say "here we go ... another home made tin with pipe fittings and no baffles" ... check this out.
I pulled the throttle body off my Whipple to paint it on the weekend and found oil ... so time to fit a catch can.
I googled as much as I could and came to the conclusion that anything under $100-$150 was simply going to be a container with fittings.
I rang around all the local auto shops ... useless ... had no idea what I was talking about. No surprises there!
So seeings I wanted to fit one straight away, I decided to make a decent one myself.
So a trip to lowes and $32 later I came home with my shopping list.
2 1/2" PVC fittings: 2 x end caps, 2 x drain grates, 1 x joiner, 2 short lengths of pipe (approx 1" long each)
1 x chemical resistant scotch gray automotive scourer
2 x barbed & threaded chemical resistant nylon right angle hose fittings
Short length of fuel or vacuum line
1 x brass micro tap
short length of aluminum flat to make bracket + 2 small bolts with nuts
PVC joining compound
Thread seal compound
Oil resistant silicon sealant.
The following diagram should be explanatory ... make sure you use thread compound on the hose fittings and tap, PVC joint compound on the pipe and end caps, and silicon in and around the bracket bolts and also to join the fuel line onto the bottom of the inlet fitting.
Once everything has cured, sand, prime, paint, clear coat.
This took me a total of 3 hrs inducing fitting. I should point out that I EXTREMELY fussy ... and would never fit this to my car if it looked even remotely home made. I even took the time to file and sand the writing off the top of the end cap so it doesn't look like a PVC fitting.
I know the purists (and those selling the good units) will have something negative to say ... but I love doing things myself ... and I am really happy with result.
I should add that I am realistic and know that I'll need to blow it out with compressed air when I drain it to ensure the scotch pad does not get blocked and restrict air flow ... and I will eventually go for a CCA, Mike Norris or RX. But I was in a McGyver mood.
simon.w is offline   Reply With Quote
Old 04-26-2011, 02:18 PM   #2
BigCarrot
xbox: this is tedious
BigCarrot's Avatar
Drives: 2011 1SS M6 Camaro IOM
Looks good for that little amount of money. I wonder how much oil it has caught so far?
Any results? I'm not critiquing just curious
Big Carrot's Changes - It's a work in progress
Originally Posted by Fiftydriver View Post
Seems like just yesterday I spent $450 for a Roto Fab CAI!!! What the hell happened.
BigCarrot is offline   Reply With Quote
Old 04-26-2011, 02:35 PM   #3
Oxtar41
Oxtar41's Avatar
Drives: 700 rwhp 2010 SS
If you spent a ton of money on a blower and have your engine bay chromed out and painted, why not spend the 130 for a RX can that WORKS (not saying yours doesn't but we KNOW RX cans work though).
Either way it looks decent though!
Oxtar41 is offline   Reply With Quote
Old 04-26-2011, 02:36 PM   #4
ArkySS
Camaroless for now...
ArkySS's Avatar
Drives: 2014 Blue Topaz Silverado
Good lord nice work man!
It was fun while it lasted.....
ArkySS is offline   Reply With Quote
Old 04-26-2011, 02:38 PM   #5
very nice job, looks great
Old 04-26-2011, 02:43 PM   #6
simon.w
So I did everything in the engine bay myself too ... fitted the blower, headers, CAI, painted everything. This was simply an extension of that. I'll do two things in a month ... remove the throttle body again to check oil build up, and drain the can to see what it's caught. That should tell me whether it's working on not.
Old 04-26-2011, 02:44 PM   #7
simon.w
Only fitted it Sun night .. would have only done 10 miles since then.
Old 04-26-2011, 03:14 PM   #8
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
[QUOTE]
2 x 3/16' barbed x 1/4" threaded chemical resistant nylon right angle hose fittings
1 x brass micro tap
The Man is a Genius, Congrats, I love it.
I am really impressed by the Drawings.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 04-26-2011, 03:19 PM   #9
BlackinBlack
BlackinBlack's Avatar
Drives: 2016 Corvette Z06 Blade Silver
[QUOTE=JANNETTYRACING;3144975]
Ted.
I am interested to see how well it works.
2016 2LZ Z06 Blade Silver
2013 ZL1 BLACK on BLACK <SOLD>
Roto-Fab CAI
2010 2SS/RS BLACK on BLACK <SOLD>
3" MBRP 304 Stainless Exhaust
Roto-Fab CAI
BlackinBlack is offline   Reply With Quote
Old 04-26-2011, 03:19 PM   #10
simon.w
Ted.
Thanks so much Ted ... that means a lot coming from you!
I should have photographed it as I made it ... but I just wanted to get it finished ... so when it turned out so well I thought I'd Photoshop up a drawing for others to follow.
I'm sure there are others out there like me who would like to get the real deal eventually ... but in the mean time has the ability to make something themselves that is better than the coffee tins with fittings on eBay for the same price.
I don't know how long it will last ... and only time will tell how well it works ... but boy I had fun making it ... and I'm very proud of how it turned out.
Old 04-26-2011, 03:29 PM   #11
JANNETTYRACING
[QUOTE=simon.w;3145007]
I have been fabricating my own tools and gadgets my whole Life So I can Really Appreciate what you did.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 04-26-2011, 03:43 PM   #12
Kendell347
Doc
Kendell347's Avatar
Drives: BLACKOUT (2SS/RS)
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 128Mods: CAI CAI, Emblempros Dash Plaque, R/C Lic. Plate, Fbodfathers signature, AAC SMD SML, AAC P13 LED DRL, TF center console, Full dash ABL, Noweed Exhaust Diverters, Heritage Grille, Door Projectors, 20watt LED reverse lights with strobe features, S.S. black billet grille with air scoops, custom designed engine cover, custom designed "BLACKOUT" cross drilled / slotted rotors, Borla S-type exhaust, Elite Engineering oil catch can, Nitto Invo Tires WWW. NY5THGEN.COM
Kendell347 is offline   Reply With Quote
Old 04-26-2011, 05:20 PM   #13
SC2150
This should work! The PVC will not cool like metal for the condesing effect but it looks good!
Old 04-26-2011, 05:29 PM   #14
Tshepp
Show & Go
Tshepp's Avatar
Drives: '10 Camaro 1SS LS3
DAMN!! That is so awesome, I really want to do this myself. I also understand that the catch is a useful mod, but just cant justify spending $150 on an aluminum can that costs MAYBE $5 to make...
Tshepp is offline   Reply With Quote
Home made CAI, comments and suggestions RBC2010SSRS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 37 04-29-2010 11:43 PM
Home Made Fuse Box Cover markmass Camaro DIY & HOW-TO instructions & discussions 2 12-22-2009 09:33 PM
"Sinister" Finally made it home!!!!!!! Mr. Brownstone Camaro Photos | Spyshots | Video | Media Gallery 37 11-27-2009 02:01 PM
#7830 Made it Home scifisteve 5th Gen Camaro SS LS LT General Discussions 12 05-29-2009 03:07 PM
Going Green, Means going Made In China One Mean Chevy Off-topic Discussions 0 04-26-2009 12:04 AM
