04-29-2011, 08:05 PM | #1 |
Drives: 2011 SS/RS Join Date: Feb 2011
Walbro Pump instead of BAP????
Just trying to get some knowledge on this fuel pump. Why would I buy a BAP for $250 when I can get a Walbro pump for 125? Just wanting peoples input here. Thanks
04-29-2011, 08:20 PM | #2 |
My car runs on acorns....
Drives: 2010 SS RS Inferno Orange Join Date: Feb 2010
Really? didn't know they were that cheap. I'm positive that the install of a BAP is much simpler than a new pump though.
My car runs on acorns, the tears of ricers and these other slightly less important things...
2.9 Polished Whipple, Kooks LT 1 7/8 headers, HiFlow Cats, Kooks Sleeper catback, Cooling Mist Methanol Injection, PFADT Sport Sways, PFADT Springs, PFADT rear trailing arms, ADM intake, JDP stainless brake lines, Jegs Catch can, Stock SS wheels widened to 10 3/4, Hawks HPS Pads, Pedders Rear Subframe Bushing Inserts, BMR Center Brace, MSD BAP, AAC side markers, Emblem Pro's Custom Lighted Door Sills, Dash-Floor-Cupholder ABL lighting and other stuff.... |
04-30-2011, 04:53 AM | #3 |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
I am in no way an expert here but from what I have gathered so far, you cant just drop in an aftermarket pump. Most aftermarket pumps will not be compatible due to the way the Camaro fuel control system electronically modulates flow/pressure. Aftermarket pumps will not work on a vehicle system that uses pulse width modulation to control the pump output. It's not just a drop-in affair or people would not be spending a grand or more on adding fuel pump upgrades.
You can add an aftermarket pump and return line style fuel system and re-engineer the whole fuel supply including dealing with the electronic control module. Aftermarket pump install is FAR from easy and cheap. No HP limit - just keep upping the system until you have more than enough fuel. You can keep the factory returnless style system and buy compatible pumps (from other GM applications) and install those upgrades. GM pump style upgrades are sort of easy, somewhat expensive and they are very reliable. More HP potential than a boost a pump. Boost a pump is easier and cheaper but you can only go just a bit more HP before the BAP runs out of potential. Some would question reliability. I am sure you will get a better answer from someone who knows this stuff more than I do but this is pretty close. -Mark. |
04-30-2011, 06:37 PM | #4 |
thanks Mark
04-30-2011, 06:42 PM | #5 | |
Drives: 2010 rs ss Join Date: Jan 2010
Similar Threads | ||||
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) | robertway | Camaro DIY & HOW-TO instructions & discussions | 313 | 12-16-2023 06:53 PM |
Lingenfelter 2010-2011 Camaro fuel pump voltage booster kit | jrh@lpe | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 0 | 08-28-2010 12:24 PM |
walbro fuel pump | halo8hkk | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 07-13-2010 10:28 PM |
PERRIN Performance Water/Methanol Injection Kit | PERRIN_JOHN | Forced Induction | 4 | 03-17-2010 09:57 PM |
Stock Injectors vs Magnuson Kit Injectors | Mark-HD | Forced Induction - V8 | 24 | 01-27-2010 08:04 PM |
