Old 02-28-2009, 11:10 AM   #1
spruce26
Drives: 96 camaro v6
A/C HELP!!!
i took my 3.8 96 camaro down to the shop to get my a/c check and they said i had a small leak in the compressor and my condenser will have to be changed. is it smart to let them do it? or is it a easy enough job to do it in the garage?? and what are some good sites to purchase those parts?
thnx
spruce26 is offline   Reply With Quote
Old 02-28-2009, 12:43 PM   #2
CatiaJockey
CatiaJockey's Avatar
Drives: 2010 2LT RS
Since you had to ask the questions you asked, I'd say you need to let a shop perform the task. It takes special tools to do A/C work.
Old 02-28-2009, 12:50 PM   #3
MrCool
MrCool's Avatar
Drives: '95 Z28
Unless you have the tools and know-how...you might want to let them do it.
But just make sure you have a good mechanic.
MrCool is offline   Reply With Quote
Old 02-28-2009, 01:18 PM   #4
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
A/C work is not diy work imo, always take it to a licensed mechanic. Freon can be some nasty stuff if not handled and disposed of correctly.
Old 02-28-2009, 03:54 PM   #5
UA488Fitter
UA488Fitter's Avatar
Drives: 1981 Z28 1995 Z28 2010 2SS/RS
The problems that DIY'ers have with working on AC systems has mainly to do
with the refrigerants and the CFC's that they contain. CFC's are ozone killers;
because of this are restricted substances; you need a certification to handle them.
So if you want to replace the parts in your garage your will first need to have
someone that is "certified" to handle refrigerants to evacuate them from your
AC system. After that it would be a good idea to have them purge your system
with nitrogen. You need to prevent air from entering the system; O2 and water
are real killers to an AC systems. After you've replaced the parts you will once
again need someone that is "certified" to handle refrigerants to recharge your system.
Your compressor leak is more than likely cooked seals, #18 in the diagram below.
That is a fairly easy fix; but you MUST keep everything clean and dry, you don't
want any contaminants entering your AC system. Also remember that the compressor
is 12 years old; you may want to consider replacing it.
Condenser???? Are you sure that's what they mean? #3 or #4 in the diagram?
The condenser sits in front of the rad; unless it has been punctuered by something
it should be just fine. I would think that your shop is refering to #4 the receiver.
This part is commonly call the accumulator in the refrigeration industry. It is there
to dry, filter and receive/accumulate (hold) the liquid refrigerant prior to being applied
to the evaporator. As this part contains desiccants to remove any moisture, it is
commonly replaced any time the AC system is opened up.
Parts? Summit Racing, NAPA, or similar outlet; but here's a word of caution.
Make sure that the parts that you purchase are NOT "made in China"; parts coming
from China are GARBAGE, I repeat GARBAGE, of LOW quality, inferior and will not last.
Pay the extra dollar and find parts made in the USA, Canada or Europe; parts
made in these places will be of much higher quality and will last a long time.
So if after reading this long winded advice, you still feel up to the task; fly at it.
Though you should keep in mind that if you get the work done at a reputable shop;
their work should come with a warranty. Plus you will be helping your local economy.
UA488Fitter is offline   Reply With Quote
Old 02-28-2009, 05:32 PM   #6
craigd853
Drives: 199 SS Camaro
First of all, why is the mechanic telling you that, your condensor needs replaced when the leak is supposedly in the compressor. It is normal practice to have to change the filter drier and orifice tube when changing out the compressor. Also, what was said earlier about needing special equipment to service this system is very true. A round about guess at what it should cost if indeed the seals are bad in your compressor, a system flush, a rebuilt compressor and orifice tube is probably going to cost around $800.00 and 1,200. By all means get a second opinion, most are free.
craigd853 is offline   Reply With Quote
Old 03-31-2009, 02:59 PM   #7
lafountain
lafountain's Avatar
Drives: 2011 Synergy Green 2LT/RS
I can vouch for the work involved stated in UA488Fitter's post. I am certified to work with freon on everything but automobiles and it can be a pain. I also agree that if the compressor has a leak, there is no need to replace the condensor. I actually have to get mine checked out too as when my engine was replaced the guy recharged my A/C system and it has already started to not cool again so I have a leak somewhere as well. Best bet though is find a certified mechanic and get an estimate, then go somewhere else and get a 2nd estimate.
Hey, you want to lay the fate of the world on the kid's Camaro? That's cool.
I bought a car, turned out to be an alien robot. Who knew?
lafountain is offline   Reply With Quote
FINAL Production 2010/2009 Camaro! (PICS) rray200 Camaro Photos | Spyshots | Video | Media Gallery 799 05-19-2011 11:48 PM
Fbodfather/ Anyone who's driven the new Camaro... question? (just curious) scotchsride09 5th Gen Camaro SS LS LT General Discussions 13 09-23-2008 06:45 PM
CamaroScotty's JULY 22 Dealer Presentation Details Thread CamaroScotty 5th Gen Camaro SS LS LT General Discussions 332 07-28-2008 03:28 PM
