Jason 98 TA
Old 05-04-2011, 03:41 PM   #15
caverman
caverman's Avatar
Drives: '69 SS Convertible
I had a can of High Temp VHT paint in Aluminum color. I used to blend in the colors of the two metals. Worked great and took me about 5 min to do.
Originally Posted by Stone★ColdNuts View Post
They now rest peacefully in my shed, in case I need them to pass state inspection.
LOL....waste of space. You'll end up tossing them.
Before you pay to put those back on you should add a resonated X-pipe. That will be your muffler and give you just a little performance.
http://www.camaro5.com/forums/showthread.php?t=64964
Build Journal
Old 05-04-2011, 03:55 PM   #16
TSSUNAMI
It was ninety nine cents!
TSSUNAMI's Avatar
Drives: 2014 Jeep Wrangler
Ahhh Caverman! I've been looking for your thread about your setup since yesterday! Thank you for posting it up!
I am strongly considering the resonated X-Pipe. I didn't get aftermarket tips, but the ones you use do look sharp. I planned on doing this as a step by step process, essentially following your build. I will Re-Read it and shoot any questions your way if you don't mind?
TSSUNAMI is offline   Reply With Quote
Old 05-04-2011, 04:15 PM   #17
caverman
caverman's Avatar
always happy to toss out some suggestions.
Once I switched over to headers and the 3" Magnaflow exhaust I sold mine to a guy with a 2LT for $300. Sounded alot better than I thought it would on a V6. They need the resonated x-pipe to keep if from sounding like a ricer.
Muffler delete on a V6 is no good. Muffler delete with resonated x-pipe on a V6 .
Build Journal
Old 05-04-2011, 05:15 PM   #18
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
[QUOTE=Stone★ColdNuts;3176525]Just had a local muffler shop cut off my jerry can's.
Question: Is the replacement pipe used a strait pipe, or did they had to bend it with a mandrel to weld your original tips?
Do you know what's the size of pipe and its lenght?
thanks
mike
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 05-04-2011, 05:28 PM   #19
looks good
Old 05-04-2011, 05:44 PM   #20
TSSUNAMI
TSSUNAMI's Avatar
[QUOTE=Mikamaro;3180028]
Question: IS the replacement pipe they used a strait pipe, or did they had to bend it with a mandrel to weld you tips?
What size of pipe was it, do you know?
thanks
mike
It was 2.5 inch pipe to match the rest of the exhaust as far as I know. Stainless steel, not sure what grade. It started out as straight pipe, but they bent it to fit.
Old 05-04-2011, 09:07 PM   #21
rocketman 12
SOON.........
rocketman 12's Avatar
Drives: 2010 ABM SS/RS Z-281LE
Welcome to the club! One thing you NEED to do... stand about 5 feet directly behind your car, then have your fiance(or a buddy) get in and fire it up, after you pick your jaw off the ground have them rev it up to 3-4k a couple of times....I just had my wife do this a couple weeks ago, I almost needed to change my pants after, it was AWESOME!!!!
No, it's not a real Z/28.....
rocketman 12 is offline   Reply With Quote
Old 05-04-2011, 09:27 PM   #22
BLACK10
BLACK10's Avatar
Throw an xpipe on it and it will deepin the popping a little
Old 05-04-2011, 10:10 PM   #23
5150 Maro
5150 Maro's Avatar
Drives: 2012 SS 45th Anniversary
Good review on this, thanks for all the info. Is there anything that decreases the popping ???
5150 Maro is offline   Reply With Quote
Old 05-04-2011, 10:57 PM   #24
caverman
caverman's Avatar
A resonoated X-pipe from Magnaflow will help a little. Won't get rid of it but should tame it down some.
Build Journal
Old 05-05-2011, 03:24 PM   #25
TSSUNAMI
TSSUNAMI's Avatar
I will likely do the resonated x-pipe within the next few weeks. I will update when it is finished.
So far, so good with the setup though.
Old 05-05-2011, 04:07 PM   #26
Rockin the BlueSS
The New Guy
Rockin the BlueSS's Avatar
Drives: 2010 2SS/RS IBM M6
if you are a manual car you can simply push the clutch in / take it out of gear and this will eliminate 99% of the pops. the other 1% me get help from an x-pipe...
if your an auto a tune will eliminate the pop
i love my muffler delete....
Rockin the BlueSS is offline   Reply With Quote
muffler delete with xpipe and no resonators, first imprseeions caper Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 07-05-2011 05:41 PM
LT header and muffler delete kbui USA - Texas 6 06-17-2010 06:39 PM
Muffler delete ch3apsh0t Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 05-21-2010 03:18 PM
DIY at home Muffler Delete for $20 CDBiker220 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 10-12-2009 07:32 PM
Muffler Delete with Dyno clips and pictures KK2010SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 07-26-2009 03:09 PM
