Old 05-04-2011, 06:42 AM   #15
Ironheadspearo
ride the pain train
Ironheadspearo's Avatar
Drives: 2011 1LT RS, 1998 fxstc HD
I have been running mobile 1 synthetic extended mileage oil for the past 5 years now, it is rated up to 15,000 miles. the problem with this is that oil filters are not matched up to go the 15,000 miles. in the past i was buying the best filter i could get and running them upwards of 13000 miles with no issue. i would feel the oil and inspect it when drained and even with 13000 hwy miles on it the oil felt actually pretty thick like new oil would just black. at 7000 miles it was still semi translucent. I now run the oil to 13000 in the camaro but with a top mounted filter it is easy to change out the filter every 4 or 5 thousand miles. the main thing when running your cars mileage up vetween oil changes it to every 2 to 3000 check the level because you will need to add some most likely. adding some new to replenish the old that was lost also helps freshen up the oil some. you will save a ton of money doing it this way especially if your on the hwy alot. i used to change it every 3000 with regular oil but for me it was every month i was changing oil.
PAIN is temporary, PRIDE is forever......RACE HARD
Ironheadspearo is offline   Reply With Quote
Old 05-04-2011, 06:52 AM   #16
Russell James
Russell James's Avatar
Drives: Camaros
I got the same recall notice for an Acadia w/ 3.6 L I use to own. It was to reprogram the Oil Life Monitor due to premature timing chain failures.
That tells me two things. The timing chains aren't so great. And, those real long oil change intervals may not be so great if they can contribute to an engine problem.
I never bought into the OLM theory, 3 -5 K changes for me. I've done a ton of oil changes on other peoples cars where they take it down to 0% on the OLM, and that oil looks nasty. I'll trust my eyes before theories, and now there is a recall to back up that suspicion that real long oil change intervals may not be so great - gee who'd of thunk it.
Old 05-04-2011, 07:01 AM   #17
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
Another problem with these long oil change intervals is that most people never check their oil. How many engines have been ruined by people assuming everything is fine because of the monitor running their cars out of oil.
I'd never use the oil life monitor. I go by how it looks on the stick. I know using the oil monitor is "probably" ok, but "probably" doesn't cut it when it comes to an engine on a $35,000 car.
"Proven V-8 power with better efficiency than a turbo V-6"
"The car is the closest thing we will ever create to something that is alive."eds.
fielderLS3 is offline   Reply With Quote
Old 05-04-2011, 07:06 AM   #18
shawn18
OWTATIME
shawn18's Avatar
Drives: 1969 CaRaMo & 2015 Z/28 #595
I check mine regularly and change it around 35-40%
2015 #595 A/C
shawn18 is offline   Reply With Quote
Old 05-04-2011, 07:14 AM   #19
Markel
Drives: 2010 L99 2SS/RS
Thumbs up
Thank you for posting this!
Markel is offline   Reply With Quote
Old 05-04-2011, 07:16 AM   #20
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
its good in theory,, but it just doesnt work,, especially when people use cheap oil,, and no one checks their oil anymore, then people complain that they have their low oil light come on but they have 8000 miles on their oil change.
gm is re-programming many of the v6 engine ecm's to make the oil change light come on sooner because of all the problems these engines are having with oil issues
Old 05-04-2011, 07:22 AM   #21
scottyvegas
X SS
scottyvegas's Avatar
Drives: 2010 Camaro 2SSRSM6 1988 Sportside
Great info..
MODS: PEDDERS XA COIL OVERS, STAGE 3 CAM, McLEOD CLUTCH, SKIP SHIFT, , HURST SHORT THROW, CAI INTAKE, SCOOP, WASHER RELO KIT, KOOKS HEADERS, KOOKS HI FLOW CATS, CUSTOM TUNE, QTP CUT OUTS, PAINTED STRIPES, PAINTED SS EMBLEMS, PAINTED FIN, PAINTED REAR TAIL LAMP BEZELS, HERITAGE GRILLE, DUCTS, AAC STUFF, BAER ROTORS, HAWK PADS, FUZZY DICE, LASER BEAMS, DISCO BALL, SYBIAN & 3 CHROME VALVE STEM CAPS................
scottyvegas is offline   Reply With Quote
Old 05-04-2011, 09:34 AM   #22
TooCool5
Resident Gearhead
TooCool5's Avatar
Originally Posted by Fearer2010SS View Post
Just changed my oil in both my cars:
Camaro: 7,200 miles with 28% left after one year. The manual says to wait for the DIC or one year.
Fiesta: 10,076 miles when the oil change sensor went off. The Ford manual states to change the oil every 10,000 miles.
- For the record many car companies go a lot further than even 10,000 miles. Oil is SOOOOO much better than was when 10W40 and 3,000 miles were the standard.
Looks like I will be going to the one year interval too. My Mobil1 oil has 5,200 miles on it and 40% Oil Life. in 10 months.
Old 05-04-2011, 09:54 AM   #23
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
so you'd rather trust your eyes (that I'm sure are calibrated to judge actual contamination of oil, not just its "dirty look") over a system designed by engineers for the sole purpose of telling you if your oil is good or not?
sorry, but "How it looks on the stick" doesnt cut it when it comes to an engine on a $35,000 car.
define cheap oil.
you talking regular dino oil vs synthetic? the system works with both types of oil.
I piss excellence
and fart awesomeness
Old 05-04-2011, 10:06 AM   #24
el ess A
formerly "el ess X"
el ess A's Avatar
Drives: 2010 & 2013 Camaros
OnStar is "on my butt" about the Camaro OLM reading like in the 80s yet it's been a bit over a year since an oil change.
Your vehicle is due for required maintenance because your oil life system has not been reset for 12 months.
Hence the little warning sign on my OnStar report. They suspect I'm not resetting my OLM, but fugg 'em. Car only has 6800 miles on it. So when I change my oil, THEN I'll reset it.
I've used the OLM to schedule oil changes for all the vehicles so equipped and never had an issue with any of them. None. I believe...
2010/2013 Camaro
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 05-04-2011, 10:07 AM   #25
IROCanSS
Drives: 89 IROC 350
I can't remember the last time I changed my oil. Checked it yesterday... Full, pretty clean and 51% on the indicator. I think I changed it last fall...
Old 05-04-2011, 10:09 AM   #26
camaro1
camaro1's Avatar
the system doesnt know what you put in for oil,, the system does not do any tests on the oil,, it is just a calculated value based on rpm, speed, load, time, temperature
you could put drain oil back in your car, reset the OLM to 100% and the computer will start its calculation again, same as any other oil used
Old 05-04-2011, 10:09 AM   #27
Gramps69Z
Still waiting on the Z
Gramps69Z's Avatar
Drives: 69 Z/28, 06 Denali, 09 CTS
Send a message via AIM to Gramps69Z Send a message via Yahoo to Gramps69Z
Two years, two oil changes on the 5600 mile CTS. Had 78% left on the OLM when it was changed last time. (Mobil 1 and a Wix filter) It's driven 4 miles every third day to work, and has one trip to Kentucky on it.
October 31, 2015 at 0700 - officially retired
1969 Chevrolet Camaro Z/28
2006 Denali
2009 Cadillac CTS
The Six Old Guys
The last thing we want is to ship something that isn't right.
Gramps69Z is offline   Reply With Quote
Old 05-04-2011, 10:16 AM   #28
el ess A
formerly "el ess X"
el ess A's Avatar
OLM is not a check to see if someone is being an idiot and putting drain back oil in it or simply resetting the OLM. So you don't believe in it. Ok, we get it. So what? Big deal. You can't convince me that it doesn't have merit. And it comes with the cars nowadays, why not use it?
You have to make some assumptions when running a computer program. The program is assuming once you reset the system, you put in the proper and approved grade/quality oil and keep it topped off. It figures it out based on those assumptions. If you don't live up to your end of the bargain, then nobody or no program can protect you from being a dumbass and doing dumbass things. I'm speaking rhetorically here.
2010/2013 Camaro
AFM turned off by my dealer???? fastfreddie 5th Gen Camaro SS LS LT General Discussions 95 08-25-2012 02:55 PM
Can we use the catchcan made for the G8? HaZe_X Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-05-2010 10:35 AM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
