sjm autoprod
Old 05-04-2011, 11:06 AM   #1
jjjaroscak
jjjaroscak's Avatar
Drives: Cyber Gray 2011 2LT Camaro
In cabin 12v constant
So using this diagram: http://www.camaro5.com/forums/showpo...0&postcount=24
to hook up my dual halos it looks like I just need to find a 12v source for the switch, since I'm puting it on the drivers side of the center consol thing I was hoping one of you could suggest a wire to tap into. Since I have a non-rs and can turn on my running lights (power for halos) without the key in the ignition, I want to be able to switch from white to blue at all times. So what is my easiest/best option? Thanks!
jjjaroscak is offline   Reply With Quote
Old 05-04-2011, 02:11 PM   #2
MUSCLEIT
MUSCLEIT's Avatar
Drives: 2010 REDLINE EDITION#46
DO YOU WANT 12 volt all the time..even with key out ?
REDLINE MOTORSPORTS EDITIONMOTORSPORTS
MUSCLEIT is offline   Reply With Quote
Old 05-04-2011, 04:59 PM   #3
jjjaroscak
jjjaroscak's Avatar
Yes, that way I can flip the switch, and turn on my running light without putting my key in and have the blue halos on and not be stuck with just white without the key
Old 05-04-2011, 05:39 PM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
Dual halos have one power and two grounds for the dual halos. So do you have a switch that lets you switch between the two colors?
Click to view my build thread
Old 05-04-2011, 05:48 PM   #5
jjjaroscak
jjjaroscak's Avatar
Yes, I have the switch and the relay, what wire is easiest to tap into the get the power I need for the switch that would provide power at all times so that I don't need to the key in the ignition to get blue to turn on
Old 05-04-2011, 05:50 PM   #6
The Stig
The Stig's Avatar
I would just check your manual for a 12v fuse in the driver side fuse box
Old 05-04-2011, 06:07 PM   #7
jjjaroscak
jjjaroscak's Avatar
I'm an electronic newb, how do I connect a wire to a slot in a fusebox...
Old 05-04-2011, 10:14 PM   #8
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
http://www.camaro5.com/forums/showth...e+tap+autozone
fuse tap
overhaulengines is offline   Reply With Quote
Detailing questions answered here! Moose Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 636 06-04-2011 12:27 PM
12V!!! HELP BEFORE I BREAK IT! ZuluKilla8 Camaro DIY & HOW-TO instructions & discussions 5 11-16-2010 10:46 PM
Constant 12v power source? 13lade Cosmetics and Lighting Modification Discussions 8 06-12-2010 11:51 AM
Do solar chargers that plug into the 12v port work? armando416 5th Gen Camaro SS LS LT General Discussions 9 01-13-2010 05:05 PM
*ORACLE 4 Channel 12V Remote Control Unit Group Buy!* AACstyle Audio / Visual / Electronics/ Gauges / Nav 9 01-03-2010 11:19 AM
