Old 05-04-2011, 09:43 PM   #1
cho62
2013 & 1989 Camaro
cho62's Avatar
Drives: 2013 Camaro 2SS
tree sap removal
i just got a thick drop of tree sap on my hood, any suggestions on how to remove it, im scared to use something like goo off, thanks in advance
cho62 is offline   Reply With Quote
Old 05-04-2011, 09:53 PM   #2
nomadicdogg
Drives: '10 2SS/RS Cyber Grey Camaro (sold)
Clay Bar with extra spray lubricant
should take it right off. just dont rub on it crazy. light and slow and you should be fine.
nomadicdogg is offline   Reply With Quote
Old 05-04-2011, 10:08 PM   #3
edgehead2000
2016 Camaro 1LT 2.0T
edgehead2000's Avatar
Drives: Nemesis
I had just clayed my SIM for the same reason. Anybody know how to remove the small amounts of sap from the windshield? Think that can be clayed too?
edgehead2000 is offline   Reply With Quote
Old 05-04-2011, 10:11 PM   #4
INTIMIDAT3R
Drives: '11 2SS/RS L99, '12 2LS LFX
Dawn dishwashing soap will get rid of any tree sap problem.
Now, you either have to re-wax after claying or washing with Dawn.
Take your pick.
Me, I choose Dawn. Much easier.
INTIMIDAT3R is offline   Reply With Quote
Old 05-04-2011, 10:20 PM   #5
VChula
SoCal C5 Family Member
VChula's Avatar
Drives: 1996 Z28 SS & 2010 RS
Using a clay bar on the glass works quite well!
Vance Chula -
1996 Camaro Z28 SS #1688
2014 Camaro ZL1 Coupe #1956
VChula is offline   Reply With Quote
Old 05-04-2011, 11:08 PM   #6
1BADLS3
1BADLS3's Avatar
Drives: Sold: 2011 2SS/RS
Yes, you can clay the glass. It actually cleans it very well, but I don't recommend for sap unless it's sap that's spritzed on from a nearby fir (tiny little droplets, feel like sand)-- most of those are taken off with soap and water. On glass, a razor blade makes quick work of taking up sap, especially big or hardened globs.. Follow up with a coat of rain-x, after washing and claying the glass.
Tree sap on paint...sorry, sometimes Dawn dish soap just won't cut it. If it's a huge glob (this I know about...I have 100' firs on my property), you need to get as much of the glob off the body panel as possible using paper towel or a dull plastic edge (be very careful about scratching the paint).
Then, depending on the age of the sap, I'll use a bit of bug and tar remover. With fresh sap, it comes right off. If it's aged a bit, I'll put it on the sap and rub it in a bit with the tip of my finger. Sometimes a clay bar helps, but the hard tree sap just usually shreds the clay. For the really bad stuff, I'll put on a pair of thicker latex gloves and work the edges with my nail, using a healthy glob of bug and tar remover.
1BADLS3 is offline   Reply With Quote
Old 05-04-2011, 11:09 PM   #7
TOMS1SS
Drives: NA
Clay bar works wonders.
TOMS1SS is offline   Reply With Quote
Old 05-04-2011, 11:15 PM   #8
CUPRA
CUPRA's Avatar
Drives: 2011 2SS/RS - IOM/CGM Stripes
I've found sap comes off no problem at all with the Turtle Wax car wash soap I use... coupled with a chamois mitt, never had a problem with it.
I have Turtle Wax Ice on my car, and things don't seem to stick to it very well at all, which makes cleaning a lot easier too.
2011 - 2SS/RS - IOM/CGM Stripes • CUPRA • Ordered: 4/10/2010 Mine: 7/1/2010
CUPRA is offline   Reply With Quote
Old 05-05-2011, 06:30 AM   #9
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Turtle Wax Bug and Tar remover, spray on let it sit a few minutes wipe off.
Scott@Bjorn3D is offline   Reply With Quote
Old 05-05-2011, 10:11 AM   #10
Skyblu
Skyblu's Avatar
Drives: 2010 Aqua blue 2SS/RS M6
the quickest easiest and non-damaging way is to use a small amount of go-jo non -pumice hand cleaner,put a small spot on the wax,smooth it around all over the sap,let it sit for a few minutes wipe away with a soft cloth. It will not hurt your paint,it' s simple and painless. My husband used to be an autobody man and this was a tip they used to tell people about after having their car painted. It's petroleum based and safe, you can use vaseline too but doesn't work as well.
Skyblu is offline   Reply With Quote
Old 05-05-2011, 11:20 AM   #11
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
I'll offer up some advice for a very simple solution.
70% Isopropyl Alcohol on a plush microfiber towel. Soak a spot on the towel, put in on the sap and hold it there for a few moments, then gently wipe. The IPA will soften the sap up for removal, then simply follow up with a little Detail Spray and touchup the area with your preferred wax/sealant.
Old 05-05-2011, 03:19 PM   #12
cho62
2013 & 1989 Camaro
cho62's Avatar
thanks alot guys, so far ive got most of it off with dish soap, im gonna try the alcohol tonight to get the remaining off or i might just clay bar it since the car needs it anyways this stuff is really thick but im sure it will wipe right off thanks again
Old 05-05-2011, 03:47 PM   #13
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
This is the technique I used to remove 3 years worth of sap from my '97 Chevy truck before selling it. Didn't matter if the sap was hard and dry or fresh and soft. The alcohol and microfiber towel took off every bit of it.
rolnslo is offline   Reply With Quote
Tree Sap removal? djamphi555 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 5 09-19-2010 07:18 PM
tree sap norton750 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 4 06-21-2010 09:28 AM
Tree Sap.... UGH! Verio Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 16 09-08-2009 11:14 PM
Tree Sap SirBrad Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 14 07-15-2009 09:01 AM
