ModBargains
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 05-04-2011, 09:52 PM   #1
73duster
Drives: 2010 camaro ss automatic
My check engine light cleared itself!
Has anyone elses check engine light clear itself? My check engine light has popped up a couple of times since i did long tubes, High flow cats and full exhaust with cam. The first two times i checked it, and cleared it with my handheld tuner. The code read engine misfire each time. Anyway, the last time it popped up again, i just kept driving with it on. It stayed that way for over a week, but today when i started the car to go to work, the check engine light stayed off. Does anyone know if the cel clears itself on it's own?
73duster is offline   Reply With Quote
Old 05-04-2011, 09:58 PM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
Doesn't mean it will stay gone for good. There is a chance it will come back.
Build Journal
Old 05-04-2011, 10:36 PM   #3
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
The misfire light will clear itself after three pcm cycles with no misfire error
Ovenmitt is offline   Reply With Quote
Old 05-05-2011, 06:55 AM   #4
KARBON
KARBON's Avatar
Drives: 2010 CAMARO 1SS/RS L99
Mine done the same thing after putting on LT and high flow cats, took bout 10 miles to come on. Stayed on for bout 2 day's.. the next morning it was out, 3 day's now it has stayed out.. It will come back eventually..
KARBON is offline   Reply With Quote
Old 05-05-2011, 07:49 AM   #5
Badger
Badger's Avatar
Drives: 2010 ABM SS
It will be back
"One of the ordinary modes, by which tyrants accomplish their purposes without resistance, is, by disarming the people, and making it an offense to keep arms."
-- Constitutional scholar and Supreme Court Justice Joseph Story, 1840
Badger is offline   Reply With Quote
Old 05-05-2011, 08:02 AM   #6
barnesql
Drives: 95' Z28, 2010 2ss RS
You did get a tune after install on these things right?
2010 Camaro SS - LS3
Magnaflow 3" Competition Series Catback
Off road x-pipe
Kooks LT Headers
barnesql is offline   Reply With Quote
Old 05-05-2011, 08:20 AM   #7
x2martell24
x2martell24's Avatar
Drives: 2012 ZL1
It will come back. The only way to lose the codes for good is with a tune. Talk to Ted at Jannetty.
x2martell24 is offline   Reply With Quote
Old 05-05-2011, 10:15 AM   #8
KARBON
KARBON's Avatar
Vector is on the way
Old 05-05-2011, 02:14 PM   #9
73duster
Ted contacted me and is sending me a download for my flash tuner. It was a simple problem with a quick fix. Jannetty Racing rocks! Ted's customer service is second to none, and i highly recommend going to them no matter how far away you are, well worth it!
Engine Misfire when cold, Check Engine Light TooCool5 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 16 03-30-2011 10:26 AM
Check Engine Light... Missionboi Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 01-08-2011 01:02 AM
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 01:56 PM
Help with Check Engine Light after tune jrpxxii Tuning / Diagnostics -- engine and transmission 8 11-06-2009 05:37 PM
Voice Your Comments/Suggestions/Input for Focus Group on 2010 Camaro Mr. Wyndham 5th Gen Camaro SS LS LT General Discussions 236 04-22-2008 12:43 AM
