JUICEDMOTORSPORTS
Old 05-05-2011, 05:22 PM   #1
Allan Hernandez
Allan Hernandez's Avatar
Drives: 2LT/RS RJT/GrayHStripe
Send a message via Yahoo to Allan Hernandez
how does the paddle shift work in my 2lt/rs
I dont know how to drive standard but ive tried to put my camaro into manual mode a couple of times.I kind of get it but I dont want to mess up my transmission.Can any one show me how to use it and if it gives it any boosts performance wise
Allan Hernandez is offline   Reply With Quote
Old 05-05-2011, 05:38 PM   #2
Papa T
Papa T's Avatar
Drives: 2011 2LT RJT, 6A, 19" polished
D = Drive (Normal)
M = Sport and Manual.
M - Sport gives you a more aggressive "Automatic" shift than D, but still automatic.
M - Manual is once you start "Tapping" the shift up or shift down buttons on the back of your steering wheel.
to get back to sport mode, you press and hold the right button on the back of your steering wheel.
Hope this helps.
Papa T is offline   Reply With Quote
Old 05-05-2011, 05:55 PM   #3
Papa T
Papa T's Avatar
Sorry just read the subject line... :(
I'm not a racer so some one else will have to give you the low down on "optimal" shift rpms.
But day to day and spirited diving here is my 2 cents:
So if driving normal traffic speed
  • Start in M1 rev to ~3k and tap up and continue through the gear each time you reach ~3k or what ever feel right. If rpms are too low it will not shift up. you will get a "Shift Denied" message.
  • Down shifting is similar just in opposite order. let your rpms drop to about ~2k (maybe a little lower) tap down then kept going through the gears. Can't go wrong on the down shifts for low rpms because it will automatically down shift for you.
Once you are comfortable with the above, then you can start getting more aggressive.
  • Increase revs to ~4k tap up
  • let your revs go down to ~3k and tap down
Listen to the car you will start to get a feel for it.
So Everyone else... what are the optimal shift points?? And what revs should you stay away from up shifting and down shifting??
Old 05-18-2011, 09:21 PM   #4
StlRomAniaN
StlRomAniaN's Avatar
Drives: IOM 2010 Camaro 2SS/RS
WOT you can shift around 5900-6000 to get a good shift. I would wait to 2000-2500 to downshift because 3000 would cause it to rev really high, around 5000.
StlRomAniaN is offline   Reply With Quote
Old 05-18-2011, 09:29 PM   #5
5thGenOwner
5thGenOwner's Avatar
Drives: '10 SS & '15 FRS
Don't fear the paddle shifters! First off, you can't do any real damage to your car using the paddle shifters... it won't let you. You may look like a fool at first, we all do... but you'll catch on quick.
For me, i wish it was more of a manual type shifter... but the paddles are fun to play with.
Although... just puttin' it in M and standing on the gas will do the trick just as easily!
5thGenOwner is offline   Reply With Quote
2011 Camaro. Grinds when shifting from 1st to 2nd under hard acceleration denster V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 153 06-09-2013 03:08 PM
PWA "The Lounge" DGthe3 Off-topic Discussions 143773 11-06-2010 12:00 PM
Imagine If Someone Hit Your Camaro... len56 5th Gen Camaro SS LS LT General Discussions 53 09-03-2009 11:08 AM
Dragoneye’s Birth Day KILLER74Z28 Off-topic Discussions 34 04-15-2008 12:07 AM
Transmissions...? Kenz Camaro 5th Gen Camaro SS LS LT General Discussions 129 11-04-2007 01:08 AM
