HURST
Old 06-23-2011, 12:27 PM   #15
FFPM73
Firefighter/Paramedic
FFPM73's Avatar
Drives: RJT 2SS/RS M6 LS-3
The reservoir is a Holden from a 2004-2006 GTO, any GM dealer can order it for about $20 bucks. 2 2 1/2 pop rivets, 1 brake reservoir plug and the factory line. If you need more line, any auto parts store sells it. Whole project = $25.00 including beer.....
FFPM73
FFPM73 is offline   Reply With Quote
Old 06-23-2011, 11:25 PM   #16
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
ok, easy enough. . . but where do you find the brake rez plugs at?
franknbeans is offline   Reply With Quote
Old 06-23-2011, 11:28 PM   #17
Jason@
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@ Send a message via MSN to Jason@
Anyone know what the "capacity" of this reservoir is? I've got one from an 02 Camaro LS1 T56 car is it looks very similar in size compared to the GTO reservoir.
Jason@ is offline   Reply With Quote
Old 06-23-2011, 11:34 PM   #18
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
not much i think its 2-4 oz
Old 06-24-2011, 05:48 AM   #19
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
I want to caution anyone considering this mod. You MUST USE EPDM (ethylene propylene diene Monomer (M-class) rubber) which a synthetic type of rubber for the cap and hose. It is the same material your brake lines are made of. DO NOT use ordinary gas/oil hose you find at your local parts store. Brake fluid will eat ordinary gas/oil hose. EPDM caps and hose is far more expensive than ordinary gas/oil hose. The hose and caps I use in my kit are EPDM and will last as long as any brake hose in your car.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 06-24-2011, 07:22 AM   #20
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
Ed M.
Thanks Ed! I can't stress the importance of this enough either! This is VERY important, no one wants brake fluid running out all over the car or worse, loosing the braking ability because they used the cheaper rubber plugs and hoses! This is not a project to short cut and save money......
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 06-24-2011, 08:41 AM   #21
faSSt
**Sold n' Sad**
faSSt's Avatar
Drives: 11 F150 Supercrew FX4 5.0
I cannot locate any epdm hose or caps at any auto parts stores here in Arkansas. I've even tried tractor supply company. I usually get a blank stare in return when I ask if they sell epdm.
The only hose I found that says it's made of EPDM rubber is a prestone radiator overflow hose, I called prestone and the guy said I shouldn't use it for brake fluid....maybe he thought I was using it under higher pressure? What do you guys think, can I use this hose? If not, I will need to order from somewhere online.
Are there varying types or grades of epdm, or can I use this radiator overflow hose?
2011 Camaro 2SS, SIM, 6M, HUD, 10% tint, black out lenses, SS emblems, TSP 304 LT's, Roto-Fab, MGW shifter, gto res, 8K BFXENON, HP Tuners, Redline Fluids. ***Sold*** Now in an 11' F150 supercrew FX4.
Still addicted to the this forum
faSSt is offline   Reply With Quote
Old 06-24-2011, 12:18 PM   #22
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
This is the one I used:
https://www.napaonline.com/Catalog/C...282495029&An=0
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 06-24-2011, 03:10 PM   #23
JSC81
JSC81's Avatar
Drives: 2010 1SS/RS M6
I have all the parts to do this, what kind of drill is used to put the holes in the positive battery post? Mines obviously too big...
JSC81 is offline   Reply With Quote
Old 06-24-2011, 05:32 PM   #24
TornadoSS
WICKDSS
TornadoSS's Avatar
I think some of the guys used a 90 degree drill, not real common, I know. I am going out to my car to sort that issue out myself.....Maybe I will try my dremel tool.
Last edited by TornadoSS; 06-25-2011 at 11:08 AM. Reason: Added info in new posting
Old 06-25-2011, 11:07 AM   #25
TornadoSS
WICKDSS
TornadoSS's Avatar
Reservoir completed!
Hi Guys, as promised I have a few pics of my install, which is pretty straight forward and mounted in pretty much the same way as some others here, on the battery post. First though, many thanks to flht99b and 2SSRS for the parts! I used a masking tape template traced from back of reservoir and located the holes to my liking. I opted to start the holes with an 1/8" dremel drill bit. Then I removed the CAI Inc intake and used a reg sized battery drill motor with a 1/4" bit from the front side of the battery post bracket, using the pilot holes for a guide. Everything is pretty much self explanatory from here so just take your time and make sure you have all of your paint protected from the brake fluid! Here's a few pics of my install -
Old 06-25-2011, 11:33 AM   #26
2SSRS@Gen5diy
Look's great, you did a nice job, but don't forget to add the brake fluid,LOL the pics dont show any.
Old 06-25-2011, 01:24 PM   #27
TornadoSS
WICKDSS
TornadoSS's Avatar
I guess I could have added a pic with brake fluid! No worries, the reservoirs were full with nice clean DOT 4! Even though the pics don't look like it, must be the flash from the camera. Thanks!
Old 06-25-2011, 10:25 PM   #28
faSSt
**Sold n' Sad**
faSSt's Avatar
I have the reservoir, and I finally ordered my install kit from Ed. I cannot believe how hard it is to find EPDM at auto parts stores! Can't wait to get me reservoir all set up :-)
clutch dust, gto clutch reservoir, install, separate reservoir
ACT twin disk clutch install by Mike Norris Motorsports ducatisl V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 34 09-06-2016 08:38 PM
t56 clutch fluid reservoir KKJ V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 18 08-26-2012 12:46 PM
looking for a shop to do a clutch install in ny or ct 1 bad azz ls3 Tuning / Diagnostics -- engine and transmission 2 08-19-2010 08:22 PM
Zeta (Camaro/Commodore/G8) suspension details Gatecrasher Wheels and Tires Talk Sponsored by The Tire Rack 66 04-16-2009 02:11 PM
