| Forced Induction - V6 V6 Supercharger, turbo, nitrous discussions |
Thread Tools |
Drives: jealous vendors mad!! HAHA!! Join Date: Jan 2011
Can someone do a NOS install write up
I notice there has been alot of questions lately regarding a nitrous system for our LLT.
Is there anyway someone can do a DIY install write up on a nitrous system? Maybe like the zex kit. I am personally thinking about installing a kit myself since I dont have any plans to install a turbo or a supercharger, but I never installed a nitrous system in any vehicle before. Anyone want to get a DIY going
Back on the dino-juice
Drives: '10 LS + a few more Join Date: May 2010
If anyone tells you to cut into the fuel line don't believe them. Our car has a Schraeder valve at the back. It's pretty much the same install as previous GM EFI cars other than the throttle is a throttle by wire setup. That means there's a sensor that senses how far you've pushed the go-pedal and it will adjust the throttle electrically. The throttle position sensor for this setup gets spliced into the throttle body harness. It only allows the nitrous to be activated at wide open throttle. Some have gone with a window switch, others haven't. I am one of the ones who did. I took my car to the track some last fall and hit the rev-limiter a couple times. How a rev limiter works is it cuts spark until a predetermined rpm. That's just bad for a nitrous car and can cause real bad things to happen. The first thing I did when I got my kit was lay everything out and read the instructions. Then I struck up a conversation with one of the techs at NX and feel if I have any questions in the future I could call them and would be given good advice. Recently I've started talking to a few individuals at nitrousoutlet.com. I'm going to be taking an intake manifold to them to look at to see what they think about plumbing a direct-port fogger to it. I'd like to do a clutch upgrade first, but we'll see. Most of the nitrous companies will make the instructions available to you if you email them and let them know you're considering their kit but would like to read the instructions to see if it's something you could install yourself.
I wake up in the morning and I piss excellence.-Ricky Bobby America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936 |
Account Suspend...Right
Drives: Synergy LS & Vulcan 1600cc Join Date: Apr 2011
Go to the gas station, pay for a bottle, pop the tab and drink it. There you go installed. Took me 2 min the other day. But then I had to drain my fuel line (weiner) after I drank (installed) it.
#4 | |
hahaha good sh#t
CAMARO 2010 V6
INJEN CAI LOUDMOUTH MUFF DELETE ZEX NITROUS KIT REAR WINDOW LOUVER CUSTOM PAINTED RIMS CUSTOM PAINTED CALIPERS WHITE RACING STRIPES METRA KIT INSTALLED PIONEER TOUCH SCREEN DVD 1-12INCH PRIMIER SHALLOW MOUNT SUB 800 WATT SINGLE CHANNEL PIONEER AMP FRONT AND REAR LIGHT BLACK OUT KIT |
#5 | |
![]() Thanks usa1cam |
#6 |
Back to the hunt....
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09 Join Date: Aug 2009
#7 |
did zex ever get their jet size correct?
#8 | |
Doesn't that look a lot easier/simpler than cutting/splicing a fuel line?
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Really Slow Join Date: Apr 2010
My small jets seem to be right on par to their 55shot claim. I'll bump up to 75 at the next dyno with the colder plugs. I'll also get the number jets sizes.
#10 |
added 5hp at least right away
#11 |
![]() Drives: Pontiac Firebird Join Date: Apr 2011
I would be happy to do a write up. Anyone Near Waco, Texas interested in an install?
It will not be about a zex kit ![]() Most of the install is straight forward. Just turning a few wrenches. The wiring and placement of a few components is really all that's a pain. |
#12 | |
I was looking at the zex install on a SS in the newest issue of camaro now and it actually look more simple than installing an amp and woofers, and I can do those with my eyes closed. Do u sell v6 specific kit at NOS outlet? |
#13 |
We have not setup one yet. But we want a TRUE specific. Not just a name and a part number.
We need to get a car in the shop so we can really line it out perfect. We are willing to spend the time to make a Nitrous plate system which we prefer, as it is a better solution than a nozzle, for the v6 car but we have not seen much demand yet. I would love to get some of you guys with us and then the entire scene can have specific and high quality parts. |
#14 |
![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Sep 2009
Guys, the Nitrous Outlet Camaro specific kit is one of if the easiest to install. No splicing any fuel lines as it includes a fuel manifold that installs on the end of the fuel rail where the Test Port(Schrader valve) is. And it includes a TPS extension with a breakout wire so you don't have to cut and splice those wires either. The only wire you have to tap into is for the RPM signal and only if you opt for a window switch(definitely suggested).
I installed one on my brothers Camaro and just recently one on the Silverado. I did a step by step writeup with tons of pics for the Silverado. If you guys want to see it let me know and I will post a link or I can post pics and info here. The install is pretty much the same for both since they are both GM engines at least in the engine compartment. I did not do a complete writeup on the Camaro install but I am sure Graham has a couple useful pics from Dave's install.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock 2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo Last edited by SRT10KLLR; 05-10-2011 at 05:21 PM. Reason: Seeing as this is for the V6 it might be different. |
#15 |
the zex kit for the camaro is super easy to install if you need help let me know. I did the full install on my camaro took me 4 hours to install.
CAMARO 2010 V6
| Thread Tools | |
| Hellion Twin Turbo L99 Install Photos + Results + Reviews | AdamCzap | Forced Induction - V8 | 24 | 10-04-2010 10:19 AM |
| Roto-Fab CAI Install with Pics (5 Stars) | NVMY68SS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 120 | 05-23-2010 01:51 AM |
| DIY: Here it is Dashboard ambient lighting ABL | Tecca | Camaro DIY & HOW-TO instructions & discussions | 356 | 09-03-2009 10:46 AM |
| DIY : Install catback on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 3 | 08-09-2009 04:36 PM |
