| Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires |
Thread Tools |
#251 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS, 2000 Trans Am WS6 Join Date: Jul 2008
Whipplecharged 2010 IOM Camaro 2SS/RS manual trans
Magnacharged 2000 Trans Am WS6 manual trans |
#252 |
Ok kmcd,
I have read the entire thread but kept getting interrupted at work so I just want to do a short summery. You widened the rears to 10.5 and are running a 305 tire correct? Also you had to adjust the break cable and lines not to rub? The rear spacers are for looks and not necessary? The reason I ask is because I want to do this for running at the track. I think like my last girlfriend, the extra inch and a half makes a huge difference lol. But I am not really into putting in spacers and cutting the lug bolts if I don’t have to. Also just an FYI I had JDP Motorsports install Pfadt sub-frame bushings and rear arm package. This helped with wheel hop and gave me 2 – 3 10ths on the stock PZeros. The rear end “plants” a lot better. But I would like to run the 555R or the M/T 3727R. Your thoughts please and thanks. Also I did buy a couple months ago a complete set of stock wheels and tires (brand new) for $1,000. So I do have donor wheels.
Whipple
Comp cam, RotoFab CIA, Kooks 1 7/8 LT Headers, MagnaFlow 3” Comp Series Cat-Back, JDP Tune, Pfadt Sub-Frame mounts, Rear Upper Control Arm Bushings, Rear Arm Package. |
#253 | |
![]() Drives: 2011 JDP Track Spec Camaro Join Date: Jun 2009
You will have to run spacers if you widen the wheels. We have a car with the rears widened and the lugs did not need to be cut. I can get you any information you need. Talk to you soon! ![]() Kind regards, Jordan Priestley 888.308.6007
![]() ![]() AEM | Airaid | Anvil | ARH | BBK | BMR | Brembo | CAI | CSF | COMP Cams | DBA | DSS | ECS | FAST | Forgeline | Gforce | Hawk | Hurst | Hotchkis | Injen | MagnaCharger | Magnaflow | KOOKS | Oracle | Pedders | Pfadt Racing | ProCharger | Roto-Fab | RX | Seibon | SLP | Spohn | Stainless Works | Street Scene | Turn One | Vararam | VMAX | Whipple | + MORE! |
#254 |
My rears are widened to 10.5" with 315's. No spacer. I did get some rubbing while I was autocrossing. No issues on the street.
#255 |
![]() Drives: 2010 Black Camaro 2SS RS Join Date: Jul 2011
Ok so I should be getting my wheels back from Vaughn tomorrow or on monday. I ended up going with widening the fronts to save some $$ and less hassle right now. They are powdercoated black and I got the fronts widened to 10.75 . So I need a 20mm spacer for the rears and what size spacer for the fronts (since I'm moving the rears to the front). I want to have an aggressive stance where the wheel is almost flush with the fender lip. Are the H&R's the best spacers? Do I need to do anything else other than that? I guess I'm gonna have to get my center caps painted black to match since they couldn't powdercoat them.
#256 |
No spacer needed to put the rears on the front.
#257 | |
1,425 hp / supercharged
Drives: (2010 2SS/L99) (1999 Corvette) Join Date: Oct 2009
I haven't looked at this thread for a while. I'm running 315s on the back, not 305s. Like yotaman96, I did get some rubbing at the track, but it wasn't enough to be a concern. Now I'm running 20mm Eibach spacers all around, but they're mainly for aesthetics. I suspect that if you run 305s, you won't have any rubbing issues at all.
"If it's too loud...well, you know the rest."
#258 |
So no need for spacers on the front if i stick the rears on the front. And a 20mm spacer on the rear? What tires should I get for street? I'm thinking a 305? Are the H&R spacers good? Do i need to cut the lugs too?
#259 |
American Muscle
Drives: 2010 Camaro 2SS/RS LS3 M6 Join Date: May 2010
Has anyone widened the rear wheels from the outside of the wheels (meaning an increased offset or deep dish look)? So far, I have seen two threads of people widening the stock wheels on the inside. Thanks!
2010 2SS/RS LS3 Blk/Blk with Cyber Gray Metallic stripes and sunroof.
Mods: Cold Air Inductions, MTI, Kooks, Borla, Ported and polished TB, Custom Dyno Tune, NGK, Hypertech, PFADT, BMR, DSS, JRE, Hurst, SLP, black out bowties. GM sure did their homework on the new camaro! I just wish it had better visibility...![]() "HP sells cars, Torque wins races." -Shelby "There is no replacement for displacement." |
#260 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS M6 Join Date: May 2011
#261 |
Banned
ps...i have stock 20's for slae ...sorry, dont mean to thread jack
#262 |
Ok I need some help! I got my fronts widened from Eric Vaughn to 10.75 and today I went to a local wheel shop and it was a disaster. I was trying to get the do the fitment with spacers etc and things just didn't quite work out as planned. Anybody know anyone I can take it to in the Bay Area to get the spacers etc done? They were saying I'd need like a 47mm wheel adapter to get it to clear. I was under the impression I could use a 20mm hubcentric spacer?
#263 |
Since you widened the fronts and they have a different offset than the rears, I believe you need a 1" spacer. You will also need to modify the emergency brake cable routing.
#264 | |
***GO HOGS GO***
Drives: 68/327 & 10 2SS SIM w/ CGM Stripes Join Date: Jun 2010
Halltech, VMax, BBK Headers & X-Pipe, Solo Cats, BMR Level 2 Suspension, CCW SP16a Wheels 10"/11.5", 1LE 3.91's, JRE Tune
Halltech CAI, VMax TB, BBK Headers, Solo Performance H/F Cats, BBK X Pipe, Muffler Delete, BMR Suspension, 1LE 3.91 Gears, Heritage Grille, CCW SP16a Wheels 10"/11.5" Nitto 275/40 315/35, Painted Calipers, Blackout: Bowtie, Rear Panel, Markers & Side Vents, SS Fender Badges, 6.2L Cowl Lettering, RPI SS Door Kick Plates, Billet Cup Holder, Fesler Shift Boot, Lloyd Floor Mats..(1/4: 13.017 @ 108.63) |
#265 |
Damn conflicting info here haha! So you have 25mm adapters on 11" widened fronts? I have 10 3/4 widened wheels. So you're saying 20mm? Should I call ADM or?
#266 |
25mm is almost an inch. If you look back at threads he started, he says his wheels were widened to 10.8".
#267 |
Ok cool so I talked to ADM and they have the spacers I need. Gonna order them today. Should I stick with the Pirelli P-Zero's? They're expensive but seems weird to have 2 different sets of tires if I get something else.
#268 | |
By the way, I'm running 20mm hubcentrics (rear stockers widened to 10.5" / 315 INVOs), and have plenty of clearance.
#269 |
#270 |
FYI, since moving the rear wheels and tires to the front, I have had some rubbing. I never felt it rub, so I'm guessing it happened while autocrossing.
#271 |
#272 |
I'm thinking of adding a small spacer. It shouldn't be an issue unless you drive aggressively. I also have Pfadt lowering springs.
#273 |
#274 |
Post 243 shows my pics.
#275 | |
We're both running rear stockers (widened to 10.5 / 315s) on the back. I'm running mine with 20mm spacers. His are flush on the hub. The 20mm spacers bring all four corners to just about flush with the fenders on my setup, but his fronts are an inch wider and are more concave because of the slight difference in offset between the front and rear stockers. Clear as mud, isn't it?
| Thread Tools | |
| Pics of Customized STOCK wheels? | DieselDork | Wheels and Tires Talk Sponsored by The Tire Rack | 5 | 04-20-2011 10:51 AM |
| stock wheels widening? | Capthowdy | Wheels / Tires | 3 | 10-15-2010 09:12 PM |
| My wheel comparison: stock 20's vs. stock (1LT) aluminum 18's: A writeup | ALLTRBO | Suspension / Brakes / Chassis | 12 | 05-11-2010 09:34 AM |
| Widening back of stock SS rear wheels | flht99b | Wheels and Tires Talk Sponsored by The Tire Rack | 3 | 05-11-2010 08:54 AM |
| SLP 2010 Camaro ZL575 supercharged -- unique aero parts & "SS" on grill | nUcLeArEnVoY | Camaro Photos | Spyshots | Video | Media Gallery | 129 | 04-22-2010 02:59 PM |
