Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires
Old 08-02-2011, 08:32 AM   #201
kmcd
1,425 hp / supercharged
kmcd's Avatar
Drives: (2010 2SS/L99) (1999 Corvette)
Originally Posted by yotaman96 View Post
I think this will probably look the best. I believe the word you were looking for is stance, not rake.
You could get your stock fronts narrowed and run them as skinnies at the strip.
It's only money, you can always make more.
I stand corrected. We're wider in the back, not taller.
I'm still a little hesitant to scale back to the 15-mm adapters because I don't like the idea of cutting threads off the studs. I'd still like the option to take them off for the drag strip. Maybe I'm just being too anal about it though. With the way that adapter is made and the way it fits, I doubt the structural integrity of the hub/wheel assembly has been compromised. I should probably just commit to them and be done with it.
"If it's too loud...well, you know the rest."
kmcd is offline   Reply With Quote
Old 08-02-2011, 08:35 AM   #202
kmcd
kmcd's Avatar
Originally Posted by bkscott View Post
You could also get another set of adapters for the front, and move them out to match the rears.
There is a guy in Germany running adapters on all 4 wheels. Looks good.
Pictures?
Maybe I could do this until I need new tires again. It shouldn't take too long.
Old 08-02-2011, 10:21 AM   #203
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Give me a few.
Here you go. Hopefully I won't get into trouble for linking to another site. Those are the stock wheels on H&R 20mm adapters on stock wheels and tires.
http://www.moderncamaro.com/forum/5t...lack-rims.html
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, Hotchkis Max Chassis Brace, BC Racing Coilovers, Hotchkis Sway Bars, Whiteline Cradle Bushings,Forgestar F14's 20x9/11,Nitto Invos.
bkscott is offline   Reply With Quote
Old 08-03-2011, 01:57 PM   #204
STARSKI
Drives: 2010 Black Camaro 2SS RS
So you guys all think I'm better off putting a set of rears on the front? Instead of widening the fronts?
STARSKI is offline   Reply With Quote
Old 08-03-2011, 02:06 PM   #205
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
You could buy two wheels cheaper than what it costs to widen them.
Whipplecharged 2010 IOM Camaro 2SS/RS manual trans
Magnacharged 2000 Trans Am WS6 manual trans
yotaman96 is offline   Reply With Quote
Old 08-03-2011, 03:52 PM   #206
kmcd
kmcd's Avatar
Yep. The only reason we widened the rears is because you can't buy 10.5-inch stockers. You can buy 9-inch stockers for the front, and because of the net difference in width minus offset, you'll gain a little outboard movement as a bonus.
Old 08-03-2011, 07:39 PM   #207
STARSKI
Ok but I already bought a full set of wheels. Not just 2. I have 2 full sets. One of them I powdercoated front and backs already. So I was just going to send all them to get widened. If not I'm gonna end up with 4 fronts that are mix match unless I powdercoat the rest of the wheels I have.
Old 08-03-2011, 09:38 PM   #208
kmcd
kmcd's Avatar
Well, now that you've explained your dilemma,
Old 08-04-2011, 05:19 PM   #209
STARSKI
So you guys think I can widen the fronts to 9.5 and put a spacer on them? And widen the rears to 10.8 or 11?
Old 08-04-2011, 05:44 PM   #210
kmcd
kmcd's Avatar
The fronts will work. If you go past 10.5 on the rears, you'll need spacers on the back too.
Old 08-07-2011, 03:25 PM   #211
CosmicBrut
CosmicBrut's Avatar
Drives: 2011 CGM 2SS/RS L99
I just put a set of widened wheels on my 2011 SS. They are the stock 20x9 wheels widened to 20x10.5. This is my setup for the track so I put nitto nt05r 315/35/20s on them. The car is lowered 1.25 " with pdaft drop springs and the wheels clear everything even though the car is lowered. They miss the inner wheel well by a little more then half an inch with no spacers. I drove them around quite a bit and they dont rub at all so i guess they are good to go. Just figured id post this to help anyone else out who has lowered their car and is worried about clearance issues. Hope this helps.
2011 SS/RS A6
TSP 229/236, TSP ported heads, FAST 102 intake, Vmax ported throttle body, Circle D 3200 stall, CAI cold air intake, Kooks complete system, installed and tuned by ECS 11.36@121
CosmicBrut is offline   Reply With Quote
Old 08-08-2011, 09:44 PM   #212
STARSKI
So what did you do on your front wheels?
Old 08-09-2011, 11:18 PM   #213
PoleCat2SSRS2010
R6P Marketing Lab Rat
PoleCat2SSRS2010's Avatar
Drives: 2010 2SSRS for weekends mostly
How is the traction difference with the 20 inch Nittos compared to the Pirellis? Your sig shows a stall and a cam so it must be minimal with the p zeros compared to the Nittos.
PoleCat2SSRS2010 is offline   Reply With Quote
Old 08-10-2011, 06:37 PM   #214
CosmicBrut
CosmicBrut's Avatar
I left the stock 245s on the front
2011 SS/RS A6
Old 08-10-2011, 06:38 PM   #215
CosmicBrut
CosmicBrut's Avatar
The traction difference is huge just with the burnout. The nto5rs barely wanted to even spin, compared to the stockers that spin on demand.
2011 SS/RS A6
Old 08-11-2011, 03:57 PM   #216
kmcd
kmcd's Avatar
Old 08-13-2011, 02:58 PM   #217
kmcd
kmcd's Avatar
Sticking out too much with the 8" wheels up front.
Originally Posted by kmcd View Post
Yeah, I was afraid of that. I could go with the 15-mm spacer, but I'm pretty sure I'd have to sacrifice some threads on the stock studs.
What if I put another set of 9-inch OEM rears on the front with 275 INVOs? Isn't that what you're doing?
I went ahead and moved the 8-inch/245 fronts out by 20 mm until I need new tires, at which time I'll put 9-inch stockers up front with 275s.
Does this look any better?
Old 08-13-2011, 06:08 PM   #218
yotaman96
yotaman96's Avatar
That looks a lot better. Are the spacers in the back still 20mm?
Old 08-13-2011, 06:54 PM   #219
kmcd
kmcd's Avatar
Yep. Twenty millimeters on all four corners now. This way I didn't lose any threads on the stock studs, so I still have the option to take them off when I go to the track.
If I had it to do over again, though, I'd put rear stockers up front like you're doing. The 275 INVOs would look good up there (when are we going to see your pics?).
Oh well, I'll need new tires eventually.
Old 08-13-2011, 07:18 PM   #220
yotaman96
yotaman96's Avatar
Nitto just did a production run on the 315/35/20 Invos and are sending them to people on the emergency list. I'm on that list now and should have the tires in my possession hopefully Friday.
Old 08-14-2011, 04:52 PM   #221
bkscott
bkscott's Avatar
Any change in steering feel or response with the adapters up front?
Old 08-14-2011, 09:34 PM   #222
kmcd
kmcd's Avatar
I know the wider track is supposed to enhance the handling characteristics, but I can't tell any difference. I'm gonna' check the adapters here in a few days, and I'll let you know if they require any re-torque.
Actually, I did notice one change, and it's going to sound goofy, but the brakes are quieter now. Don't ask me why. Maybe the harmonics changed on the wheel/hub assembly.
Old 08-14-2011, 10:22 PM   #223
bkscott
bkscott's Avatar
I get my tires next week, and I will drop the wheels off the Monday after that. btw Ramiro is no longer working there. Don't know why.
Old 08-15-2011, 10:27 PM   #224
Rogan
No Pain No Gain
Rogan's Avatar
Drives: Yellow 5th Gen 2SS RS
i didnt read the entire thread but i am assuming you had your widened at weldcraft? what was the turn around?
Rogan is online now   Reply With Quote
Old 08-15-2011, 11:19 PM   #225
bkscott
bkscott's Avatar
He had them widened at Wheels America here in Dallas Texas. That is where I am taking mine.
Pics of Customized STOCK wheels? DieselDork Wheels and Tires Talk Sponsored by The Tire Rack 5 04-20-2011 10:51 AM
stock wheels widening? Capthowdy Wheels / Tires 3 10-15-2010 09:12 PM
My wheel comparison: stock 20's vs. stock (1LT) aluminum 18's: A writeup ALLTRBO Suspension / Brakes / Chassis 12 05-11-2010 09:34 AM
Widening back of stock SS rear wheels flht99b Wheels and Tires Talk Sponsored by The Tire Rack 3 05-11-2010 08:54 AM
SLP 2010 Camaro ZL575 supercharged -- unique aero parts & "SS" on grill nUcLeArEnVoY Camaro Photos | Spyshots | Video | Media Gallery 129 04-22-2010 02:59 PM
