BeckyD @ James Martin Chevy
Old 05-09-2011, 12:52 PM   #1
SIN R G
SIN R G's Avatar
Drives: 2008 VW R32, 2011 Synergy Green 2SS
Clay Bar - My First Time
I have never used Clay Bar before and am getting ready to do it for the first time. I know you don't use it on the vinly stripes, but do you do the front and read rubber bumpers?
2SS L99, CAI, Kooks Stainless 1 7/8 headers, Kooks Catted Oem Connection Pipe, MBRP Exhaust, MSD LS1 Superconductor 8.5 mm Wires. NKG Copper Spark Plug Set, Full Dyno Tune. BMR G8Trailing Arms - Hammertone and BMR Rear Toe Rods, GFX, Devils Tail Side Stripes, Side Vent Stripes, Synergy Green Door Panels and SS Grill & Trunk Badges .
SIN R G is offline   Reply With Quote
Old 05-09-2011, 12:56 PM   #2
DJBullitz
DJBullitz's Avatar
Drives: 2011 Camaro 2SS
Yes you can use it on the bumpers. Check out Adams as sponser here and they will have a video.
DJBullitz is offline   Reply With Quote
Old 05-09-2011, 01:00 PM   #3
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
What rubber bumpers are you talking about? Are you talking about the rear diffuser (the flat black part)? If so, then no, don't do that. Do anything that is painted.
Oh- and don't forget the glass.
[B]
Old 05-09-2011, 01:18 PM   #4
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '17 Corvette Z51 Coupe
anything that is PAINTED......that is what you clay.
Old 05-09-2011, 01:58 PM   #5
vinman
The BBOMG fill-in husband
vinman's Avatar
Glass too?
UPSTATE C5 MEMBER
Old 05-09-2011, 02:01 PM   #6
Uncle Harvey
Uncle Harvey's Avatar
Drives: 2011 2SS RS
Yep. Do the glass. You will need a lot of detail spray so be prepared.
Uncle Harvey is offline   Reply With Quote
Old 05-09-2011, 02:58 PM   #7
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Originally Posted by vinman View Post
Glass too?
Absolutely! Whatever contamination is stuck to your paint is stuck to your glass too. You'll be amazed at how much clearer your glass will be after claying. So many times the things you thought were minor pits and stuff turn out to be contaminants stuck to the surface.
Old 05-09-2011, 03:38 PM   #8
SIN R G
SIN R G's Avatar
Wow, I kind of thought I should do everything that was painted, but I sure would not have done the glass also. I just had the GFX package painted and installed a few weeks ago. Can the new paint be clayed now, or should I wait a little bit before I do that.
Old 05-09-2011, 09:43 PM   #9
Rookie50
Rookie50's Avatar
Drives: 2011 SS RS Black
If you have original factory paint it is ok to clay now, however if you recently had your car painted at a local shop you should wait.
Rookie50 is offline   Reply With Quote
Tips for first time Manual Transmission Drivers from a new Camaro Owner (First post) LoneCynic 5th Gen Camaro SS LS LT General Discussions 45 04-03-2016 03:46 AM
THANK YOU CLAY BAR!!! sask-man Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 27 10-04-2010 07:35 PM
Clay bar a clear bra? My 5th Cosmetics and Lighting Modification Discussions 3 05-06-2010 03:15 AM
Claybar Cleaner and Extender Angelo@Autopia Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 15 02-02-2010 12:37 PM
All About the Clay Bar Process Junkman2008 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 0 01-11-2010 11:22 AM
