Emblempros
Old 05-09-2011, 04:29 PM   #1
Katech
Drives: C6 Z06
Katech independently tests FAST LSXR LS3 manifold vs two ported LS3 manifolds
Last week we conducted a test of two different ported LS3 intake manifolds and a FAST LSXR 102mm intake. The test subject was a 6.2L LS3 with the following:
-Katech Torquer LS3 cam
-Springs, retainers, pushrods
-WCCH ported heads
-C5-R timing chain
-Katech ported oil pump
Tests are as follows:
C2-9336 - stock baseline 530hp/477ft-lbs
C2-9344 - brand Y ported LS3 intake 529hp/474ft-lbs
C2-9348 - brand X ported LS3 intake 527hp/470ft-lbs
C2-9345 - FAST LSXR 102mm intake manifold 538hp/484ft-lbs
Zoomed:
As you can see both the ported manifolds lost power and the LSXR was the only one with a gain. These intakes were shown on the chassis dyno to make power so it just goes to show that the chassis dyno is not a good place to do precise A-B testing, and every tuner that ports manifolds will do what they can to make the product look good when testing. When you take that product to the controlled conditions of the engine dyno and take out all the variables, you see that you have actually lost power. This is a fairly mild LS3 engine and we can only guess that the more modified the engine is, the more it would benefit from the FAST manifold. Whether the gain on a stock or mildly modified engine is worth it to you, only you can decide.
Katech is offline   Reply With Quote
Old 05-09-2011, 04:39 PM   #2
Jason7
NorCalCamaros.com
Jason7's Avatar
Drives: 2010 2SS White
Reminds me of the ported heads and even aftermarket heads versus stock. Tons of money and the benefits aren't that large.
Thanks for this test!
Jason
Jason7 is offline   Reply With Quote
Old 05-09-2011, 06:58 PM   #3
Dexgto
Drives: 2009 Pontiac G8
Now thats some interesting results not what i thought they were gonna be.
Dexgto is offline   Reply With Quote
Old 05-10-2011, 07:20 AM   #4
Halltech
Drives: 2010 Halltech Camaro SS, 2008 C6Z06
You forgot to mention the intake system used for the baseline 530 HP. Can you clarify what stock meant? I know, but others may not.
Halltech is offline   Reply With Quote
Old 05-10-2011, 08:09 AM   #5
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
What size Throttle Body? Was the FAST 102 matched to a 102 TB?
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 05-10-2011, 08:32 AM   #6
Katech
Drives: C6 Z06
I was referring to the stock intake manifold. The air intake system for each test was the Halltech Bumblebee carbon fiber Camaro intake system.
Old 05-10-2011, 08:32 AM   #7
Katech
Drives: C6 Z06
Padre
Throttle body was 90mm. Plenty for a mild 6.2L.
Old 05-10-2011, 09:00 AM   #8
Padre
Padre's Avatar
Thanks for the response. Wasn't the FAST 102 built for a 102 TB? If so, what gains are to be had? And if few on a "mild" setup, when do you start to see the benefits of a 102 TB? It just seems like 90 TB on a 102 FAST is a restriction.
Thanks, Padre
Old 05-10-2011, 09:14 AM   #9
Katech
Drives: C6 Z06
Thanks, Padre
It can take a 90-105mm throttle body. We tested 90 vs. 102 on a 600hp LS7 and it was about 5hp. On a 530hp 6.2L it's not going to be throttle body-limited with 90mm.
Old 05-20-2011, 11:58 AM   #10
2010SSRSM6
2010SSRSM6's Avatar
If you have a TT setup pumping into the FAST intake, would it be worth the extra $$$ to step up the the larger TB?
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Engine Dyno Testing LS3 Intakes INSIDE!! LS3 vs Ported vs FAST Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 10-01-2009 01:55 PM
FAST LS3 102mm Intake Manifolds IN STOCK @ VENGEANCE RACING!!! Ron@Vengeance V8 Bolt-Ons & Tunes 4 09-23-2009 11:31 AM
FAST LSXrt (LSXr race manifold) sneak peek HaveBlue Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 09-18-2009 11:43 AM
FAST LSXR Update: manifold, throttle body, race block HaveBlue Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 06-29-2009 07:22 PM
