Cold Air Inductions
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Southeast > Local Marketplace
Old 05-09-2011, 10:06 PM   #1
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Corvette Camaro GTO CTS Tuner in Tampa Orlando Bradenton
www.TampaTuning.com
Tampa Tuning specializes in high performance custom computer reprogramming of General Motors powered LS & LT 1 through 9 powered muscle cars and trucks. Our high standard for customer service guarantees you’ll love the performance gains. Tampa Tuning will design a customized remapping of your vehicle’s computer (PCM) for optimal efficiency. Our tuner has 12 years of tuning experience and has also been trained at the basic and advanced tuning schools which specialize in dyno tuning General Motors equipped vehicles with HP tuners software. He is also a guest instructor at The Tuning School. We calibrate in South Tampa about 3 miles from MacDill Air force Base and in St. Petersburg, Florida.
We use the most powerful updated version of HP Tuners software which unleashes the horsepower and torque for an assortment of General Motors vehicles. Our computer enhancements will make your motor more efficient. Tampa Tuning specializes in the following high performance cars and heavy duty trucks for tuning:
1997-2014 Chevrolet Corvette C5, C6, C7 including ZR1,Grand Sport, Z06s
1998-2014 Chevrolet Camaros Generation 4 and 5 Z28, SS, RS, ZL1
2002-2014 Cadillac CTS, STS, XLR, SRX, DTS, Escalade
2000-2014 Avalanche, Hummer, Tahoe, Suburban, Yukon, Silverado V8s
1998-2002 Pontiac Firebird, WS6, Trans Am, Firehawk
2003-2006 Chevrolet SSR 5.3
2004-2006 Pontiac GTO
2014 Chevy SS
Our total street performance tuning package for $290.00 will include:
- Read and reprogram your PCMs settings and perform real time scanning diagnostics for the best results
- fine tune and dial in your MAF and VE table
- Increase power enrichment rate mode
- Examine and change timing tables for additional horsepower & torque gain
- Optimize your vehicles Air and Fuel Ratio monitored by the NGK/AFK wideband unit
- Reduction of intake air temperature table (heat soak)
- Desired rev limiter adjustments
- Park, neutral, and in- gear idle adjustments with and without A/C active
- Adjust power enrichment delay to immediate (*Transmission Performance*)
- Engine torque management system reduced (*Transmission Performance*)
- Transmission torque management system reduced (*Transmission Performance*)
- Transmission shift points enhanced (*Transmission Performance*)
- Transmission shift times reduced (*Transmission Performance*)
- Transmission shift pressure firmness enhanced (*Transmission Performance*)
- Skip shift deleted (CAGs 1st to 4th shift) (*Transmission Performance*)
- Fuel injector rescaling for aftermarket injectors
- Cooling fan activation temperature recalculated
- Perform speedometer recalibration for rear gear ratio and tire size change
- Turn off check engine light and remove trouble codes as needed
- Neutralize rear oxygen sensors if needed
*Transmission performance package for $170.00
Tampa Tuning recognizes that the A4 and A6 automatic transmission owners just want their sloppy, slow shifting and sluggish transmissions tuned for a performance feel. For those owners, we designed a transmission only tuning package. We will reduce your vehicles engine and transmission torque management system and re-flash only transmission settings indicated above by *Transmission performance* notation. This will be a very noticeable change in your vehicles performance!
Torque management reduction tune for $100.00
For the drivers that just want a noticeable change in your vehicles performance, and are tired of the 1st to 4th CAGs skip shift, Tampa Tuning will reduce your vehicle’s engine and transmission torque management system and neutralize your CAGs. You will be surprised and pleased with the torque management tune. Many drivers who use their vehicle daily say just turning off the CAGs are worth the price and the extra seat of the pants torque is a bonus.
Email order tunes for $150.00
If you own or have access to HP Tuners software, you can Email your stock .BIN file to Tampa Tuning where it will be reviewed and properly enhanced for a “Email order” tune. Your tune will be enhanced by using HP Tuner tables from our library of modified configurations which have a very similar set up as your make and model vehicle.
For dyno tuning and some vehicles please add $100 to the above pricing.
Contact our tuning team at: Tuning@TampaTuning.com for your tuning needs questions.
Your Corvette, Camaro, GTO, CTS Cadillac, GM Truck Tuner in Tampa Orlando Bradenton
Thanks
Phil
Tampa Tuning is offline
Old 05-09-2011, 10:14 PM   #2
Snake Slayer
Snake Slayer's Avatar
Drives: Awaiting 2014 C7
Originally Posted by Tampa Tuning View Post
www.TampaTuning.com
Tampa Tuning specializes in high performance custom computer reprogramming of General Motors powered LS 1 through 9 powered muscle cars and trucks. Our high standard for customer service guarantees you’ll love the performance gains. Tampa Tuning will design a customized remapping of your vehicle’s computer (PCM) for optimal efficiency. Our tuner has nearly 8 years of tuning experience and has been trained at the basic and advanced tuning schools which specialize in dyno tuning General Motors equipped vehicles with HP tuners software. We are located in South Tampa about 3 miles from MacDill Air force Base.
1997-2011 Chevrolet Corvette C5 & C6 including ZR1,Grand Sport, Z06s
1998-2011 Chevrolet Camaros Generation 4 and 5 Z28, SS, RS
2002-2011 Cadillac CTS, STS, XLR, SRX, DTS, Escalade
2000-2011 Avalanche, Hummer, Tahoe, Suburban, Yukon, Silverado V8s
2003-2004 Chevrolet SSR 5.3
Our total street performance tuning package for $245.00 will include:
LM-1 wideband unit
*Transmission performance package for $150.00
Torque management reduction tune for $75.00
Email order tunes for $110.00
Thanks
Phil
And even better customer service. For those of you that have never met Phil let me tell you this is his passion. He will go above and beyond to insure that you are happy with the final results.
Awaiting 2014 C7
Snake Slayer is offline
Old 05-10-2011, 08:44 PM   #3
Ucantctchme
Ucantctchme's Avatar
Drives: 2010 ss. 1990 RS the faster one.
I'm with this guy^^!
Ucantctchme is offline
Old 05-10-2011, 11:12 PM   #4
NateSS
1337 AH64D driver
NateSS's Avatar
Drives: 2010 Camaro 2SS/RS L99
worth driving 6 hours from alabama to get a dyno tune from them?
Cam/Heads by ARD, Tune by G-Force, Transmission/Gears by Circle D
NateSS is offline
Old 05-10-2011, 11:34 PM   #5
jmack71
Emerald Coast Camaros
Drives: 2011 2SS/RS RJT 'Vert
+1 for NateSS's question, haha.
Mods Done: NONE (sadly)
Future Mods: CAI & Muffler Delete
Emerald Coast Camaros Forum!
jmack71 is offline
Old 05-11-2011, 04:39 PM   #6
Tampa Tuning
Id be honored, and not many tuners would say this and chase away business, but I would hope someone would be closer than 6 hours away.
Old 05-11-2011, 11:47 PM   #7
Johnblaze
Johnblaze's Avatar
Drives: 2010 Camaro LS V-6
Tampa Tuning...
is there anything that can be done with a 10 camaro v-6.. as far as tuning?
thanks
Johnblaze is offline
Old 05-13-2011, 07:09 AM   #8
Tampa Tuning
www.TampaTuning.com
Currently, HP Tuners platform does not support the Gen 5 2010-2011 V6s. Ive been pressuring them for a realease with no results. As of 12/01/2013, HP Tuners supports the LFX V6 engine
Old 01-26-2013, 05:30 PM   #9
z28chuck
z28chuck's Avatar
Drives: 2010 Inferno Orange 2SS/RS Camaro
"Prices are still the best"...not quite; had my car tuned on the dyno for just over what you charge for a dyno run...by one of the best tuners around. Please dont take that as an insult, I have heard great things about Phil and Tampa Tuning...I am just saying that the pricing is not the best around.
z28chuck is offline
Old 01-26-2013, 05:59 PM   #10
zkdreads
zkdreads's Avatar
Drives: 2010 Camaro LS V6
ok soooo you paid MORE then whats he listed. isnt that proving his point..IJS
C-LO or Sonic
"Without Struggle there is no progress"
I am your best nightmare!
zkdreads is offline
Old 06-18-2013, 10:43 PM   #11
Tampa Tuning
Like us on Facebook !
For the best vehicle calibration prices, reach out for Tampa Tuning.
Please allow three hours for your dyno session alone.
Recently several vehicles "tuned" at a shop that was running an October dyno tune special price came to us for re calibration because the vehicle was not running to expectation. If your tuner spent a half hour on your car, you got ripped off.
The newest sponsor Tampa Tuning for Camaro Corvette GTO Firebird Trans Am Truck tuner Tampa Tuning USA - Southeast 17 02-08-2011 07:33 AM
Best priced Camaro Corvette GTO tuner in tampa fan mail Tampa Tuning USA - Southeast 0 01-25-2011 09:24 PM
