r1concepts
V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment Intake, exhaust, tunes, other bolt-ons for V8 Camaros
Old 05-09-2011, 09:12 PM   #1
forplay
forplay's Avatar
Drives: 2011 2SS/RS LS3
LS9 Injectors
SOLD SOLD SOLD SOLD...
I have a set of 8 injectors I took off my maggie kit to go bigger they are GM#0280158187... they have about 200 miles on them ..like new..$300.00 shipped obo
These Genuine Bosch injectors at 43.5 psi (3 BAR) flow 48.9 lbs/hr or at 58 psi (4 BAR) they flow 56.4 lbs/hr. In addition, these units are high-impedance. Despite the high flow rate, they are linear and controllable at low pulse widths and have been used in ULEV applications! This allows you to use a larger injector than normally possible without hurting idle and low speed driveability. Adding to the flexibility of application, these units are high-impedance; making them compatible with most ECUs, while delivering the most flow available in a High-Impedance injector. These injectors represent the most current Bosch engineering and are used on many high power turbo and supercharged oem applications including the GM LS9 engine.
2011 SS/RS M6 Synergy green 559RWHP...530RWTQ
Mods: Maggie supercharger...LS9X Twin disk clutch..85lb Fast inj..ZL1 Fuel pump..,MSD BAP..Roto-Fab cold air..Hotchkis max chassis brace, strut brace,, sway bars front and rear ,HD end links.adj toe link,lower control arm,,trailing arm,, Norris catch can..XS Power 1 7/8 ss lt headers..3" cat delete..3"X pipe..XS 3" mufflers. Hurst shifter.. Lowering springs..22" Foose wheels. Boost/vac ..Fuel pressure gauge..GPS stereo Head unit, all speakers and amp 4 10" subs..Ram air hood.heat extractors .Custom leather interior.Escort 9500ci..
forplay is offline   Reply With Quote
Old 05-11-2011, 08:03 AM   #2
forplay
forplay's Avatar
bump
Old 05-29-2011, 10:06 PM   #3
ShaneH
Drives: 09 pontiac g8
still have? i want!
Procharged G8 -10.55@134.3 1.60
ShaneH is offline   Reply With Quote
Old 05-30-2011, 07:47 AM   #4
forplay
forplay's Avatar
yes I still got them... ready to ship..
Old 05-30-2011, 09:12 PM   #5
forplay
forplay's Avatar
SOLD!!
Old 06-05-2011, 03:36 PM   #6
ShaneH
Got them in the car yesterday thanks again!
Bosh LS9 ZR1 56lb injectors g4dadon Forced Induction 4 02-21-2011 06:42 AM
Why wait for the Z, LS9 TVS2300 available now R6P Camaro ZL1 Forum - ZL1 Specific Topics 36 11-30-2010 04:26 PM
LS9 Injectors new Paul4137 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 2 11-17-2010 10:16 PM
What horsepower will the LS9 injectors support at 58 psi? 99-LS1-SS Forced Induction - V8 2 05-24-2010 12:27 PM
WTB: LS9 injectors DSteck V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 2 05-20-2010 01:52 PM
