Solo Performance
Old 05-10-2011, 10:52 AM   #1
B52bomb
B52bomb
Drives: 2011 Synergy Green 2SS
First Scratch on Front Bumper - HELP
Decided to drive in to work this morning (Boston) and normally never park where there is a curb as to avoid hitting front bumper. Whelp.....didn't take my own damn advice and just barely hit curb..and I mean BARELY. Now front passenger side bumper has a nice deep scratch (to black plastic and about 3 inches). So I need your help and advice. Do I attempt to touch up myself or take to dealership and have them fix? I can take road rash, but this one really has me bent. My own damn fault! Thanks in advance for the advice! 2011 Synergy Green SS by the way.
B52bomb is offline   Reply With Quote
Old 05-10-2011, 10:56 AM   #2
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
If you cut down to the plastic, you're already past the paint and primer. I'd go to a paint shop and have them look at it before attempting a home repair that could make it worse. Respraying a front end is around $300 just in case you're wondering.
TheHorse13 is offline   Reply With Quote
Old 05-10-2011, 11:23 AM   #3
nancygrl
銀幽霊
nancygrl's Avatar
Drives: '17 Z71 Truck
On a different note...You got your first one out of the way, it gets a little easier from that point
Previous rides: '17 ZL1 M6,'16 2SS/A8, '15 1SS/1LE/M6, '13 Hotwheels RS, '11 2SS/M6
nancygrl is offline   Reply With Quote
Old 05-10-2011, 11:27 AM   #4
Pollock
LT1 M6
Pollock's Avatar
Drives: 2018 1SS/1LE
I would have a body shop fix it but that is because I suck at body work.
You could buy touch up paint. I am sure it will only last for a couple months.
Pollock is offline   Reply With Quote
Old 05-10-2011, 11:36 AM   #5
kiteman
Drives: 2012 45th Camaro, 2SS/M6
what color is the car? dark is worse. a picture would be good, but generally if you can run your fingernail across it and you feel it, it's deep enough to not be buffed out. if it's down to the plastic, touch-up paint plus light wet-sanding plus a machine polish will make it basically impossible to notice if it is indeed as small as you imply. i think wet-sanding is really easy, but if you don't know how to do it don't even try. most people freak out when they wet-sand and it mars the paint badly and don't have the patience to buff out the scratches left from the sandpaper, or keep going with the sandpaper expecting to make it look better and then wind up going through the paint coats altogether. a shop shouldn't charge you much, but probably $100 or so. way too much IMO, but it will make it look the closest to perfect as you can get without repainting the entire bumper.
or you can just put the touch-up paint on as delicately as you can and not wet-sand, and it will look OK. a lot of times if you aren't going to wet-sand, then touch-up paint only makes it look more obvious.
kiteman is offline   Reply With Quote
Old 05-10-2011, 04:31 PM   #6
Kwik
Drives: car
That will cost you about $400. I fixed mine the first time. I gave up after that. LOL!! I guess the car is just too low. Good luck.
Upgrades to suspension, brakes, motor and appearance. 482.7 RWHP- 434.2 RWT - All motor.
Kwik is offline   Reply With Quote
Old 05-10-2011, 05:27 PM   #7
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
If you're down into the plastic (which it sounds like you are) this is gonna be a bodyshop type job in all likelihood.
Old 05-10-2011, 10:16 PM   #8
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Been there...twice
Costs about $400 to have repaired. You cannot do it yourself. I haven't even bothered repairing the second one at this point. It's so low, you can't see it unless you're under the car. I'm gonna wait til the rock chips are super bad and just redo the whole thing.
[B]
Old 05-10-2011, 10:50 PM   #9
Cbrenthus
Drives: 2011 VR 1SS
Just gave mine it's first ouchie last night! Down by the front fog, I hit it with my dirt bike foot peg :(. Scraped the paint down to the plastic, but it is only about the size of a bug! I masked off around, wrapped some 1000 grit around a pencil eraser, scuffed and painted. It is very noticeable up close, but not from 5 feet.
My advice that I am following is to touch it up a bit but leave it. I supersticiously believe that all cars are going to have something, and if you have something that small and out of the way fixed, then something worse will happen!
Cbrenthus is offline   Reply With Quote
SS bumper cover installed on my 2LT/RS 01pewterz28 Cosmetics and Lighting Modification Discussions 60 01-15-2015 04:57 PM
Shipping Weight/dimensions of front bumper cover? danrc28 5th Gen Camaro SS LS LT General Discussions 21 08-12-2013 08:21 PM
Synergy front bumper, grills, and headlights. torranosaurus Exterior Parts & Accessories 4 06-08-2011 03:01 PM
For sale: Front Bumper (cracks by passenger headlight) Tonka Exterior Parts & Accessories 0 06-02-2010 06:19 PM
Swapping out Front Bumper Covers droidboy Cosmetics and Lighting Modification Discussions 22 05-06-2010 08:19 AM
