Cold Air Inductions
Old 05-12-2011, 01:53 PM   #1
Hired Gun
Wild Man
Hired Gun's Avatar
Drives: 2010 Camaro
LED Side markers
Ok I have decided to order a set of led side markers for my black 2ss. I have priced them already from AAC. I was thinking black and tinted. I was not sure on the tinting however. I was afraid they would not show up bright at night.
Also, how reliable are these? I would hate to order them and they fill with water, or burn out in a few months. I had this happen with a company called RECON. I was ready to go after the owner due to a piss poor product that faded to yellow, and burned out in about a year.
So please if you have led side markers, let me know all you can, the good the bad, and the ugly. Vendors please sway me to your side so I can get them ordered.
I am sick of looking like the guy down the road, I want the cool stuff in lighting.
2010 Camaro Black with White Stripes, Jannetty Racing Roto-Fab CAI, VMAX Ported Throttle Body, Long Tube Headers, GMPP Axel Back, Emblem Pros Custom "VOODOO" Under hood Bow tie, Chrome Gill Inserts, HUD plate, Sparks Performance White SS front and rear Plate MPD-1 Spoiler
Hired Gun is offline   Reply With Quote
Old 05-12-2011, 02:16 PM   #2
fugimo
fugimo's Avatar
Drives: 2010 Camaro SS/RS ABM
I currently have the AAC side markers and they are tinted, the tint is not dark like you are thinking, they are more of a shade of tint so that you do not see the LEDs when the lights are off. I have also tied the side markers into my turn signals, so they actually work as blinkers when making a turn. They are plenty bright enough, even with the tint and reduced lighting so they can blink when they are suppose to.
I have had them on the car for about 9 or so months and have not had any problems with them, except when I miswired one up wrong and only three of the middle LEDs did not light up, but once I corrected the wiring, had no problems at all. Have not had any water get into them as they are sealed like the factory ones and the hole I drilled into the back of them, I used silicon to block that hole.
All in all, I am very happy with them and get compliments on them all the time. You really can't go wrong with these.
Born date 12/18/09
ARK Slant Tip Cat back Exhaust
Ported throttle body
Injen CAI
AAC lighting (Foot well, trunk, interior, RGB Halos, Plasma DRLs, V2 scanner, side markers)
fugimo is offline   Reply With Quote
Old 05-12-2011, 02:20 PM   #3
Camaro21
Drives: SOLD - 2013 M6 ZL1
Here are a couple of pictures of my Black Camaro with the AAC Painted & Tinted Sidemarkers.
Camaro21 is offline   Reply With Quote
Old 05-12-2011, 02:28 PM   #4
jmart53
jmart53's Avatar
Drives: 2012 Cruze LTZ RS
do the OEM ones just "pop" off and these(AAC) snap into place with plug and play wiring?
jmart53 is offline   Reply With Quote
Old 05-12-2011, 02:46 PM   #5
Hired Gun
Wild Man
Hired Gun's Avatar
Drives: 2010 Camaro
Thanks for the fast feedback. When you wired them into your turn signals did you supply the wiring, or was it an extra harness?
I may order these in the morning. Does it take long to get them? I got a pm from AAC today so I was happy for the fast pm.
Old 05-12-2011, 03:01 PM   #6
AACstyle
AACstyle's Avatar
Drives: www.CamaroLighting.com
These sidemarkers are still PLENTY bright even with the tint!
AACstyle is offline   Reply With Quote
Old 05-12-2011, 03:04 PM   #7
AACstyle
AACstyle's Avatar
Correct, you just pop out the stock ones and pop these in... thats all there is to it!
Instructions are included.
Old 05-12-2011, 03:35 PM   #8
bthomp01
bthomp01's Avatar
Drives: 2010 2SS/RS IBM M6
I've been looking at these for a while but I have a question about the rear ones. I've been hit twice, once in each rear wheel which means the rear bumper has had to come off a few times. On the driver side the rear bumper piece isn't totally flush with the rear quarter panel anymore, right where the side marker is, the bumper buldges out a little bit. Looking at that image it doesn't look like there's any clips on the markers themselves, or are they just hidden by the foam? If I could buy these and knock that problem out that'd be awesome, but if it's the bumper clips that are busted I'm going to have to find some other way to fix it..
EDIT: I'll see if I can get a picture of this when I get home today, horrible weather though so it might be tough.
2010 IBM 2SS/RS - T BRUTAL
Matte Black Bumblebee Stripes - Unpainted Heritage Grille - Blacked Out Bowties - Stainless Works S-Tube Catback - CAI, Inc. Cold Air Intake
Whiteline Rear Cradle, Rear Differential, Front Radius Rod Bushings - BC Racing BR Coilovers - Installed by Whiteside Customs
bthomp01 is offline   Reply With Quote
Old 05-12-2011, 03:37 PM   #9
AACstyle
AACstyle's Avatar
The sidemarkers have clips, its the complete marker. That is just thick foam that we ship them in to be sure they arrive to the customer safely
Old 05-12-2011, 09:36 PM   #10
CDN SS
Steve from Canada.
CDN SS's Avatar
Drives: 2010 SW SS/RS with Inferno package.
I installed a set of painted AAC side markers 3-4 weeks ago and loved the look of them. After 2 car washes I noticed 3 of the 4 have condensation inside of them and one has 2 blowen LEDs. I contacted Jonathan via PM and he told me to remove them from the car, ship the blowen one back to him for replacement at my cost. I'm suppose to open up the others using a razor blade, let them dry out and then reseal them using a silicone caulk.
If there was a problem with one I could understand but 3 out of 4 should not happen with a product that has been around for awhile. So now I have to go back under the car to remove the new ones and replace them with the stock ones then do it once again once I get my replacement back from AAC. Since it's my responsibility that the part gets to AAC I'm going to have to ship it insured with a tracking number. The cost to ship from Canada to LA will probably be around $30.
Almost every mod I've bought for this car has had a problem, this one is no exception.
CDN SS is offline   Reply With Quote
Old 05-12-2011, 10:03 PM   #11
Angelsilhouette
Angelsilhouette's Avatar
Drives: 2011 Camaro 2LT RS, Red Jewel
Ooog! This makes me think twice about them. I'm glad I read this.
Still not quite done.
Angelsilhouette is offline   Reply With Quote
Old 05-12-2011, 10:09 PM   #12
Tom D
Tom D's Avatar
Drives: 10 Camaro SS/RS RJT
Same here. Sure would like to hear what AAC has to say about that. Glad I didn't order yet.
2010 2SS/RS RJT, ADM CAI, Borla Shorties, Borla "S" Cat Back, Edelbrock E-Force Supercharger, GMS Wires, GMS Rear Trailing Arms, GMS Rotors, GMS End Links, GMS Tunnel Brace, GMS Rear Tie Rods, GMS 1G Suspension Package, GMS Stage 3 CNC ported heads, GMS Spec'd R12 Custom Ground Camshaft, Snow Meth Injection, GMS Custom Tuned, Norris Catch Can, MTI Brake Lines, Pfadt Coilovers, Sway Bars, Camber Kit, and Rear LCA Reinforcement, , AAC Footwell, Trunk, DRL and Dome LED Lighting, Technostalgia Tail Lights, RED B/A Pedals, Kompression Custom Wheels with Nitto tires, 621RWHP/584RWTQ
Tom D is offline   Reply With Quote
Old 05-12-2011, 11:12 PM   #13
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
Can't give you a review yet. Ordered on 4/22. Still waiting.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 05-12-2011, 11:35 PM   #14
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
I think there is a miss understanding here I've had no issue with any promblems that occured with my AAC stuff so I find it hard to belive they are not going to take care of you!!!!!!!
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now!
Gotthat02fire is offline   Reply With Quote
AAC LED Side Marker Lights Stealth 2010 2SS/RS Cosmetics and Lighting Modification Discussions 21 04-20-2011 10:57 PM
DIY - 2010/11 Camaro AAC LED Side Markers Install with Turn Signals GearHeadPeter Camaro DIY & HOW-TO instructions & discussions 0 03-03-2011 02:30 PM
Smoking the Tail Lights and Rear Side Markers Medieval Peanut Cosmetics and Lighting Modification Discussions 3 06-22-2010 01:11 PM
WTB Side markers christianmotox Exterior Parts & Accessories 2 06-17-2010 12:01 PM
Who makes painted or blacked out front and rear side markers?? g-townmach Cosmetics and Lighting Modification Discussions 7 12-08-2009 07:03 PM
