Old 05-12-2011, 05:41 PM   #1
StlRomAniaN
StlRomAniaN's Avatar
Drives: IOM 2010 Camaro 2SS/RS
Rotor Hats
I've been thinking about painting the rotor hats on my SS flat black. Has anyone done this? Do you think this is a good cosmetic touch? I just want some opinions before I go do it. High temp. paint of course .
StlRomAniaN is offline   Reply With Quote
Old 05-12-2011, 07:25 PM   #2
StlRomAniaN
Yes no maybe so. lol
Old 05-12-2011, 07:32 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
Sure why not. It won't hurt them.
Click to view my build thread
Old 05-12-2011, 10:30 PM   #4
StlRomAniaN
Ugh. Has anyone on this forum done this?
Old 05-12-2011, 10:41 PM   #5
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
It shouldn't be that hard to visualize even if nobody has done it...
Or are you just asking out of durability curiosity? Either way, you posted it in the wrong forum and you won't get many responses. Brakes or cosmetic mods would've been better.
[B]
Old 05-13-2011, 08:16 AM   #6
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
I just got finished painting my rotor hats a close-to-stock aluminum color, since I got a very nasty cleaner on them that stripped their factory protective coating right off and they started to rust.
I used Rustoleum High Heat (2000 degrees Fahrenheit) paint for mine. Be careful with high heat paint, since it can only be cured via heat. Otherwise, even though it's dry to the touch, it scratches and marks very easily until it cures. Drive the car around a lot before cleaning them for awhile and the heat from the braking should cure the paint.
Black should look pretty damn good, if I do say so myself. Where are you going to get gloss black high temp paint?
Also, perhaps you can answer a question for me. The texture for the rotor hats is ridiculously coarse and traps brake dust real easily. How do you clean them without using harsh chemicals? Even agitation doesn't do a good job.
nUcLeArEnVoY is offline   Reply With Quote
