05-14-2011, 03:29 AM | #1 |
formerly 2011Camaro
Drives: 2011 Camaro LS IBM M6 Join Date: Jul 2010
O2 extensions
Just installed my bbk long tubes and would like some short rear O2 extensions, does anyone know where I can get some for a decent price?
Born on the Island and raised in the sand.
Semper Fidelis |
05-14-2011, 04:33 AM | #2 |
Why do u need rear ones?
top 10 reason why real men drive stick. 10. A manual transmission is the ultimate in control 9. You can use automotive jargon and not sound like a total tool 8. You can't spell "manual" without "man" 7. Manual transmissions prove you can do more than one thing at a time 6. You can't drift in an auto 5. You can't pull fancy moves in an automatic 4. You get better fuel economy with a stick 3. You’ll never look like a chump if you can drive stick 2. Manual transmission cars are faster 1. Women like a guy who is good with his hands. |
05-14-2011, 05:21 AM | #3 |
Drives: 2010 Camaro Rally Yellow 2LT Join Date: Aug 2009
You should be able to pull enough slack from the existing wires to plug into your sensors. The driver side wire runs across the top of the trany to the passenger side where it is attached to some other wires/cable. Just loosen that and it will give you enough slack.
05-14-2011, 06:31 PM | #4 |
formerly 2011Camaro
Yeah I loosened it up but the passenger side is still kind of tight so I thought if I could find some decently priced extensions I'd go ahead and throw them on there .
Semper Fidelis |
05-15-2011, 10:11 PM | #5 |
Wind Rider
Drives: ZL1 19 White; Jeep 5.7 GC 15 Join Date: Jan 2010
Guys!
Did anybody post a DIY on headers installation?
Im not Gray any more !!
05-18-2011, 09:13 AM | #6 |
I had to cut a wire tie that was holding the passenger side extension to the tranny. You really should not have any problems. If I didnt cut that wire tie then it would have been too short.
05-18-2011, 07:47 PM | #7 |
formerly 2011Camaro
I'll take another look at it when I get it up on the lift next. Thanks all
Semper Fidelis |
05-18-2011, 07:54 PM | #8 |
Drives: 99 Camaro SS, 79 z28, 70 GTX Join Date: Oct 2009
we offer 24" 02 extensions
05-30-2012, 02:25 PM | #9 |
Drives: 2015 Camaro 1LE 2SS Join Date: Mar 2012
this may be a stupid question but do i need the rear O2's connected or the front ones?
05-31-2012, 10:38 PM | #10 |
formerly 2011Camaro
the front (pre cat) are a must, the rear basically get deleted out with a tune so its up to you on those
Semper Fidelis |
Thread Tools | |
Similar Threads | ||||
02 extensions | jeffny09 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 0 | 05-11-2011 05:17 PM |
O2 Sensor Wire Extensions? | Hicompression | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 19 | 03-28-2011 08:09 PM |
LT header O2 extensions | summitss/rsls3 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 19 | 01-06-2011 04:08 PM |
Rally Stripe extensions?? | Camaro Freak | Cosmetics and Lighting Modification Discussions | 3 | 03-15-2010 04:01 AM |
stripe extensions | mrpre10der | Cosmetics and Lighting Modification Discussions | 8 | 03-28-2009 03:13 PM |
