Old 05-14-2011, 07:41 PM   #1
scythezo6
Virologist in the making
scythezo6's Avatar
Drives: 2010 VR SS/RS LS3
Fuuuuuuuuuu plz help!!!
I decided to peel off my stripes today and all the glue stayed behind I've gone through 6 cans of 3M adhesive remover and i have been working for 5 hours removing the glue! Anyone have an answer?? Any help would be much loved! :(
Old 05-14-2011, 07:42 PM   #2
1badtie
1badtie's Avatar
Drives: 2010 Camaro 2SS RS
go buy a heat gun and heat it up then use the adheisive remover
2010 2SS RS --- SOLD
MODS-
Performance: BMR trailing arms & bushings | BMR Toe links | X-pipe | Muffler delete | Vmax ported throttle body | Apex "strong" MAS | Vararam CAI | Apex catch can | Kooks Headers | Kooks HF Cats | Dyno tuned by GPI 417 RWHP 409 FT-Lb
Cosmetic: painted Zl1 rockers | Zl1 grill | AAC side markers | AAC LED backup lights | windows tint | taillight tint | JDP tow hook | all emblems blacked out | LED fogs
1badtie is offline   Reply With Quote
Old 05-14-2011, 10:35 PM   #3
scythezo6
scythezo6's Avatar
I tried heat and the glue is still stuck on. I can't afford to go through 6 more cans of adhesive remover. Anyone?
Old 05-14-2011, 10:44 PM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
Try using goo gone and a heat gun
Click to view my build thread
Old 05-14-2011, 11:02 PM   #5
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
O crap. That sux. My buddy was over here today trying to talk me into removing mine. Glad I didnt now. Good luck to you.
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires.
2000 1500 silverado extra cab
Camarowguy is offline   Reply With Quote
Old 05-14-2011, 11:15 PM   #6
Mr Twisty
Mr Twisty's Avatar
-- Benjamin Franklin
Old 05-14-2011, 11:53 PM   #7
David79z28
David79z28's Avatar
Drives: 79Z28 and 2010 2SS/RS
A wax and grease remover might break it down. I have used it with sign vinyl adhesive...
David79z28 is offline   Reply With Quote
Old 05-15-2011, 12:43 AM   #8
rlem00
try a clay bar yet?
rlem00 is offline   Reply With Quote
Old 05-15-2011, 10:05 AM   #9
USMCSSGT-RET
USMCSSGT-RET's Avatar
Drives: '14 SIM 2LT/RS Vert
WD-40
USMCSSGT-RET is offline   Reply With Quote
Old 05-15-2011, 10:25 AM   #10
Toyaholic
It's a sickness!
Toyaholic's Avatar
Drives: '69 442 Vert
I've had good luck with this....
Toyaholic is offline   Reply With Quote
Old 05-15-2011, 11:49 AM   #11
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
bug & tar remover, and alot of patience & elbow grease...
Old 05-15-2011, 11:51 AM   #12
trashauler
trashauler's Avatar
Drives: 2010 ABM 2SS RS 2008 Trailblazer
Try a citrus based degreaser. I have used that on some of our trucks and it works well.
trashauler is offline   Reply With Quote
Old 05-15-2011, 11:53 AM   #13
Xmicro_SS
Thank You GM
Xmicro_SS's Avatar
Drives: Sky Redline & Camaro 2SS/RS
You really should have heated the stripes as you took them off. The adhesive would have stayed more on the vinyl and less on the car. You would have had some clean up, but not as bad.
An orbital buffer with the right pad and good auto adhesive remover should do the trick.
If you plan on having a body shop do any work to paint stripes, just leave it, they need to remove the clear anyway, and it will come right off. Or take it to a local detailer and have them do it.
ITS HERE! : 2010 Camaro 2SS / 6 Speed Manual (No other way) / Silver Ice Metallic / Inferno Orange Interior Accent / RS Package / Polished Wheels / SOLO MACH X CAT BACK
Xmicro_SS is offline   Reply With Quote
Old 05-15-2011, 12:30 PM   #14
spyderbuddy
spyderbuddy's Avatar
Ok this one is and old trick to remove glue. And believe it or not it works this is not a joke and I was not going to tell you this.
I used this to removed the glue off my 2001 Chevy Impala.
Lighter fluid
Just be very careful and make sure you wash and wax after.
and please do not set this on fire it will burn the paint.
Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, Vararam Cold Air Intake, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
i need help plz martin_2010 5th Gen Camaro SS LS LT General Discussions 1 03-01-2011 01:19 PM
PLZ HELP!!! CLUELESS BRAVO29ER Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 07-27-2010 05:09 PM
hey you guys i need help with girl problem plz plz plz thejoker1232 Off-topic Discussions 117 03-19-2010 11:57 PM
Plz help with a photshop JorgeSS Camaro Photoshops / Renderings Forum 16 03-02-2010 11:27 AM
PLZ INSTRUCTION HOW TO INSTALL AMP AND SUB Terrellford12 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 14 07-03-2009 07:17 PM
