Old 05-15-2011, 04:23 PM   #1
ouhockeyplayer
Drives: 2010 Camaro RS
Paint chip repair concerns
So I just repaired a paint chip on the top of my rear quarter panel (the flat part by the pillar) using the Lanka system and the jagged edges of the chip are still visible. I have tried multiple coats of paint but I can't seem to get a perfect flat finish. Should I be worried that the edges of the chip can lead to further chipping in the area? Also, what is the best cloth to put over the card for rubbing the excess paint off? I was using a thin meguairs microfibre towel.
ouhockeyplayer is offline   Reply With Quote
Old 05-16-2011, 11:10 AM   #2
ouhockeyplayer
Here is a pic of the chip if that helps. Anyone with any tips?
Old 05-16-2011, 11:21 AM   #3
BigCarrot
xbox: this is tedious
BigCarrot's Avatar
Drives: 2011 1SS M6 Camaro IOM
That chip doesn't appear to be filled in all the way yet. I know when I got some paint chip repair it says to apply 1 coat then check for appearance then apply more if necessary. Then once you're happy with the look allow 24 Hours to cure then apply clear coat which also comes in a small container.
Got the Color for my car from the Dealer and the Clear Coat from an Auto Parts Store.
Big Carrot's Changes - It's a work in progress
Originally Posted by Fiftydriver View Post
Seems like just yesterday I spent $450 for a Roto Fab CAI!!! What the hell happened.
BigCarrot is offline   Reply With Quote
Old 05-16-2011, 12:21 PM   #4
ouhockeyplayer
Thanks. I did multiple coats but the factory touch up paint goes on so thin. I finally had what I thought was a good fill, and when I used Lanka to smooth it out the above picture was the result. Should I be using something different then a meguairs micro fibre towel with the Lanka system?
Old 05-16-2011, 01:22 PM   #5
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
try using the thinnest cotton tee shirt you can find, wrapped around a stiff plastic credit card, the mf towel is too thick........ next time try dr colorchip, gets a good fill everytime and is much easier IMO.
h2oplay is offline   Reply With Quote
Old 05-16-2011, 01:45 PM   #6
ouhockeyplayer
Thanks. I was thinking the towel might be taking too much out. I will try a t shirt and see how that works.
Way to fix you rims if you curb your wheels DarkDragonAn Wheels and Tires Talk Sponsored by The Tire Rack 25 08-21-2016 12:11 PM
How Safe is the PC-7424XP for Newbies? Junkman2008 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 182 07-01-2012 07:00 PM
Understanding Paint Correction-The Nitty-Gritty Mr CLuTcH Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 29 03-02-2012 04:51 AM
Paint chip :( JFerraro819 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 15 05-07-2011 10:44 AM
Paint Chip to Door C4m4r0 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 8 08-25-2010 03:04 PM
