Cold Air Inductions
Old 05-15-2011, 05:15 PM   #1
AACstyle
AACstyle's Avatar
Drives: www.CamaroLighting.com
Arrow AAC's 1969 Pro Touring Resto-Mod Camaro Build
We have been swamped lately so I have not been able to post a complete build thread of this project but figured I would start the thread and update it as we find time.
Ok first the car started as an all original 1969 X44 body:
Smoothed Firewall:
Frame:
Coilovers/ Fuel Cell:
Last but not least... the powerplant!
Here is a quick mod run-down:
DSE SMOOTH FIREWALL
DSE MINI TUB KIT
DSE SUBFRAME CONNECTORS
GOODMARK STEEL COWL HOOD
POWER WINDOWS
ELECTRIC TRUNK LATCH
LINEX ENTIRE UNDERCARRIAGE
SPEED-TECH UPPER CONTROL ARMS
SPEED-TECH LOWER CONTROL ARMS
KDW QA-1 COIL OVERS
ENERGY SUSPENSIONS BUSHINGS
ENERGY SUSPENSIONS END LINKS
ENERGY SUSPENSIONS MOTOR MOUNTS
ENERGY SUSPENSIONS TRANS MOUNT
SPEED-TECH SOLID ALUMINUM BODY MOUNTS
BODY MOUNTS REINFORCED WITH WELD-IN 1/4” PLATES
PRODIGY CUSTOMS CANTED 4 LINK SUSPENSION
CUSTOM PRODIGY COILOVER SPRINGS
LATE MODEL POWER STEERING GEARBOX
DSE CONVERSION FITTINGS
EARLS BRAIDED STAINLESS POWER STEERING HOSES
NEW LS6 POWER STEERING PUMP WITH DSE OUTLET
SPEED-TECH ANODIZED BRAKE BRACKETS
Z06 CALIPERS AND ABUTEMENTS
EBC REDSTUFF PADS
EBC SLOTTED AND DIMPLED ROTORS
BRAIDED BRAKE LINES INSTALLED
MOSER 9 INCH REAR AXLE
LATE MODEL CAMARO BACKING PLATES
LATE MODEL CAMARO PARKING MECHANISM
EARLS BRAIDED CENTER LINE WITH CUSTOM AXLE LINES
MODIFIED LATE MODEL CAMARO BRAKE BOOSTER
WILLWOOD ADJUSTABLE PROP VALVE
PRODIGY CUSTOMS / RICK TANKS STAINLESS STEEL FUEL CELL
INLET TAIL PANEL CUSTOMIZED TO FIT FLUSH MOUNT GAS CAP
INTANK BOSCH "044" FUEL PUMP
PCM CONTROLLED LEVEL ASSEMBLY
AEROMOTIVE FITTINGS AND LINES 8AN FEED/6AN RETURN
AEROMOTIVE INLINE FUEL FILTER
AEROMOTIVE FUEL PRESSURE REGULATOR
AEROMOTIVE FUEL PRESSURE GAUGE
AEROMOTIVE FUEL RAILS/CROSSOVER LINE
LS7 DELCO FUEL INJECTORS
NEW GM LQ9 BLOCK
EAGLE FORGED 4 INCH STROKE CRANKSHAFT
EAGLE FORGED RODS
ARP 2000 ROD BOLTS
MANLEY FORGED PISTONS
LIGHTWEIGHT PINS
SPIROLOCKS
COVETTE Z06 BALANCER
ARP MAIN STUDS
ARP BALANCER BOLT
ARP HEAD STUDS
ARP STAINLESS HEADER STUDS
L92 RECTANGULAR PORT CYLINDER HEADS
COMP CAMS 26918 VALVE SPRINGS
TITANIUM RETAINERS
COMP CAMS PUSHRODS
COMP CAMS R SERIES LIFTERS
COMP CAMS CUSTOM GRIND CAM 580, 224, 115
COMP CAMS HEX-ADJUST TIMING CHAIN SET
LS2 TIMING CHAIN DAMPENER SYSTEM
LS6 HIGH VOLUME OIL PUMP
JMZ SWAP OIL PAN AND PICKUP TUBE
LS7 ROCKER ARMS
LS3 INTAKE MANIFOLD
LS3 90MM THROTTLE BODY
SPEARTECH PERFORMANCE ENGINE/TRANS HARNESS
SPEARTECH PERFORMANCE CUSTOM ECM AND TUNE
MSD PLUG WIRES
NGK PLUGS
GM PERFORMANCE ACCESSORY DRIVE
LS6 WATER PUMP
LS6 ALTERNATOR
KWIK PERFORMANCE COMPRESSOR MOUNT
SANDEN COMPRESSOR
BE-COOL DUAL FAN ASSEMBLY (PCM CONTROLLED)
BE-COOL ALUMINUM RADIATOR
BE-COOL AC CONDENSER
CUSTOM RADIATOR/CONDENSER MOUNTS
5 WIRE MASS AIR FLOW SENSOR
HOOKER CERAMIC COATED LONG TUBE HEADERS
HOOKER LS1 SWAP MOUNT BRACKETS
ENERGY SUSPENSION MOUNTS
MAGNAFLOW 3 INCH XPIPE
PRODIGY CUSTOMS TAILPIPES FOR PRODIGY BAR SUSPENSION
4L60E TRANSMISSION UPGRADED INTERNALS
TCI MASTER KIT WITH RED CLUTCHES
TCI SERVO'S INSTALLED
TCI 3200 STALL CONVERTOR
TRANS-GO SHIFT KIT
CUSTOM COOLER LINES
CUSTOM TRANS COOLER
MOSER 9" REAR END
LS1 AXLE ENDS
CURRIE 9" NODULAR CENTER SECTION
CURRIE BIG BEARING PINION SUPPORT
ARP STUDS
RICHMOND 3.70 GEARS
ARP RING GEAR BOLTS
AUBURN LIMITED SLIP
33 SPLINE MOSER FORGED AXLES (CUSTOM LENGTH)
AUTOMETER GAUGES
FLAMING RIVER TILT STEERING COLUMN
FLAMING RIVER RAG JOINT
FLAMING RIVER CRUISE CONTROL STALK (PCM CONTROLLED)
NEW CUT PILE BLACK CARPET
ELECTRIC CAMARO SS FRONT SEATS
AMERICAN AUTOWIRE FUSEBLOCK / COMPLETE HARNESS
ELECTRIC LIFE POWER DOOR LOCK KIT
ELECTRIC LIFE KEYLESS ENTRY W/ POWER TRUNK
Fast Forward to Camaro Fest 2011,
LS3 Engine cover custom painted & Installed:
Test fitting new console with custom aluma-grain hydrographics and LED illumination:
Update:
HUGE thanks to all our friends at Metra for supplying us with their Top-of-the-Line audio components for this build! This car is going to sound simply amazing!
Update:
Hmmm... need to get creative to fit this iPad into this new console!
Update:
Teaser Pic of the new nearly-completed sound system (this is what 3 months worth of work looks like):
Update:
The new sound system came out so nice we are doing a photoshoot
Update:
Of course you can't have a badass pro-touring Camaro without a custom set of wheels. Bismark and USW really came through for us with these custom USW Forged wheels!
*Updated Shots*
Here is another teaser from the soon to be released ORACLE Camaro Photoshoot:
Interior Shot:
Yes, that is an iPad integrated in the console. Why? Controls the stereo, navigation, and on-board web browsing
Update- New Pics!
Motor:
Sound:
Custom Kick Panels:
AACstyle is offline   Reply With Quote
Old 05-15-2011, 05:16 PM   #2
AACstyle
AACstyle's Avatar
One of my favorite mods on this entire car is the "hideaway" sidemarkers!
We really wanted to incorporate some of our own products into this build and this was a great way to do it
Old 05-15-2011, 05:17 PM   #3
AACstyle
AACstyle's Avatar
RESERVED #2
Old 05-15-2011, 10:38 PM   #4
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I had every intention of getting the this side marker lights but my gas money caught me off gaurd.
Those hidden side markers are pretty damn cool.
Old 05-15-2011, 11:08 PM   #5
The Stig
knows 2 facts about ducks
The Stig's Avatar
I'm really liking those hidden side markers guys. Great Job
Click to view my build thread
Old 05-15-2011, 11:25 PM   #6
Jekyll-N-Hyde
I put the FU back in FUN
Jekyll-N-Hyde's Avatar
Drives: 1969 SS 396 , 2010 Camaro SS
Wow yall used a X44 car for this Car looks Amazing however i'm suprised folks are using optioned marked cars for retro modding.
Great job either way keep up the Great work.
Jekyll-N-Hyde is offline   Reply With Quote
Old 05-16-2011, 04:49 AM   #7
mcotton
mcotton's Avatar
Drives: 2010 Camaro
looking good
mcotton is offline   Reply With Quote
Old 05-16-2011, 05:43 AM   #8
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
funny thing is a few weeks before you showed off the car i was talking to my dad(partner) in the shop about getting some AAC goodies in to my 69 firebird im getting ready to start building. then poof you guys droped it! Really nice job with the car guys!
camaro4mybday is offline   Reply With Quote
Old 05-16-2011, 09:42 AM   #9
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
No numbers matching engine, no care when it comes to X codes. X44 is pretty common, perfect for modifying. With the right modifications, these pro-touring cars sell for far more than any numbers-match fully restored version of an X44 would bring.
Nice project guys!
Tony
Fquick.com/NineBall
Old 05-16-2011, 12:15 PM   #10
Jekyll-N-Hyde
Nice project guys!
Tony
oops my bad I just reread I thuoght you started off with engine and body lol
Sorry long weekend
Continue on
Old 05-16-2011, 08:18 PM   #11
thespymaster
thespymaster's Avatar
The whole build is very bad a$$................
2014 C7 Stingray 3LT/Z51
2013 Camaro SS
2012 Camaro ZL1 - 850 HP
2015 GMC Denali 3500HD 4x4
2012 GMC Sierra 3500HD 4x4
Old 05-17-2011, 12:52 AM   #12
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Those hideaways are freaking SICK!
Loved seeing the cars at C5FII. People were talking and talking about them! And you know....I loved seeing them drive all over the place. No one was afraid to go and take them for a spin. I get really tired of seeing the trailered cars everywhere... they are taken off, shown off, tossed back on the trailer and stored somewhere. Where the hell's the fun in that???
LOVED seeing them out on the road!
Old 05-17-2011, 01:19 AM   #13
Merc
In The Circle
Merc's Avatar
Old 05-17-2011, 01:26 AM   #14
Merc
In The Circle
Merc's Avatar
I wanted to pick-up a set of IOM tinted side marker lamps at Fest, but you were sold out. Any chance you will still honor the Fest price.
Curt's 1969 Camaro Project cjingle USA - Southwest 523 12-14-2014 12:17 PM
GT5 Camaro pics brantley847 Camaro Photos | Spyshots | Video | Media Gallery 93 05-27-2013 09:35 PM
