| Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires |
Thread Tools |
www.norcalcamaros.com
Bogart or Weld, with DOT tires, but drag set up in mind
We're kickin around the idea of running a set of Bogarts or Welds on our shop car, 2010 SS blah blah blah...
The idea is to have the lightest wheel/tire combo, 17", or maybe 18", but with DOT approved and streetable tires. I know we're asking for cake and eat it too, but we know there will be some trade off, its just how much trade off and what are the results... All the 28" x ? x 17 or 18 are too short. Yes , I know 28" is a great height, fits well, and might be the best size for performance while still filling the wheel well, but IMHO, 28" is just a little too short. It leaves too much tire to fender gap. Yes, our car is lowered, but still too short IMO. What I'm really asking for here, is, not opinions, but I'll listen, I want real world experience. Show me or tell me whatcha got. Ideally: 1. 29" tall tire 2. 17" wheels 3. Drag radial tires, that will still handle well on the street. Pics would be great too. |
Does anyone have experience with Mickey Thompson ET Street Radial 305/45-18? , the specs claim 29" tall.... ????
No one makes a 29" tall 17" wheel skinny. M&H just came out with a 28" radial skinny (if you can find it), I have the 26" on my fronts. My 295/45/17 MT ET streets are 27.6" tall, the 305/45/18s should be 28.8", so that sounds about right. Shorter tires will make the car faster though. Not only less rotating mass, the gear advantage is a winner. This combination is DOT approved, and drives fine on the street, I put 100 miles on it this past weekend with no issues
Thanks for the feedback.
The Nitto NT05R, specs say 28.9", I wonder how accurate that is. I might have one dropped off and mount one up and see for myself. How does your car handle the twisties? just curious... |
It drives fine in corners, but I wouldn't push it very hard with a skinny tire up front. They aren't meant to handle the loads of a car this heavy pushed hard. They're only rated @ 1100lbs/tire.
#6 |
![]() Drives: 2011 Camaro Join Date: Jan 2011
Bogarts mainly because they fit without modifying or upgrading to different arms.
17x5 with 28x4.5x17 M&H D.O.T. Front 17X10 with 32545R17 M&H Drag Radials Rear http://www.mandhtires.com/store.php?...on=show_detail http://www.mandhtires.com/store.php?...on=show_detail |
#7 |
COTW 12/5/11
Drives: 2010 Camaro 2SSRS IOM Join Date: May 2009
I just ran my Bogarts (front and rear) at the track for the first time last Friday. I have no complaints and Pumpkin is even lowered 1.5".
#8 | ||
Thanks in advance. |
#9 |
COTW 12/5/11
Pumpkin has everything BMR makes for the Camaro. Although BMR claims I have 1" lowering springs, it has settled more then a 1". I ran the Bogart's last Friday with no issues. You can check my build thread for pic's of Bogarts.
#10 | |
What size are your tires? Sorry everyone that I'm so hung up on the look, as I usually preach performance way over appearance, but I'm considering running 17's and DR's only, so she's gotta look good sittin in the shop,
#11 | |
COTW 12/5/11
#12 |
In Mud We Trust
Drives: 2010 Camaro 2SS/RS LS3 Join Date: Mar 2011
Ovenmitt,
Love the stance and look of your car with that tire wheel combo. So it drives OK on the street? Would really like something like this and ditch these low profile tires and 20" wagon wheels.
2010 2SS/RS, LS3 -Hurst Shifter -American Racing Torq Thrust/Anthracite -CAI Intake |
#13 | |
I'm not trying to steer you away from the idea, I just want to make sure you know what you're getting in to before you go out and spend a lot of money!!! I still absolutely love the look, and I hope someday to have enough money to buy a secondary set of wheels/tires like this. Until then, unfortunately, I need to keep it a little more practical for the street. |
#14 | |
So, I guess that raises this question: Is there a Drag Radial set up, that runs Bogarts or Welds, 17" or 18", with, say, an 8" or 9" wide front wheel, and a performance tire, so you kind of end up with best of both worlds? |
#15 |
I am not aware of any radial tire that you can use with the 17x5 or 17x8.
#16 |
One combination that I considered when I was researching this set-up was running a 17x6" or 17x6.5" front wheel, and running a P215/65R17 (which will supposedly fit a 6-7.5" wheel). This is the skinniest and tallest (28.0") radial tire that I could find that is commercially available. There are even a few "H" rated (130mph) tires in that size. It would be a pretty good 28.0" front radial, which would match the 28.0 height on the M&H 325/45R17 radial drag master. In the end, I didn't want different brands and/or tread patterns on the front and rear (I guess I'm too picky).
#17 | |
Great Information!!!!
#18 |
In Mud We Trust
Does Weld or Bogart make a wheel that's normal width for the front so you can put on a tire that's not so skinny?
I agree, I wouldn't want to be driving around town all the time with 5-6" tires up front. The mileage doesn't matter to me as I only drive about 3000-4000 miles a year. All I want is an 18" wheel, the same width of the stock tires but a larger sidewall. I'm ready to change the brake pads/calipers to achieve this. I'm finding out this tougher than I thought. ![]()
#19 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Feb 2010
I would advise against driving the Bogarts on the street for daily driving. They will make you a specific wheel if you want to do that but their drag wheels are super soft and will bend easily if you hit a decent pot hole. I've seen the edges rolled in from being dropped during shipping.
On the tires, what about the M & H 275 drag radial? Thats the same size as stock.
9.80 @ 139.73, 1.45 60', 2010 Jannetty Racing L99
#20 | ||
#21 | |
I get nervous driving on the return road. They are kick ass wheels but for the street, forget it.
#22 |
The obvious answer is two sets of wheels and tires, I just really want a happy medium, without sacrificing too much either way.
#23 |
Did you look into the CCW wheels at all?
#24 |
Weld Racing does make their RT-S wheels in all the wider widths you're talking about, all the way from 5" up to 10.5" that will fit the Camaro (high mounting pad), in both 17" and 18". However, as we have just recently learned, the 17" should only be used if you are strictly staying at factory ride height, as there have been a few reported cases of the trailing arms hitting the wheels on hard launches on lowered cars. Go with the 18" if you ever plan on modifying the ride height. They also make them in an awesome looking 20", but they are really expensive once you get up to that size.
#25 |
| Thread Tools | |
| 5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 138 | 05-09-2013 03:58 PM |
| Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 | TAG UR IT | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 44 | 07-13-2011 01:43 AM |
| Wanted: 20" set of factory wheels and tires, central IL. if possible | wbyman | Wheels / Tires | 19 | 04-16-2011 11:47 AM |
| What is a new set of rear tires gonna cost on the RS.... | Wizzer | Wheels and Tires Talk Sponsored by The Tire Rack | 28 | 03-21-2010 02:24 PM |
| Drag Racing Suspension Kits | Info@PeddersUSA.com | Suspension / Chassis / Brakes | 25 | 02-21-2010 08:48 PM |
