Jason 98 TA
Old 05-16-2011, 01:35 PM   #1
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM 2SS
NOS or Zex?
I got a guy tellin me he can hook me up with a NOS kit for my v6 at $300 + install.
Phastek has the Zex kit for about $550.
Which is the one I should go with? I am tryin to figure why the Zex kit is more expensive than NOS at almost a $200 difference and wondering if the NOS kit is built just for the Camaro as well or is it something that is ported over from another car and will require customization to install in a Camaro.
Blade is offline   Reply With Quote
Old 05-16-2011, 01:39 PM   #2
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
do you have a parts list for both? does that NOS kit come with a throttle position sensor? is that how you want to run your kit, or do you want to run with a push button?
Old 05-16-2011, 01:48 PM   #3
Blade
Blade's Avatar
I much rather have the TPS than push button.
Old 05-16-2011, 01:49 PM   #4
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
We recomend Zex, they make a better kit and have a nice bottle preasure saftey feature.
GET MORE POWER PER DOLLAR!!!
We carry all the hottest brands for your Gen5 and Gen6 Camaros! Get awesome deals on Corsa, SLP, ARH, SW, Whipple, Kooks, Procharger, CAI, K&N, Rtoto-Fab and much more! Call us for your CAMARO5 discount today!
224-63-JUICE OR INFO@JUICEDMOTORSPORTS.COM
Juiced1 is offline   Reply With Quote
Old 05-16-2011, 01:52 PM   #5
PoorMansCamaro
Drives: Really Slow
well, nitrous management unit alone for the zex kit is $250. Not sure if NOS has that or not.
Old 05-16-2011, 06:31 PM   #6
usa1camaro1969
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
Is that the part they use rather than a fuel solenoid and a nitrous solenoid? If it is, Zex is the only one I know using that setup and I'm not sure it's a positive in my view. I know why they did it, I'd just rather have individual solenoids.
Oh, and I've got the NX kit. I'm pretty sure the NOS kit is everything other than the TPS, and don't let them tell you they can install a TPS on the accelerator pedal. It's a safety feature that keeps the kit from being activated until wide open throttle. You don't want to skimp on it. You can ask him how much extra for the TPS. They aren't that expensive.
I wake up in the morning and I piss excellence.
-Ricky Bobby
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
usa1camaro1969 is offline   Reply With Quote
Old 05-16-2011, 08:50 PM   #7
PoorMansCamaro
Drives: Really Slow
I believe the nitrous management system is the TPS for zex.
Old 05-17-2011, 10:40 AM   #8
usa1camaro1969
Pretty sure their tps is around $100, NX also. They can be had for less(around $70).
-Ricky Bobby
Old 05-17-2011, 11:00 AM   #9
Blade
Blade's Avatar
Checked last night, and the stuff you described is what's missing from the NOS kit.
Thanks man!
Old 05-17-2011, 12:32 PM   #10
PoorMansCamaro
Drives: Really Slow
no problem! good luck!
Old 05-17-2011, 06:32 PM   #11
usa1camaro1969
So when I looked it up, their TPS, fuel solenoid and nitrous solenoid is contained in a single box? Clean, but it means if one part doesn't work of the three the whole box has to be replaced/removed.
Before you install or have whoever install it make sure you realize there is a Schraeder valve at the back of the engine rather than cutting any of your stock fuel lines. It would make for a cleaner removal of the kit if needed/wanted in the future.
Good luck with the kit.
-Ricky Bobby
Old 05-17-2011, 07:52 PM   #12
PoorMansCamaro
Drives: Really Slow
You mean the jets, when talking about the solenoids, right? If so, then no, the jets are separate. They are placed just outside the intake elbow, about 2" away from the throttle body.
Old 05-17-2011, 07:55 PM   #13
PoorMansCamaro
Drives: Really Slow
You can see the purple piece in front of the engine cover, that holds the jets.
Old 05-17-2011, 08:32 PM   #14
usa1camaro1969
No, the nozzle holds the jets. The nitrous management unit contains a solenoid or pair of solenoids contained along with the tps unit. My NX kit has each piece seperate. The solenoid opens when you want it to allow fuel or nitrous to flow through the jets/nozzle. The Zex kit does look clean. I don't care for the way they're cutting a fuel line. I also wonder if the TPS or solenoid portion should happen to have issues if the management unit is rebuildable(I've always had separate solenoids).
-Ricky Bobby
zex nitrous kit for sale Nique303 Forced Induction 17 06-21-2011 03:30 AM
Anyone installed the ZEX Kit? Germann Forced Induction - V6 10 02-21-2010 01:16 PM
V6 Camaro Owners! 2010 V6 Zex Nitrous System now available! Kris@BMCPerformance Forced Induction 3 01-23-2010 03:41 PM
ZEX Installation Instructions tbyrne Forced Induction - V8 0 09-26-2009 03:03 PM
New Zex 2010 Camaro V6 Nitrous Kit - intro and free shipping @ PFYC.com Redshift Forced Induction 0 07-16-2009 09:31 AM
