IPS Motorsports
Forced Induction - V6 V6 Supercharger, turbo, nitrous discussions
Old 05-23-2011, 03:47 PM   #51
Duflar
Duflar's Avatar
Drives: 2011 Camaro 2SS RS
Originally Posted by jeff4946 View Post
Well, there might be an advantage of nitrous enabling you to burn a lot more fuel,that is the important part of it, and THEN cooling is a close second, but cooling doesn't make 125hp... and if that bottle heats up and you continue to pump nitrous in that bottle, that would be BAD!
Nitrous IS why you can burn more fuel. The nitrous changing state from liquid to gas causes the intake air temp to drop hense denser air/ more air per stroke so more fuel to the mix. The reason the bottle (charged) goes into the bath is to keep it at 92 degrees.That temp has been determined to insure that it will come out at the desired psi. The size of the jets and the angle they spray into the cylinder heads has been tweeked too. depending on the ambient temp and humidity the jets could be changed out to a larger or smaller orifice to get the desired flow rate. My brother races in Wild Street bracket (8.5 sec 1/4 mile) where the smallest tweek can cost you the race. Just last weekend he broke out (8.47) because the air temp dropped by the time he got to the line. He was done for the day so for the hell of it his mechanic put in a larger jet and he ran an 8.10. I forget what the numbers are when it's not on the gas, some where around 920 HP. And 1350 on the N2O. The nitrous doesn't get switched on until after the burnout and just before staging, then purge the lines, then it kicks in at a pre determined rpm, then cuts out below a set rpm and switched off after trapping. It's very hard on the engine. He breaks down the engine after a couple sessions to check for wear and tear. He's an old video of his car during a test and tune. He had a lot of issues at the time and ran in the 10s. I will be getting new video the next time he runs including in car video.
Here's a recent run from this past weekend. Unfortunatly he broke out and was disqualified. Just couldn't slow the beast down.
Duflar is offline   Reply With Quote
Old 05-23-2011, 05:45 PM   #52
ROD1
Back to the hunt....
ROD1's Avatar
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09
Note to NGK plug owners
This is a quote.
"I do NOT recommend re-gapping an Iridium spark plug as you will likely damage the core without even realizing it (meaning they will still run, just not to their optimum potential). This is straight from NGK themselves, as they say in their literature it would be better to run one of their Iridium plugs at the incorrect gap than it would be for you to re-gap them and run them there. "
ROD1 is offline   Reply With Quote
Old 05-23-2011, 06:09 PM   #53
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Drives: 2010 Camaro 2LT Rally Yellow
11.5 or maybe a cage might be in order. LOL.
Best of luck!
GMPP exhaust/JBA shorties/Vararam CAI/VMax TB/SLP Pulley/VMax IM isolator/MACE Ported IM +Plenum Spacer/IPF Tuned
67 GTO is offline   Reply With Quote
Old 05-23-2011, 06:45 PM   #54
ROD1
ROD1's Avatar
Best of luck!
11.499 for cage...
Old 05-23-2011, 07:29 PM   #55
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
how har dis it to install the zex system?
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 05-23-2011, 07:46 PM   #56
jeff4946
jeff4946's Avatar
Drives: 2010 RS 2LT
Originally Posted by ROD1 View Post
11.499 for cage...
Wow... its like we just started running this shtuff.... or something. Geez, don't you know?
K&N Cai, BSR Ported intake, MBRP catback, BBK long tubes, VMax throttle body, 3.73 SS gears, Zex nitrous 125hp shot, window switch, purge,remote bottle opener, bottle heater, Trifecta tune, Hurst short throw, RX catch can, Intake isolator, Ported Intake manifold
jeff4946 is offline   Reply With Quote
Old 05-24-2011, 10:02 AM   #57
ROD1
ROD1's Avatar
And you can run a sub 11.5 once. They might not give you the time slip though...
Old 05-24-2011, 10:40 AM   #58
jeff4946
jeff4946's Avatar
Drives: 2010 RS 2LT
I had mine installed by the local performance shop. Don't think its too hard though.
Old 05-24-2011, 10:42 AM   #59
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
yeah, installation is fairly easy. Just need to lay out where you want everything installed.
Old 05-25-2011, 01:42 AM   #60
ADKINS PERFORMANCE
Banned
Drives: boosting camaro
Just a heads up we are now stocking zex and half off install tell the end of the month
ADKINS PERFORMANCE is offline   Reply With Quote
zex nitrous kit for sale Nique303 Forced Induction 17 06-21-2011 02:30 AM
Anyone installed the ZEX Kit? Germann Forced Induction - V6 10 02-21-2010 12:16 PM
V6 Camaro Owners! 2010 V6 Zex Nitrous System now available! Kris@BMCPerformance Forced Induction 3 01-23-2010 02:41 PM
ZEX Installation Instructions tbyrne Forced Induction - V8 0 09-26-2009 02:03 PM
New Zex 2010 Camaro V6 Nitrous Kit - intro and free shipping @ PFYC.com Redshift Forced Induction 0 07-16-2009 08:31 AM
