| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
#26 | |
![]() Drives: 2010 Camaro SS / 2006 CC Duramax Join Date: Aug 2009
The only spring failure I witnessed myself was on TSP Jasons' personal black 2010 Camaro that you guys did the install on. The #4 intake valve spring broke causing the intake valve to break off into the engine. This happened 1800 miles after the new owner purchased the car from Jason. So your PRC springs are good for .708 lift and 7500 rpm?
#27 |
I'm not comfortable with their .650 springs on the LS3, I don't feel they can control the intake valve very well with the low pressure. Friend ran into issues with his setup, and after measuring some fairly fresh springs, I can see why. I do, however, like their EHT .675 springs, which have significantly more pressure, and have no issues turning 7k in my personal car with them with the TSP cam.
A lot of folks dont realize that valve springs are a wear item. 12000 miles/1 year and they're pretty much toast with a large/aggressive cam. Had another friend I know pick up 30whp with fresh springs at my suggestion after 20,000 miles on his and low dyno numbers/early tq and hp peak. Go figure |
#28 |
Bring It
Drives: '10 Camaro 2SS/RS LS3 Join Date: Sep 2009
Vortech V3 Si - DELIVERED || Eibach Lowering Springs - Delivered || Black Heritage Grill - Installed || ARH 1 7/8" LT Headers w/ X-Pipe and HF Cats - Installed || C.A.I. Intake - Installed || Hand Ported/Polished TB - Installed || Barton Short Throw w/ Custom Maltese Pistol Grip - Installed || Muffler Delete - Installed || Havoc Spoiler - Needed || A Lot More Money - Needed
Dyno/Road Tuned - 394HP/391TQ |
#29 |
![]() Drives: 2010 Camaro 1SS/RS Join Date: Jan 2011
I just had mine installed, but I did get the .675 springs so in 12K miles I let you know, I usually do that in 8 months!!
TSP Cam 231/236 112 LSA,TSP UD,Fast 102 w/Ported TB,AirAid CAI,1 7/8 catted Stainless Power LT,3 IN MBRP 3 in Exhaust/180*,Spohn LTA's,Toe Links, Drag Bar,Diff bushings,Hurst shifter,Hendrix/DSS 1400HP Axles,Nitto NT555R's,Lethal Performance Custon Tune 480 RWHP 454 RWTQ!! Best run so far is 11.94@121 LPE 3.91's Coming soon NW 102, and DSS DS, then car should be complete!!!
#30 |
![]() ![]() ![]() ![]() Drives: Camaro Join Date: Apr 2009
That is true my car did have a failure from a old version on the 675. The previous run of 675 springs were the ones that occasionally failed. Relative to the number of spring kit sold it was a very small number.
The newest 675 spring has only had 1 failure in my last run of 20,000 springs. Do the failure percentages on that! Sorry Sam.. After years and years of you always talking crap on tsp isn't it time for you to move on? People on this site are very smart, we all understand that over a run of springs this large if tons of them were failing it'd be all over the forums. Last edited by Jason 98 TA; 05-19-2011 at 07:58 AM. |
#31 | |
Edelbrock E-Force
Stainless Works Lts Roto Fab CAI Magnaflow Street Cat-Back DOD Delete Forgestar F-14's and Pedders XA + PKG Custom grind cam from Cincy Speed ADM dual fuel pump ADM AF/Boost gauges FTI 3200 convertor Hurst shifter Cincy Speed Build and Tune 540rwhp |
#32 |
Here's a perfect example for you Sam.
Somebody has another spring failure from a different company and rather than add any help to the thread you just try to stir the pot and ask if it's a prc spring http://www.camaro5.com/forums/showthread.php?t=132873 The guy obviously said who's spring and that it was a single beehive. Sadly you couldn't even notice that because you can't see through your hatred for tsp. It's sad really.. |
#33 |
Sorry ovenmitt I misses your post. I have good news for you on the .650". We made a update to the 650 lift spring to the next run that will give us a small bump in pressures and give you a liitle more lift capability. I'll get ya some more data when I get back to town!
#34 |
![]() ![]() Drives: 98 WS6 Join Date: Jul 2009
We have installed 1000's of PRC .650 lift Springs with ZERO failures.
#35 | |
#36 | |
![]() Drives: 2010 Camaro SS Join Date: Mar 2010
Sold 2010 IBM 2SS RS / LG G6X3 Cam / 1 7/8" Kooks headers / Hi-Flo Cats / ADM Cold air / Magnaflow 3" exhaust / UD Pulley / Sam Miller Tune / SAE 481RWHP 441RWTQ / Eibach Pro-kit / Eibach front and rear sway bars / Elite Catch Can / DRL Harness and AAC Plasma bulbs
#37 |
![]() Drives: 2010 2ssrs Join Date: Nov 2010
I read alot too and yourself and Sam always bash this guy.you guys have provided myself and many other members some really good info.I understand that ptv on LG cam is way tighter than the norm and maybe Jason is just trying to keep somebody from making a mistake with his or hers setup.You guys know what it takes to keep that cam from having issues with clearence but Jason deals with alot of people who are not possibly as mechanically inclined and could easily install low quality springs ,wrong gasket or whatever.Then they have a new car with junk for a motor.Cut the guy a break,lifes too short!!!
#38 |
Wow this has gone too far! If there is a PTV clearance issue then people should be warned, if they still want the cam they are gonna get it! At least know about the issue helps them ask to get it fixed during the installation! Really though I love the TSP Products and their prices, my neighbor loves the LG cam, but if his car makes less power than mine he will never hear the end of it from another neighbor of ours! TSP keep doing what you're doing and customers like myself will keep coming back! If someone is hating on you then you have to be doing something right! Not saying that LG isn't but I would much rather have your stuff! So keep working on those heads so Lethal can make my car faster when I get home from Iraq!! Thanks Jason!!
#39 |
![]() Drives: Ls3 Join Date: Mar 2011
What springs TSP recommends for 231/236 cam?
#40 |
NorCalCamaros.com
I've done countless hours of cam research and reading. What I have come up with is if I wasnt to purchase the 231/236 TSP Cam over any other cam on the market I would be an idiot....PERIOD
Jason |
#41 |
NorCalCamaros.com
I'm even more curious in this new cam you guys are currently working on which is a tad bit larger? When will we know more?
Jason |
#42 | |
#43 | |
Did your PRC 675 spring keep the intake valve from breaking off the stem and destroying the motor in Gregs car? Ill answer for you. No it did not. |
#44 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Truck Join Date: Mar 2010
I have a custom grind that is very close to the 231/236 and I have to tell you I love it.
Texas speed LT Headers and High Flow Cats, Magnaflow 3 inch cat-back Exhaust, SNL V2 Comp CAM, Texas Speed Underdrive Pully, G5CR CAI, Hurst Short Throw Shifter, JetFlo Mass Air Sensor, Custom Grill, Amber AAC Headlight and Fog Light Halo, Amber footwell Lighting, Amber under hood lighting, RK Sport Ram Air /Heat Extractor Hood and ADM Racing Scoop. 447.9 RWHP 428 TQ
My car is exactly that, No one has to like it but me! |
#45 |
![]() Drives: C6 Z06 Join Date: Nov 2010
You guys should fist fight and just end the forum banter.
#46 |
Like us on Facebook!
![]() Drives: C5 corvette/ 2012Dodge hemi Charger Join Date: Oct 2010
cage match in a pool of baby oil lol
Both are great selections. Big cams are going to loss some bottom end. Get a tighter LSA, that helps, or just get gears. You want a race car, just spend the money. Get dual springs My current cam which has been in the car for about 4 years is the TSP 228R, but I almost went with an LGx3. best advice you are going to hear is right here......................... select what cam you want and is perfect for you, then buy the next size larger so you wont have to change it out twice.
#47 |
either way you go will be a good cam, both cams are excellent from what i have seen on this board. as far a ptv clearance both are large cams with a high lift so ptv will be close on either cam. as tampa tuning said find the right one for you.
my youtube
my facebook www.myspace.com/1djchampagne www.twitter.com/1djchampagne mods: borla long tube headers, borla atak catback, lingenfelter gt-9 cam, ported heads, ecs base kit running 11 psi on top end, 1" bmr drop spring, aam 3.70 gears, ported throttle body, 160* thermorstat, lethal racing tune 750/641 rwhp/rwtq |
#48 |
Only drives on Sundays
Drives: 11 2SS/RS, Black/Inferno, L99 A6 Join Date: Feb 2011
I take it PTV is not a problem on L99's with their valve-reliefs?
Padre |
#49 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Camaro 2SS/RS Join Date: Jul 2009
Can I ask what ptv is?
2LT/RS M6 CGM VIN#53104 SOLD
2012 Black 2SS/RS w/ Hurst- Mods: Corsa catback, SSE, Vararam |
#50 |
![]() Drives: 2010 Camaro 2SS Join Date: Jun 2010
Piston to valve clearance
| Thread Tools | |
| Tax Time Specials at TEXAS SPEED! | Jon@Texas-Speed | Sponsor Announcements / Giveaways / Contests | 1 | 05-19-2011 04:10 PM |
| Acronyms? | KEEP RT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 03-11-2011 08:57 PM |
| Texas Speed 231/236 112 LSA cam kit for sale. (brand new still in box) | Oxtar41 | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 9 | 03-02-2011 11:05 AM |
| Texas Speed and Modern Muscle Review (long) | fuffl | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 11 | 02-06-2011 09:44 AM |
| Texas Speed exhaust | NOS2GO | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 3 | 01-02-2011 10:20 AM |
