SDTW Custom Wheels & Tires
Old 05-29-2011, 03:32 AM   #43
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
going to buy a few cans and do the LS7 blackouts this weekend hopefully
Just peel the tape off as soon as possible right? lol
CAMARO
Old 05-29-2011, 06:50 AM   #44
The Stig
knows 2 facts about ducks
The Stig's Avatar
Yep
Click to view my build thread
Old 05-29-2011, 03:54 PM   #45
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Yep
Now to find plastidip in Canada
CAMARO
Old 05-29-2011, 06:31 PM   #46
CruiseControl
CruiseControl's Avatar
Drives: 2010 Camaro 2SS/RS L99
Home Hardware
CruiseControl is offline   Reply With Quote
Old 06-06-2011, 09:59 AM   #47
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Originally Posted by CruiseControl View Post
Home Hardware
you are a champ!
CAMARO
Old 06-12-2011, 11:57 AM   #48
Tx1Lt
Mark it ZERO!
Tx1Lt's Avatar
Drives: '10 Black Camaro
Damn, should have read tip 17 yesterday. Lol
Tx1Lt is offline   Reply With Quote
Old 06-12-2011, 12:12 PM   #49
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
On a black car, Clear-bra may have some competition.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 06-12-2011, 07:56 PM   #50
evilbumbblebee
evilbumbblebee's Avatar
Drives: 2LT 2011 camaro blk w white rally
Can you spray paint over plastic dip?
evilbumbblebee is offline   Reply With Quote
Old 06-12-2011, 08:38 PM   #51
The Stig
The Stig's Avatar
I actually wasn't sure of this when I first read it. But I asked around and searched the internets. The answer is really two-fold.
Yes, as plasti-dip hardens into a plastic you can *technically* paint over it. I say *technically* because their is the possibility of the paint cracking, etc etc. But, you are still able to peel off the plasti dip. The only downside is that it does make the removal a lot harder. But still possible. Downside is I don't know how you would remove it. From what I read you would still just do the peel it off with your hands method. But, you just need to find a way to chip/break the paint off first.
Old 06-12-2011, 08:46 PM   #52
derek19
derek19's Avatar
Drives: 2011 1LT RS
http://www.plastidip.com/home_solutions/Plasti_Dip
I know the site says won't crack, melt, blah blah blah in temperatures between -30 to 200 degrees. I live in memphis and it get f'ing hot in the summer. Does anyone think the heat will be an issue?
derek19 is offline   Reply With Quote
Old 06-12-2011, 09:06 PM   #53
derek19
derek19's Avatar
Drives: 2011 1LT RS
Do ya'll think black rims would look right with the color of my car? My car is IBM with white stripes down the middle.
Old 06-12-2011, 09:19 PM   #54
The Stig
The Stig's Avatar
If you paint it in a slightly controlled enviorment you should be fine. Basically, when you paint plasti-dip it is the same as any other spray paint/painting process.
Old 06-12-2011, 09:31 PM   #55
derek19
derek19's Avatar
Drives: 2011 1LT RS
I'm not necessarily worried about when applying it, i'm more worried after its on. It almost averages 95 degrees here in memphis during the summer and i'm just worried about it peeling or cracking because of the constant heat.
Old 06-12-2011, 09:50 PM   #56
The Stig
The Stig's Avatar
Well I read up a bit more on plasti-dip and checked out its certification, etc etc. Basically the temperature range of -30 to 200 is for plasti-dip in its solid (hardened) form. So it would take a pretty hot day to get the plasti-dip to a high enough temp that the chemical bond structure would break up (the bond structure is what gives plasti-dip the tough/rubberly/plastic feel to it. So in short, you should be fine. I wouldn't worry about the heat.
so going to plasti dip tomorrow Allan Hernandez Cosmetics and Lighting Modification Discussions 39 05-17-2011 03:02 PM
Plasti dip bezels puertoricanfont Cosmetics and Lighting Modification Discussions 53 03-03-2011 04:43 PM
Those that have used Plasti Dip on rims KybheSS Wheels and Tires Talk Sponsored by The Tire Rack 0 01-28-2011 04:47 AM
Plasti dip LosXC451 Cosmetics and Lighting Modification Discussions 9 09-20-2010 08:44 PM
