Old 06-12-2011, 10:14 PM   #57
derek19
derek19's Avatar
Drives: 2011 1LT RS
Well I read up a bit more on plasti-dip and checked out its certification, etc etc. Basically the temperature range of -30 to 200 is for plasti-dip in its solid (hardened) form. So it would take a pretty hot day to get the plasti-dip to a high enough temp that the chemical bond structure would break up (the bond structure is what gives plasti-dip the tough/rubberly/plastic feel to it. So in short, you should be fine. I wouldn't worry about the heat.
Thanks man, appreciate it.
Also, your car looks good. Love the lights.
derek19 is offline   Reply With Quote
Old 06-13-2011, 04:52 AM   #58
destroyerofu2
xbox360 tag
destroyerofu2's Avatar
Drives: 2010 inferno orange 2SS
Well I did some more plasti sergery
did the top and bottom of the front lip
did the lower side and inset body line
(not sure if i like the inset body line yet)
lower side all the way around
cant really tell from pictures but about the lower 2-3 inches is black on the sides from front to rear
Originally Posted by babytiger
And like destoryerofu2 said, WOT should be a moment of silence...
It's mine, like it or not. http://www.camaro5.com/forums/showthread.php?t=108079
destroyerofu2 is offline   Reply With Quote
Old 06-13-2011, 08:00 AM   #59
destroyerofu2
xbox360 tag
one more
Old 06-14-2011, 12:37 AM   #60
YOUNGnRECKLESS
Building the Beast
YOUNGnRECKLESS's Avatar
Drives: 2010 VR LS3
wow, props for tryin everything out! looks really good. time well spent for sure. im a fan of plstidip, but have yet to venture into the body painting realm with it. im dying to do the ls7 style blackouts, but now i may try plastidip first to see how i like it, then pro paint
YOUNGnRECKLESS is offline   Reply With Quote
Old 06-14-2011, 03:56 AM   #61
destroyerofu2
xbox360 tag
its real easy to work with i am loving it
Old 06-14-2011, 09:55 AM   #62
TonyNo
TonyNo's Avatar
Drives: 2016 2SS, SW
destroyerofu2: Any tips on masking with this stuff?
TonyNo is offline   Reply With Quote
Old 06-14-2011, 11:57 AM   #63
pyledrivr
SW
pyledrivr's Avatar
Drives: 2011 Camaro Summit White
I plasti-dip my trunk today. I thought it turned out really nice. PIA taping around the bowtie ended up doing it twice. I didn't like the edges first time.
2011 Summit White LS
pyledrivr@hotmail.com
pyledrivr is offline   Reply With Quote
Old 06-14-2011, 12:04 PM   #64
destroyerofu2
xbox360 tag
i am just using masking tape 2" and 1/4"(for the bends) and trash bags
I tape it all off with desired shape add cut up trash bags to surrounding area and,
if small area spray light coat give about 30 seconds, then heavier coat, 30 seconds and another heavy coat, then pull tape as quick as possable.
if big area spray light coat starting at one side working way to other side (long ways), as soon as done with that coat start next coat heavy same spray patern(no waiting), as soon that is done, do next coat heavy making sure to cover everything, then pull tape as quick as possable
the key is to pull the tape and not let it dry to the tape.
dont be worried if you have some runs or a few ruff edges, a few min after you pull tape then check the edges for runs and just rub them off
TIP: when rubbing off the ruff edges and runs a plastick decal squige is good to put on your line(using the pointy part to mark your line and rubbing below the squige), then you dont have to worry about rubing into the part you want to keep.
I have to do the other side of the car tonight (just did one side to see if i liked it) so i will tke pictures and post those up.
heres the side i already did
sorry for the fingers it was bright out
Old 06-17-2011, 10:11 PM   #65
seddon
seddon's Avatar
Drives: 2017 ZL1
any pics of the tail light bezel using plastic dip
seddon is offline   Reply With Quote
Old 06-18-2011, 09:33 AM   #66
camaro_RS
Emerald Coast Camaros
camaro_RS's Avatar
Drives: A lot of show, not much go.
Looks bada** man! Well done!
-White Mary Jane....build thread [COTW 6/11/12] :
camaro_RS is offline   Reply With Quote
Old 06-18-2011, 09:36 AM   #67
rareslick
rareslick's Avatar
Drives: IOM 2SS
rareslick is offline   Reply With Quote
Old 06-18-2011, 02:41 PM   #68
seddon
seddon's Avatar
Drives: 2017 ZL1
thanks
Old 06-18-2011, 03:08 PM   #69
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
That is nice but I am too much of a chicken shit to try that out
CAI intake/ADM Scoop/Stainless Power Headers/Doug Thorley Catback Exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ Tuned by ECS. 428hp/426tq
mydreamcar is offline   Reply With Quote
Old 06-20-2011, 04:44 PM   #70
shevyman
Drives: 2010 Camaro SS IOM
Originally Posted by destroyerofu2 View Post
one more
ok my question to you is what kind of tape did you use to get the lines you wanted? second how long did you wait to peel the tape off?
cause for me all i had at the moment was painters blue tape. so i worked with it and got the lines i wanted on my car. i did three layers of plasti dip. about 30 mins or more in between layers like the can said. but here is where i messed up. i waited maybe 2 hours or and a half hours and then went and tried to remove the tape. well the paint was stuck to the tape and it peeled the plasti dip. any advice? should i have let it sit over night?
ok i just saw your last post.. so you used the trash bags to protect your paint right? not to help with the lines. so i guess do my three layers right away and then tear off the tape asap.
shevyman is offline   Reply With Quote
so going to plasti dip tomorrow Allan Hernandez Cosmetics and Lighting Modification Discussions 39 05-17-2011 03:02 PM
Plasti dip bezels puertoricanfont Cosmetics and Lighting Modification Discussions 53 03-03-2011 04:43 PM
Those that have used Plasti Dip on rims KybheSS Wheels and Tires Talk Sponsored by The Tire Rack 0 01-28-2011 04:47 AM
Plasti dip LosXC451 Cosmetics and Lighting Modification Discussions 9 09-20-2010 08:44 PM
