IPS Motorsports
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 05-20-2011, 06:56 PM   #26
caverman
caverman's Avatar
Drives: '69 SS Convertible
Originally Posted by BowenSS1 View Post
Come on guys!! This thread should be packed by now with cammed up
camaros!Im ready to do mine ls3 conv. but picking the cam is the only thing holding me backone of the tuners suggested a
236/244 on a 112lsa .617/.612 lift anyone running something like this.
You should look at one of TSP's VVT cams. Get rid of the AFM but not VVT.
Build Journal
caverman is online now   Reply With Quote
Old 05-21-2011, 12:04 AM   #27
Ivan @ Southwest Speed
Southwestspeed.net
Drives: '10 2SS/RS, '96 Z28
I'll play.
Ivan
Old 05-21-2011, 03:15 PM   #28
Tshepp
Show & Go
Tshepp's Avatar
Drives: '10 Camaro 1SS LS3
Originally Posted by mikeSS View Post
mine
mikeSS - what is in that beast?!
Tshepp is offline   Reply With Quote
Old 05-21-2011, 03:42 PM   #29
mikeSS
mikeSS's Avatar
Drives: 2013 E92 M3
kooks LTs, CAI, corsa, JRE cam
Old 05-21-2011, 05:01 PM   #30
Blueclyde
Blueclyde's Avatar
Drives: 2012 ZL1
2012 ZL1, GBA, M6, ECF, Black 10 Spokes
Blueclyde is offline   Reply With Quote
Old 05-21-2011, 05:17 PM   #31
Never Satisfied
220/221 whatever it takes
Never Satisfied's Avatar
Drives: '10 1SS/RS M6 SW/Black
Ok, I tried a little bit better camera this time. It's still not great, but better than my cell.
2010 Summit White 1SS/RS M6
Roto-Fab CAI, MNM 224/236 114, UD Pulley, VMax TB & Intake, Kook's LT's w/ Cats & X, Kook's Ex, Pedder's Xa Coilovers, UMI Trailing Arms, UMI Toe Rods, BMR Subframe Bushings, DSS 9" kit w/ 4.57's, MNM DynoTune 479rwhp/451rwtq 12.03 @ 121.62mph (1.9 60')
Never Satisfied is offline   Reply With Quote
Old 05-22-2011, 09:33 AM   #32
BowenSS1
BowenSS1's Avatar
Drives: summit white ss2
THAT SOUNDS VERY GOOD, CRISP AND CLEAR!
THATS WITH THE FULL KOOKS EXHAUST?
BowenSS1 is offline   Reply With Quote
Old 05-22-2011, 09:41 AM   #33
BowenSS1
BowenSS1's Avatar
HERES ONE THAT I LIKE
Old 05-22-2011, 10:07 AM   #34
Never Satisfied
Thank you.
Yes, the entire Kooks system part #6511. (1 7/8" Headers, 3" Catted X-Pipe and Kooks Mufflers)
Old 05-22-2011, 10:54 AM   #35
CamaroCowboy
CamaroCowboy's Avatar
Drives: 2013 Chevy Truck
I'll play.....I'm in Afghanistan right now and cant remember how to imbed but here is the link.
My mods are in the signature
Texas speed LT Headers and High Flow Cats, Magnaflow 3 inch cat-back Exhaust, SNL V2 Comp CAM, Texas Speed Underdrive Pully, G5CR CAI, Hurst Short Throw Shifter, JetFlo Mass Air Sensor, Custom Grill, Amber AAC Headlight and Fog Light Halo, Amber footwell Lighting, Amber under hood lighting, RK Sport Ram Air /Heat Extractor Hood and ADM Racing Scoop. 447.9 RWHP 428 TQ
My car is exactly that, No one has to like it but me!
CamaroCowboy is offline   Reply With Quote
Old 05-22-2011, 10:55 AM   #36
CamaroCowboy
well now they changed it....nice
you used to have to put special stuff in the front and back of the link to embed.......that is much easier....
Old 05-23-2011, 03:20 PM   #37
blk5genss
blk5genss's Avatar
Drives: 2010 Camaro 1SS/RS
I live in cove too I think we spoke at Taco Bell one day, car came out nice! I'm in Iraq but will be home soon I hope!!
TSP Cam 231/236 112 LSA,TSP UD,Fast 102 w/Ported TB,AirAid CAI,1 7/8 catted Stainless Power LT,3 IN MBRP 3 in Exhaust/180*,Spohn LTA's,Toe Links, Drag Bar,Diff bushings,Hurst shifter,Hendrix/DSS 1400HP Axles,Nitto NT555R's,Lethal Performance Custon Tune 480 RWHP 454 RWTQ!! Best run so far is 11.94@121 LPE 3.91's Coming soon NW 102, and DSS DS, then car should be complete!!!
blk5genss is offline   Reply With Quote
Old 05-23-2011, 03:23 PM   #38
mikeSS
mikeSS's Avatar
Drives: 2013 E92 M3
well thats how most forums are.
Old 05-23-2011, 03:32 PM   #39
Mustang Killa
Mustang Killa's Avatar
Drives: Black 2SS
Which JRE cam did you go with?..Sounds like a monster
Mustang Killa is offline   Reply With Quote
Old 05-23-2011, 03:59 PM   #40
SilverSS3108
SilverSS3108's Avatar
Drives: 2010 silver SS
Any one running the Texas Speed VVT 3 cam?!
SilverSS3108 is offline   Reply With Quote
Old 05-23-2011, 04:50 PM   #41
nuptualnemesis
NuptualNemesis
nuptualnemesis's Avatar
Drives: Silver 1SS M6 - 480hp 11.57/120.79
Yes, you need a 4:33 gear and more compression to run this. You also need good springs like comp cams duel spring steel tool and upgrade the trunion bearings in the stock rocker arms. Patriot gold springs are not enough for this cam. Good thing about cam is it has no rpm drop on top, it just pulls and pulls. The higher I rev the faster I go. Currently shifting at 7,000 rpm. (But rev limiter set on 7,200 and I have hit it) You can probably get better average hp and close to the same max hp with a 231/236 and 113LSA or even 114LSA and it is much more streetable. I am about to cam mine down a little.
With out gears there is a lot of buck and surge below 1,500 rpm. Now I shift 1st, 3rd, 5th around town @ 2,000 rpm. Only lost 2mpg at 70mph with cam and 4:33's. But the cam kills my MPG sitting idling at red lights i.e., 10 to 11 mpg in constant stop and go. Big city lots of long lights up to two minutes each. Now trapping around 6,400 rpm in fourth in the quarter. Really wakes up the 60ft too, but keep the stock clutch ( I lost .2 on 60 ft with Ram HD clutch and finally put my old clutch back in). A 3:70 is a waste of time in an M6.
CORRECTION: I did not realize you have an automatic. The gear ratio is different and a 3:90 is probably the highest you want to go. LPE has a good one out now. A stall will also help tame the cam.
nuptualnemesis is offline   Reply With Quote
Old 05-23-2011, 05:20 PM   #42
mikeSS
mikeSS's Avatar
Drives: 2013 E92 M3
the 445WHP street cam rough idle one.
Old 05-23-2011, 06:47 PM   #43
Chad's 2ss
Chad's 2SS
Chad's 2ss's Avatar
Drives: Yellow 2SS
I have a question about the cams. What actually does the cam do for the car, and I want that "cam sound" but I live in Cali so I can't really get headers put on because of the smog laws, but I have my 2ss with electric cutouts on my stock exhaust and I have my cold air induction. Could I achieve this sound from getting a cam with what I have now. And how much are CAMs? Thnks.
Chad's 2ss is offline   Reply With Quote
Old 05-23-2011, 07:05 PM   #44
Tshepp
Show & Go
Tshepp's Avatar
That is so mean! I cannot wait to finally choose a darn cam!!
Old 05-23-2011, 08:06 PM   #45
Huggerorange73
Banned
Drives: The REAL C5
Send a message via AIM to Huggerorange73
Just shot this one today
Huggerorange73 is offline   Reply With Quote
Old 05-23-2011, 09:03 PM   #46
Pollock
LS3 M6
Pollock's Avatar
Drives: 2011 2SS/RS
Nice!!
JRE 470 RWHP Cam, UD pulley, Kooks 1 7/8 Headers w/high flow cats, PCV catch can, Black CAI, ADM racing Scoop, Flowmaster AT Cat Back, VMax TB, BMR Trailing Arms
Pollock is offline   Reply With Quote
Old 05-25-2011, 07:58 PM   #47
Tshepp
Show & Go
Tshepp's Avatar
SAME HERE!! Grrr...I need to just pick a cam. I have heard the 231/236 loses low end tq and really makes power in the higher end, I wouldnt think this is a cam for a normal street car then...
Old 05-25-2011, 08:15 PM   #48
shadow09
H-Town Camaro Club
shadow09's Avatar
Drives: 2010 Camaro SS LS3
I can't wait to install a cam sometime this year sound so much better that way
shadow09 is offline   Reply With Quote
Old 05-25-2011, 09:33 PM   #49
Chad's 2ss
Chad's 2SS
Chad's 2ss's Avatar
Drives: Yellow 2SS
Old 05-25-2011, 10:19 PM   #50
CamaroCowboy
If you are talking about when we talked about the diablo tuner you had then yes that was me.
Get home safe.....I will try to do the same.
Thank You for the compliment. I really like how everything has turned out so far also. I have a few more things planned for when I get back in October for R & R.
Another L99 cam question....VVT! SS-screamer Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 90 06-28-2010 06:41 PM
Cam Headers Intake Tune 446 RWHP 430 RWTQ JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 72 11-25-2009 03:09 PM
