sjm autoprod
Old 03-06-2009, 10:23 AM   #1
Isaacnc
SS Kid
Drives: 2002 Camaro SS/2010 Camaro SS
Exclamation Will LS3 aftermarket parts work with L99?
Hey guys,
I am getting a L99 (automatic) Camaro SS and I was wondering if the LS3 aftermarket parts will work and fit for my SS or are they going to make seperate parts for LS3 & L99. What do yall think/know?
Ordered Feb. 1st: 2010 Camaro SS Inferno Orange Metallic
Isaacnc is offline   Reply With Quote
Old 03-06-2009, 10:29 AM   #2
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
I think you will have to be careful with any valve train modifications. As the valve setup on the L99 is set up for the AFM. Otherwise you should be pretty safe with LS3 aftermarket parts.
Old 03-06-2009, 01:54 PM   #3
JJ#48Racing
Drives: 1998 Camaro SS
Short answer is some will, some won't. Most of the different parts are in the valvetrain.
JJ#48Racing is offline   Reply With Quote
Old 03-06-2009, 04:20 PM   #4
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
bolt-ons will all interchange. actual engine modification, no.
meaning, CAI, exhaust, headers, t/b, fuel injectors, etc will all interchange.
cams, rockers, heads, etc will need to be specific for the L99
I piss excellence
and fart awesomeness
Old 03-06-2009, 10:25 PM   #5
mike@newera
mike@newera's Avatar
Drives: 2016 Camaro SS
For the most part, this will be true depending on the internal component. Stay tuned, we just ordered our project Camaro 2ss for testing, which will include product development for this platform (specifically the Auto with AFM/VVT) as we have done with the G8GT and then some.
mike@newera is offline   Reply With Quote
Old 03-06-2009, 10:28 PM   #6
meanmike
Drives: FIRST ON RACE DAY
How do you find the time? Your alway's on g8 board and now here.
meanmike is offline   Reply With Quote
Old 03-06-2009, 11:16 PM   #7
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
you can always delete the afm and vvt on your l99 and convert it to ls3/2 parts, pretty simple swap and with software like hp tuners or efi-live you can delete out the afm/vvt from the ecm
my L99 is coming out right away and a LS3 is going in!
Old 03-07-2009, 01:18 AM   #8
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
How does the AFM work? Is the crank split when the cylinders shut off, or is the EFI and valves deactivated in the valvetrain and fuel delivery system during AFM mode? If so it'd just be a valvetrain swap, and ECM recalibration as you said, correct?
Zabo is offline   Reply With Quote
Old 03-07-2009, 04:52 AM   #9
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
so the rockers are different on th l99 so aftermarket ls3 rockers will not work, correct?,anyone know why this is, is it because of the afm?
Gentry78 is offline   Reply With Quote
Old 03-07-2009, 08:33 AM   #10
camaro1
camaro1's Avatar
here is what you need to do to eliminate the afm/vvt and turn your l99 into a ls3 with your choice of camshaft
-choose a cam(any LSx 3 bolt)
-Get the correct length pushrods for your cam(LSx engines have non adjustable rocker arms and the lifter pre-load is set by using longer or shorter pushrods)
-get valve springs to match your cam(pac1218 or pac1518 are great beehive springs and are a direct swap)
-swap the cam sprocket(LS2 with 4x)
-swap the front cover(LS2/LS3 will work)
-swap the lifters(LS2/3/7)
-swap the lifter retainers(LS2/3/7)
-swap the valley cover (LS2/3 will work as long as it has the o-ring's to block off the afm towers in the valley)
buy hp tuners or efi live or have someone dyno tune and remove the afm/vvt from the ecm
Old 03-07-2009, 09:28 AM   #11
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
Or buy an LS3 car!
ZZcamaro is offline   Reply With Quote
Old 03-07-2009, 10:46 AM   #12
mike@newera
No, the rockers are the same, the lifters are different. We are getting the automatic because it has VVT/AFM, we developed camshafts to work with AFM aready, for the camaro we are going to get rid of AFM and create some custm cams to work with VVT, there are some pretty big advantages to having this VVT option, and I think that with tuning the VVT will make more power everywhere.
Old 03-07-2009, 10:49 AM   #13
CamaroSpike23
Truth Enforcer
awesome. thanks for the heads up. now I know who to hit up with questions for tuning with AFM.
I piss excellence
Old 03-07-2009, 11:24 AM   #14
1320junkie
Drives: The Imperial Army
Originally Posted by ZZcamaro View Post
Or buy an LS3 car!
camaro ss, l99, ls3
This site is like crack. You know you're addicted to Camaro5 when... GameOver620 5th Gen Camaro SS LS LT General Discussions 463 01-03-2011 03:28 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
And Another Car Crash... GTAHVIT Off-topic Discussions 73 01-12-2009 12:43 PM
LS376/480 EFI LS3 Gen IV V-8 NOODLESgoneWILD Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 09-04-2008 09:14 AM
LS3 Specs, and Descriptions Mr. Wyndham Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 11-06-2007 02:04 PM
