Old 05-24-2011, 03:47 PM   #1
Inuyashas_Brother
Inuyashas_Brother's Avatar
Drives: '10 Camaro LS - M6
Question Do I really need sway bars?
A bit of background: I have installed new high performance tires and Im planning on getting lowered springs. I enjoy spirited driving but do not plan on autocrossing. I have been trying to educate myself on the issue of understeer and how sway bars work, and from what I found it seems that understeer is only a problem if you push your car past 7/10s which is going beyond spirited driving into autocrossing levels.
Therefore, for my driving style, it seems lowering springs, in addition to the grip from my new high performance tires, are enough to provide me the additional handling benefits, and a sway bar would add little to no benefit.
Is my analysis correct or did I miss something?
Thanks!
Inuyashas_Brother is offline   Reply With Quote
Old 05-24-2011, 03:58 PM   #2
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
So....do you really need any modifications?.....No, not really! But that's what we enjoy doing anyway. You will probably see a noticeable difference in handling (even on the street) with stiffer sway bars. Is it a necessity for street driving?.....No! Is it an enjoyable addition?.....Yes!
blazzin1 is offline   Reply With Quote
Old 05-24-2011, 03:59 PM   #3
S-eatin-grin
S-eatin-grin's Avatar
Drives: 2013 2SS/RS AGM
No...I think you are right on the money with your analysis. Given your power level (and I'm not V-6 bashing) the stock suspension will handle it...the wheels and springs should suffice....if you wanted to do something else I'd say rear cradle bushing inserts and front radius bushing inserts...pretty simple install...pretty low cost as well.
S-eatin-grin is offline   Reply With Quote
Old 05-24-2011, 04:00 PM   #4
Neriah
Neriah's Avatar
Drives: 2011 2SS/RS
Built By Blu808
LG G6X3 Cam, UD Pully, Rotofab Intake.
Dynatech LT's. Borla ATAK Catback.
Full BMR bushings and suspension.
Neriah is offline   Reply With Quote
Old 05-24-2011, 04:02 PM   #5
JEP
JEP's Avatar
Drives: 2010 SIM Camaro 2SS 6speed
That is a good question. I'm pondering the same thing.
After doing about 2 weeks of research/reading forums on this topic and calling a few vendors I'm coming to the conclusion that it's hard for me to explain to them exactly what kind of ride I'm looking for.
I want to reduce body roll (sways/harder springs), but don't want to overdo it.
In my opinion, from what you've posted, you have the right idea to start little by little.
Try the drop springs with your tires and see if it's enough.
I'm probably going to do springs and sways (front and back adjustable) and dial in the stiffness to my liking.
Lowering with springs will help, but in my case, I came from a Corvette C6 which was tightly suspended, and the Camaro is just too sloppy for me so I'm doing both.
Let us know how it turns out, and I will also report back in a few weeks once I get this stuff installed:
drop springs (Pfadt)
adjustable sways (not decided, I want adjustable and Pfadt only rear is adj)
sway bar end links (whichever sways I go with)
rear control arm mounting brace (BMR)
hope this helps, and good luck
JEP is offline   Reply With Quote
Old 05-24-2011, 04:30 PM   #6
Inuyashas_Brother
Thank you all for your input!
Funny thing is my last car was a Celica GTS and even I find the Camaro's suspension spongy
Old 05-25-2011, 12:50 PM   #7
RichJ.
Shop Owner
Drives: 1 ton silverado
Foundation Foundation Foundation we feel the first step should be Rear sub fram inserts from Pedders. It will help the rear step out more than any other mod.
RichJ. is offline   Reply With Quote
Old 05-25-2011, 01:01 PM   #8
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Rich is 100% correct. Start your 5th Gen mods with the foundational elements.
Sub-frame bushes or inserts
Radius Bushes or inserts
These are the components that make EVERYTHING else on your ZETA II 5th gen work better. Control the rear sub-frame to is how you control rear end step out -- the looseness you feel in the rear of your 5th Gen. Reducing unwanted castor changes with radius bushes or inserts improves your steering wheel feel. It becomes more precise or on center. Adding lowering coils, more RWHP or stickier tires or whatever only makes matter worse until you address the foundation.
Star with the foundation. A large number of 5th gen owners have found it is all they need to do. We'll others become addicted and suspension fever sets in
Old 05-25-2011, 03:10 PM   #9
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Thanks!
If I had one modification to do to a Camaro5, it would undoubtedly be a set of sway bars. Sway bars have an effect when ever there is a rolling moment on the vehicle, not only when the car is being driven aggressively. You will find more confidence in corners even before the tires start breaking away because the car wont roll and wallow into corners as much.
As you increase the amount of mechanical grip you have by installing stickier tires, your car will actually exhibit more body roll than it already does since your limits are now higher. Aftermarket sway bars don't have a huge effect on ride quality but make the car feel much tighter and in control than the stock bars. You don't need to be pushing the car past reasonable street limits to notice a big difference in sway bar packages.
If you have any questions please don't hesitate to ask. We feel that sways make these cars feel so much more confident without compromises in ride quality that they're a must do for our personal cars.
Jarrett
Old 05-25-2011, 03:20 PM   #10
Synner
Drives: not stock
I think the stock sways are more of a limiting factor than the stock tires. I definitely feel body roll way before I think my tires are going to give loose. And grippier tires and springs won't fix understeer although the springs will help with weight transfer.
Old 05-25-2011, 05:14 PM   #11
JusticePete
VIR Specialist
If you set a fence post in Jello does it make any difference if the fence post is made of pot metal or titanium? It doesn't. No matter what the fence post material they will shake like Santa's belly.
The same is true on your 5th Gens. Every 5th Gen has rear end step out and significant dynamic caster changes the moment it rolls off the assembly line.
Add bigger bars -- rear end step out becomes more pronounced.
Add stickier tires -- rear end step out becomes more pronounced.
Add more RWHP -- rear end step out becomes more pronounced.
Notice the pattern? While the IRS sub-frame bushes are far from Jello, they are deeply voided for control of Noise Vibration and Harshness (NVH). It was a benchmark for the new 5th Gen -- Library Quite. Quiet is perceived as quality. The efforts to makes the 5th Gen as quiet as the target resulted in some loss in handling qualities. No matter what you driving style, no matter what your level of modification the lowest hanging fruit on a 5th Gen is found in the sub-frame and radius bushes.
Virtually every 5th Gen suspension company makes replacement bushes, braces or bars for the IRS. Why? Because they know as we do it is the single most important upgrade you can make to a 5th Gen. If you already have sway installed, you will notice your 5th Gen drive much better with sub-frame bushes or inserts installed. Have a better than OE tire and wheel package -- you will notice your 5th Gen drive much better with sub-frame bushes or inserts installed. Increased your RWHP -- you will notice your 5th Gen drive much better with sub-frame bushes or inserts installed.
Start with the sub-frame and radius bushes. Create a robust foundation. All your additional mods will work better because you did it the right way. You started with the foundation. You can read all about it in the Book on 5th Gen Suspension.
Old 05-25-2011, 05:24 PM   #12
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Do you need them? No. Will you realize a significant improvement in handling on the street? Yes.
Old 05-25-2011, 06:00 PM   #13
PfadtRacing
Inuyashas_Brother, take a look at a video we did a while ago, in regards to your exact quest for knowledge! This video was a procedure we went through to dial in the correct sway bar rates for the Camaro chassis. As you can see, sway bars are what will control the understeer/oversteer balance most effectively. This video is pretty straight forward to illustrate the example you are looking for, it is a simple 200ft skidpad,and involves steady-state cornering where no transitional forces are acting on the car. Its a pretty cool test to see how to change balance towards something more performance oreinted! Check it out
Old 05-25-2011, 06:08 PM   #14
JusticePete
VIR Specialist
Thanks!
Maybe I misunderstood your post. Can I ask a few questions to gain clarity?
What is it you are not satisfied with as far as the handling of your Camaro?
Better Handling Tbanks Suspension / Brakes / Chassis 30 12-15-2010 12:50 PM
Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H AJ@ECSMotorsports Suspension / Chassis / Brakes 80 11-17-2010 03:28 PM
