Solo Performance
Old 06-06-2011, 07:03 PM   #211
Number 3
Hail to the King baby!
Number 3's Avatar
Drives: '16 ATS 2.0T & '17 Buick LaCrose
Originally Posted by 2cnd chance View Post
Wow, I love it guys!
I go away for a little while and we are in it up to our necks. Hey Number 3 I think the excitement is back!!!
Pete I'm impressed with what you've put together. A stout 427, bulletproof drivetrain, brakes from h**l, wheel/tire combo for grip/less unsprung weight and a track-like suspension. If we can get the pricepoint $42K - $43K I think we're there. And, I fully agree, I want a decent stereo and living in the south you gotta have AC. But for those hardcore guys this can be stripped, by them. Go ahead and allow for some options, but Pete I'm with you keep it simple. As for colors and such this car has to be easily recognized as a different and special Camaro, Yeah a Z28.
Ooops should have multi-posted...........
Yes, if you don't stay on top of these things you could end up with a Z71....................or a Z24
"Speed, it seems to me, provides the one genuinely modern pleasure." - Aldous Huxley Link to Every Camaro photo I've taken in Hi-Resolution
Old 06-06-2011, 07:18 PM   #212
Kahdir
Kahdir's Avatar
Drives: 2010 Chevrolet Camaro 2SS/RS
Here is my run at a build-able Z28 from Chevrolet. It starts with a clearly defined build sheet with no options other than six speed or automatic. Colors are limited to no more than three. I would prefer two colors -- White with Black Wheels and Blue with Yellow Wheels. The cars are built in batches. This is critical because we are deviating from a standard Camaro build. By batching them the line can run with a high level of efficiency as color is the only option.
Engine Choice -- If the LS7 is available at a reasonable price we use the LS7, although a LS3 with a GMPP cam and tune would be good too. My bottom line is we need 500 NA at the crank, or more What I really want is 500 NA at the rear wheels. That means 550 or 560 at the crank. That also means we need heads to go with the cam on the upgraded LS3. I am not sure what it would take on the LS7. I'll accept 500 at the crank, but I would be a drooling idiot with 500 at the rear wheels. LS7 or LS3 doesn't matter as long as we are in the RWHP minimum range of 430.
Weight Reduction -- Everywhere we can from reduced spray in sound insulation - cloth non-power seats - fascia - console - wheels - brakes - exhaust - can you use less paint? No sun roof. No back up camera. The focus is on performance. Wait a minute. Can we replace the side view mirrors with a video display for less wind resistance and the same or less weight?
Wheels and Tires -- You can probably guess 19x10.5 lightweight wheels with 305/30/19s
Gearing -- The smaller rolling diameter wheel and tire package address the gear change, but we'll ask the engineers at Chevrolet to fine tune the gear box ratios for optimal performance
Brakes -- CTS-V / ZL1 calipers with the of the shelf GMPP Brembo two piece front rotors to improve breaking and reduce weight and don't forget the brake ducts
Exhaust -- Titanium borrowed from the Vette. A little more aggressive in tone. This ain't no panty waist machine. We want an edge to it.
Hood and Fascias -- Keep it simple, clean and light. If it doesn't reduce the drag coefficient or add down force it doesn't go on the car. Cold air induction is critical.
Thermal Management -- The LS engine do not like heat and they are furnaces. Lose the sound insulation above the plenum. Lose the engine cover. Lose the hood blanket. Add heat extractors. Coat the cast iron manifold inside and out to reduce heat transfer. Add oil and PS coolers. Can we increase the oil capacity with a new pan? Maybe add a few baffles? Don't forget the diff cooler.
Driveline -- We want the revised ZL1 drive-line since we plan on abusing, err driving this one Change out the lube in the OE CV joints so it doesn't liquefy when running hard laps to a higher temp lube.
Suspension -- Forget the typical OE conservative understeer bias. We prefer axx happier The suspension has to be Pedders Supercars with independent bound and rebound adjustment. We'll address the adjustable ride height with special locking rings that require a special bow-tie track spanner to unlock them. The special bow-tie track spanner is for off road use only In addition to the new revised sub-frame bushes that started in January, we want to add Pedders sub-frame inserts. We'll also use the EP6579 full face radius bush inserts. Pedders extended range alignment bolts are direct replacements for the OE bolts and provide a greater range of adjustment to suit the use of the car. These can all be integrated into the line process. A little trickier are the Toe link bushes. I guess GM will have to ship the OE arm to Pedders and we'll return them with our bushes. Allow me to compliment GM on the ZETA II. The arms are good to go from the factory. They do not need replacement. The arms just need a little assist from Pedders
Steering Wheel -- I love the CTS-V wheel. The ZL1 is close to the CTS-V. We want a wheel with Alcantara for grip. I could care less about the controls on the wheel.
Gauges -- We need real gauges and not simulations of gauges. The oil temp must read from an oil temp sensor with an accurate reading.
Warranty -- We are asking for a lot of performance at the best possible price. I for one would be happy with a 24 month / 36k bumper to bumper. I don't expect GM to cover what I am asking to be built for 100,000 miles on the drive-line. There is a balance to be reached. Deliver me a car that works well. Allow me to beat on it, not run it into the ground, but use it as it was intended to be used for a reasonable period of time. i.e. I was running laps at Harris Hiils. My CV joint failed. Cover my CV joint and allow me to be honest. In exchange I'll take a shorter warranty period.
We have a Z28 that is a very different car from my wife's ZL1. It should sell well and compliment SS and ZL1 sales, b ut that is just my opinion.
I like the way you think...
I'm guessing the ZL1 will be $55,990ish, so the Z/28 can be $42,990-$44,990 range. Coupe only, no verts.
Limited number (least amount possible yet profitable). est 2800 units.
Like the color scheme idea, but I would say 4 color combos:
red with silver wheels/stripes
white with black wheels/stripes
blue with black wheels/stripes
black with silver wheels/stripes
(love the blue and yellow combo idea but don't think it would sell despite the heritage)
I'm thinking LS3R (I think the LS7 would be too pricey) factory LT headers, manual trans only, tuned for 93 or E85. Rear gear change or tighter gears in the trans (no OD).
The hood I know won't have the blanket... out back a functional pedestal wing. Not as much a fan of the SCCA nose but for this, having a headlight more flush with the nose makes sense.
Carbon fiber Recaro racing seats. I would say rear seat, radio & A/C delete, but that's impractical.
Light weight 18"-19" BBS racing wheels with only summer compound tires. Suspension... I don't know... I like the Pedders idea, but would be ok with Pfadt or a hybrid of both between Pedders bushings and Pfadt arms (please excuse my ignorance on the suspension)
Horsepower should be N/A and less than the ZL1, I think 470 @ the crank could get the job done, but this car needs to be able to out corner a ZL1 and a Boss 302 @ Willow Springs.
Kahdir is offline   Reply With Quote
Old 06-06-2011, 07:50 PM   #213
LOWDOWN
Downright Upright
Drives: Daily
Pete, don't ya just luv it when someone takes your concept and puts FAT suspension on it instead...?!
Wait...we're talkin' WEIGHT...not BRAND...here...
As to hp, we're a tune from 500 at the wheels with the LS7... 'Course, there is that warranty issue...
LOWDOWN is offline   Reply With Quote
Old 06-06-2011, 07:55 PM   #214
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
What do ya think? Maybe he don't know Pete???
Gotta love it.
BTW Lowdown, you think we have this car spec'd out for GM feasibly, and at a reasonable price?
2cnd chance is offline   Reply With Quote
Old 06-06-2011, 09:49 PM   #215
Gramps69Z
Still waiting on the Z
Gramps69Z's Avatar
Drives: 69 Z/28, 06 Denali, 09 CTS
Send a message via AIM to Gramps69Z Send a message via Yahoo to Gramps69Z
Why give dealers that chance for a markup on a limited car? The Boss is limited and the dealers are getting "BIG" money over sticker. If you want a new Z/28 you should be able to order it with your options.
I don't like the "Boss" colors. Let's keep it a Chevrolet.
October 31, 2015 at 0700 - officially retired
1969 Chevrolet Camaro Z/28
2006 Denali
2009 Cadillac CTS
The Six Old Guys
The last thing we want is to ship something that isn't right.
Gramps69Z is offline   Reply With Quote
Old 06-06-2011, 10:08 PM   #216
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
^Exactly!
the missing $40K pricepoint. If your competitor sells a mid price point you need to match them.
Why? If it doesn't make any sense for YOU to make it due to costs/return on investment...
"Keeping up with the Joneses" is not a business case. Especially not when the competitor is a car nobody can buy, atm....
I would LOOOOOVVVEEEEE to see a "Z28" Camaro as everyone has promoted around here, I've said it before. An SS with some more spunk from the factory would be awesome!
But I find (from an outsider's perspective) the business case to be a VERY hard one to pitch when you (the Camaro team) have just finished your pièce de résistance: the ZL1.
Folks around here want handling. Well, I truly wonder how the the new FE4 adjustment on the SSs will effect people's minds around here. Nobody's had a chance to sample it, yet. I doubt it'll be quite as touchy as the Boss Mustang, but I imagine it's a substantial improvement over the current setup...
Old 06-06-2011, 10:24 PM   #217
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
I am guesstimating the Z28 could be built for some where between $43 to $45K where the ZL1 will be $50 to $55K. Aside from price point the character of the cars will be very different. The Corvette sells in base, Grand Sport, Z06 and ZL1 trim. Each one is still a Vette, but different. Unlike the Vette, the Camaro must generate volume sales across the board as well as in each trim level. I can see where there is a market for both the ZL1 and Z28. The question is units. I am not sure what Chevrolet will find acceptable for the ZL1. I know it will sell a 1,000 units in a Chevy Heartbeat. 10,000 may be realistic. If they could get 7,000 Z28s and 7,000 ZL1s per year, can they make money over 3 years? Does it rake 15K ZL1s per year to make a profit? It all comes down to units and if they just drain away SS sales are any variants good for business without a large built in margin?
Old 06-06-2011, 10:26 PM   #218
JusticePete
High. My name is Pete. I am a Pedder-aholic
Old 06-06-2011, 10:42 PM   #219
JusticePete
Having driven the MR suspension on ZETA in a HSV I feel I have sampled it. It is very good and as I have written numerous times, probably makes most drivers better and faster. It is an excellent suspension. Those that buy a ZL1 will like what they get.
The Mustang with a three arm solid axle will always be a bit touchier as you described. I have not driven a Camaro with MRC or with the new RLCA and sway bar so what I write next is inferred. The Camaro whispers in your ear what the IRS is doing. The Mustang sort of yells watch out and almost too late. The ZL1 will be very sophisticated.
The Z28, in my mind's eye, is a a bit edgier, but not a club racer with a cage and no interior. An SS with the current suspension, the Z28 with use controlled damping and the ZL1 with MRC makes sense to me in terms of range and markets. NA vs SC.
If the Z28 just sucks unit sales away from the SS and ZL1 it would be a bad idea. If it adds unit volumes with conquest sales from other brands they should build it tomorrow.
Old 06-06-2011, 11:05 PM   #220
Mr. Wyndham
I'm just referring to the 2012 suspension update in the SS models. Short of custom damping adjustment like your coilovers or the Boss Mustang to a much lesser extent...It should be very nice.
You seem to be talking about the ZL1 suspension/MR...or am I reading your post wrong?
Old 06-06-2011, 11:37 PM   #221
JusticePete
You are spot on as usual.
Old 06-07-2011, 09:05 AM   #222
LOWDOWN
Downright Upright
Drives: Daily
I'm sure there'll be "intel" from the GT-BOSS-GT500 situation. What were the BOSS-buyers' second and/or third choices? Direct from their 30-day surveys...
And since when is it wrong, at GM, to move someone up the price ladder, from an SS to a Z/28? Mr. Sloan devised just such a "wish" many moon's ago.
I'm sure a call to Pete and Pfadt will quickly confirm an approximation of those folks who've gone "outside" the comforts of GM to augment their SSs to "do battle" with an upgraded system...
I seriously doubt the BOSS has robbed much/any from the GT500...apples and oranges, although the same "farmer" owns the basket...
The ZL1 may well be a "driver's" car, but a properly-applied and -priced Z/28 would be a DRIVER'S car...and that, friends, is a market unto itself.
At the same time, it's better to have said canyon carver in our arsenal than seeing people flee to the (dark) Oval side...
Old 06-07-2011, 09:47 AM   #223
LOWDOWN
Downright Upright
Drives: Daily
I do, however, have an even more insightful idea as to where Number 3's "business case" concerns come from. Here are a couple of recent exerpts from a Detroit News interview with Dan Akerson, GM's Board Chairman and CEO:
In a recent meeting with engineers, for example, Akerson pressed them to explain the logic behind putting a big 6.2-liter engine in an unspecified car whose competitor has a 4.4-liter turbocharged engine. The engineers replied: "Well, we want to be able to beat the other guy."
Akerson responded: "I don't think the average buyer is going to buy an eight-cylinder, 530-horsepower (car)." His point: Decisions must be supported by a solid business case, and not just for bragging rights or as a marketing tool.
And this one:
Akerson, who became CEO Sept. 1 and board chairman Jan. 1, already is weighing in on new vehicles. He recently greenlighted the next generation of the compact Chevrolet Cruze, but vetoed a new engine for a sports car set for production in 18 months.
So, folks, if 500+ hp is "necessary", it's the LS7 or nuthin'...
Old 06-07-2011, 12:55 PM   #224
2cnd chance
First the Camaro already exist, we are only adding a package. Second the price gap is too large. GM is missing out on in-house upgrades.
700 hp z/28 in 2014, the greatest camaro
BREAKING: 2012 CAMARO ZL1 - 6.2L LSA Supercharged - 6MT Revealed! Tran Camaro ZL1 Forum - ZL1 Specific Topics 756 05-01-2013 07:22 AM
