Old 07-12-2011, 01:17 PM   #533
ShnOmac
ShnOmac's Avatar
So make it with the gen V 'LR7' (or whatever the high performance naturally aspirated V8 is called).
If they went that route then it would be safe to bet we may not see a Z/28 until the 6th Gen Camaro is released.
Now if we cant have the LS7 in the 5th Gen because of cost and the fact that it's on its way out.... And we(they) dont want to wait until the 6th gen to release a Z/28.... What are our other options to create a 5th Gen Z/28????
ShnOmac is offline   Reply With Quote
Old 07-12-2011, 01:20 PM   #534
LOWDOWN
Downright Upright
Drives: Daily
It has suddenly become clear, here, in the last few days the Laguna Seca is being used as the "benchmark" for performance by many. A $6995 option package which saves ZERO weight (rear seat delete = chassis bracing), and is being sold at a rate of 15% of BOSS production. A "halo" for a "halo".
Would GM consider the same?
LS3+ "Z/28" as "Base" @ $40ish (as per RJ), and an LS7 @ a $6995 premium, for a "Halo" of a "Halo"?!
Keep in mind, Mustang's current version has a "Best Before" date roughly equal to the Gen-5 Camaro...
LOWDOWN is offline   Reply With Quote
Old 07-12-2011, 01:23 PM   #535
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
The other thing with the LS7 being on the way out is ... how do we know that it will be cancelled before the end of the gen IV run? If its not, then its going to live roughly as long as the LS3. And its more work to get a high output version of the LS3 into the Camaro than it would be to just use the LS7.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 07-12-2011, 01:26 PM   #536
LOWDOWN
Downright Upright
Drives: Daily
That, and the fact that mods to the LS3 CO$T...shrinking the "cost to GM" differential between the hot LS3 and a production-ready LS7.
You cannot simply say "an LS7 is TWICE the cost of an LS3"...TWICE of WHAT?!
Old 07-12-2011, 02:10 PM   #537
ShnOmac
ShnOmac's Avatar
If the Vette's model change arrives in 2013 as a 2014 thats only two years a way. If the new vette does not use the LS7 and only uses GenV engines the LS7 will be dead. With that being said do yall think GM could recoup the R@D and validation cost of trying to drop a LS7 into the Camaro in only 2 years?
Yes I know we are dealing with a lot of if's and but's here but its all we got
Old 07-12-2011, 02:17 PM   #538
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
That is a #3 loaded question. If they were to use data from the LSA ZL1 for driveline validation to reduce the cost my guess would be yes. If they start with a clean sheet of paper my guess would be no.
Old 07-12-2011, 02:27 PM   #539
LOWDOWN
Downright Upright
Drives: Daily
Gee, Pete, why wouldn't they?! This IS, after all, the New GM...
With regard the LS7 usage in a "Z/28", I bet you a Tim Horton donut (your choice) MORE LS7s would be built for a sub-$50 Camaro than ever were used in north-of-$70 Vettes...
Old 07-12-2011, 02:29 PM   #540
ShnOmac
ShnOmac's Avatar
But to use the LSA ZL1 driveline validation that same drive line would have to be in the Z/28 correct?
Old 07-12-2011, 02:39 PM   #541
LOWDOWN
Downright Upright
Drives: Daily
Yes, as mentioned earlier, for durability and reliability (warrantee containment), piece-cost reduction and, therefore, improved profit$.
Win-Win-Win
Old 07-12-2011, 02:43 PM   #542
ShnOmac
ShnOmac's Avatar
Win-Win-Win
Not a win when you figure using that heavily beefed up driveline is going to add weight to what we are trying to make a track star.
Old 07-12-2011, 02:49 PM   #543
LOWDOWN
Downright Upright
Drives: Daily
Again...starting with an LS-contented interior, your friend Number 3's careful use of seam-sealer/mastic/insulation/underlay etc. etc., dropping the dry-sump tank from the LS7, using forged wheels (19s??) and lighter non-run-flat tires will at least offset the HD Tremec/HD diff/bigger brakes/HD bars. The springs, as per Pete, if not MR, are a wash, as are the higher durometer bushings throughout...
An LS7 "Z/28" for the final Curb Weight of a 1SS...3849...or less...as per the power-to-weight calculations mentioned above.
Old 07-12-2011, 03:02 PM   #544
ShnOmac
ShnOmac's Avatar
Again...... If the LS7 is really on its way out than none of this matters! That is why I am trying to look at all the options for a Z/28 (also GM's side).
Old 07-12-2011, 03:05 PM   #545
LOWDOWN
Downright Upright
Drives: Daily
Mac, would you agree that, regardless, a production-ready engine MUST be used in a Gen-5 ZEE?
If yes, your choices are few...LS3...LS7...LSA...LS9...at this time...and NO Gen-5 V8 for Camaro till after the Vette gets it, which is easily a year away, and then likely a year after that...
Old 07-12-2011, 03:16 PM   #546
JusticePete
VIR Specialist
Durability vs weight. We can still pull 200 pounds out with smaller wheels and tires, titanium exhuast, less sound insulation and so on. AND, the extra weight is in the back half of the Z/28
700 hp z/28 in 2014, the greatest camaro
BREAKING: 2012 CAMARO ZL1 - 6.2L LSA Supercharged - 6MT Revealed! Tran Camaro ZL1 Forum - ZL1 Specific Topics 756 05-01-2013 07:22 AM
