Elite Engineering
Old 07-12-2011, 02:16 PM   #547
ShnOmac
ShnOmac's Avatar
Originally Posted by LOWDOWN View Post
Mac, would you agree that, regardless, a production-ready engine MUST be used in a Gen-5 ZEE?
If yes, your choices are few...LS3...LS7...LSA...LS9...at this time...and NO Gen-5 V8 for Camaro till after the Vette gets it, which is easily a year away, and then likely a year after that...
Obviously if they wanted to release a proper Z/28 as a 5Th Gen Camaro it would have to be one of those engines. Is it cost effective for GM to do it now or wait until a later time? That is what I am trying to figure out. Unfortunately none of us really know what is and isn't cost effective for GM...... We can only guess and assume!
ShnOmac is offline   Reply With Quote
Old 07-12-2011, 02:18 PM   #548
ShnOmac
ShnOmac's Avatar
Durability vs weight. We can still pull 200 pounds out with smaller wheels and tires, titanium exhuast, less sound insulation and so on. AND, the extra weight is in the back half of the Z/28
When you start making changes to stock wheels and such does the car have to be re-certified in the crash test area as well as normal validation procedures?
Old 07-12-2011, 02:21 PM   #549
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
From what I have read the slightly lowered versions of that other brand muscle car did not require crash tests. My guess is that a small change in wheel diameter would not require more crash testing. Wheel validation yes, but I don't think crash test. Perhaps #3 can give us an idea of the ride height variation allowed in crash tests.
Old 07-12-2011, 02:22 PM   #550
LOWDOWN
Downright Upright
Drives: Daily
Yes...which the ZL1 validation will accomplish...
BTW, if Wixom is viable building LS7s in the realitively paultry numbers they've enjoyed with Corvette, does it make sense to continue if volumes ballooned to 3 or 4 or 5 TIMES as many units as might be the case with a Laguna Seca-seeking and -priced Z/28?
And there IS "value" in "shared costs"...
LOWDOWN is offline   Reply With Quote
Old 07-12-2011, 02:59 PM   #551
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
I'm Sold! Build it!
Super Z28 - all the track toys discussed & the LS7
Z28 - all the track toys discussed & and an LS3 of some sort
$40K - $47K
2cnd chance is offline   Reply With Quote
Old 07-12-2011, 03:00 PM   #552
2cnd chance
The LS7 has probably the same life expectancy as the 5Gen, itmakes sense to marry them.
Old 07-12-2011, 03:28 PM   #553
Russell James
Russell James's Avatar
Drives: Camaros
The sticker shock of an LS7 powered Camaro would bring many of you back to reality.
Plus, the LS7 was designed for the Z06. Your not going to just plop it in a much heavier vehicle and be happy with the results. To do it right you would need to optimize the cam and torque curve for the heavier Camaro. Which leads to why the LSA was chosen over it in the first place for the Camaro performance version.... later named the ZL1. The supercharged grunt is more matched to get that weight moving vs a high revving motor.
If you remember the C5 Z06's. They screamed with the LS6. I owned two of them and they were a riot to drive. Then they put that same LS6 in the tank of a CTS-V. When I drove one of those, I couldn't believe it was the same engine. Pulled hard at the very top of the revs, but the weight just killed the low end. Had no where near the excitement of that engine in the lightweight Z06. Fast forward to the next gen CTS-V.... and do you see the current Z06 engine in that car. No. They got smart and went supercharged with a better torque curve to match the weight... and the CTS-V is now an out of the park hit. That's from engineering an ideal powertrain, instead of grabbing something off the parts shelf.
Old 07-12-2011, 04:05 PM   #554
2cnd chance
The LS7 revs for a track type design (think finesse) we're discussing. The ZL1'is the sledge hammer.
Old 07-12-2011, 04:10 PM   #555
LOWDOWN
Downright Upright
Drives: Daily
A Gen-1 CTS-V weighs about the same as a Gen-5 Camaro. But comparing an LS6 to an LS7 is like comparing an LS7 to an LS9...100 hp and an equal amount of TORQUE...
I have experience with an LPE-prepped C5 TT LS6...which eventually was replaced with an LPE-prepped LS7. The LS7 with 540 rwhp turned better times in all disciplines than the 597 rwhp TT LS6...something called "heat-soak" took over the TT, and that 150 lb. on the nose was very discernible...
Sound familiar?
Old 07-12-2011, 04:13 PM   #556
Blizzard
Searching for the truth
Blizzard's Avatar
Drives: 85 K-10, 13 1LE
A Z28 might not wait a year or so to get the new Gen V V8.
2013 1LE 1SS RS TPW 4/29
Blizzard is offline   Reply With Quote
Old 07-12-2011, 04:15 PM   #557
Number 3
Hail to the King baby!
Number 3's Avatar
Drives: '16 ATS 2.0T & '14 Chevrolet SS
Gee, Pete, why wouldn't they?! This IS, after all, the New GM...
With regard the LS7 usage in a "Z/28", I bet you a Tim Horton donut (your choice) MORE LS7s would be built for a sub-$50 Camaro than ever were used in north-of-$70 Vettes...
I'd taket that bet.....................unless a Tim Horton's donut is gambling slang for $1,000.
The original C6 Z06 volumes were up to 1/3 of total prodcution or about 10,000 units per year. So when you say, "ever" do you mean total Z06 production? or highest year of production?
Nowhere near that right now, of course. But that would be a benefit of using the LS7 here. It would get back to production volumes.
But to use the LSA ZL1 driveline validation that same drive line would have to be in the Z/28 correct?
If you put a lower output engine of the same family in front of the same transmission, driveshaft, axles etc. it can reduce the overall cost to validate the product. However, it does not eliminate the need to validate. You would still have a ton of development time, calibration time, etc.
It is less, but far from ZERO.
Again...starting with an LS-contented interior, your friend Number 3's careful use of seam-sealer/mastic/insulation/underlay etc. etc., dropping the dry-sump tank from the LS7, using forged wheels (19s??) and lighter non-run-flat tires will at least offset the HD Tremec/HD diff/bigger brakes/HD bars. The springs, as per Pete, if not MR, are a wash, as are the higher durometer bushings throughout...
An LS7 "Z/28" for the final Curb Weight of a 1SS...3849...or less...as per the power-to-weight calculations mentioned above.
Your friend? Sniff, you mean I'm not your friend too?
Originally Posted by Z284ever View Post
People you know, will driving GenV smallblocks on the street, two years from now. I can't imagine GM keeping the GenIV LS7 around by then.
It's just a low volume hand built engine. I don't know the plans on this one, but as long as the engine is emissions compliant or the year, not sure why they couldn't continue...........................it's just that it would remain a hand built engine at Wixom ............. $$$$$$$$$$$$$
Again...... If the LS7 is really on its way out than none of this matters! That is why I am trying to look at all the options for a Z/28 (also GM's side).
Keep looking
It depends. If you change ride height you would have to re do side impact testing as just one example as that would position the occupant lower than what you previously tested to.
Like I said above, it depends on what you do. Bigger wheels with smaller rim to ground clearance need to be looked at even if you maintain ride height. Change ride height and you have to confirm a bunch of other things.
As we often say, the devil is in the details.
You won't be getting 3, 4 or 5 times volume. For starters, the hand built line has a maximum capacity. I don't know what that is, but it isn't 30,000 to 50,000 engines per year.
Also by your math, are you assuming 30 to 50,000 Z28s with LS7 power? That's 30 to 50% of annual sales. That's pretty hefty considering the car you wan't to compete with sold 4,000.
Good addition to the discussion. BTW, I don't remember the 400 HP in the early CTS-V as being bad at all. The wheel hop on the other hand...................:(
"Speed, it seems to me, provides the one genuinely modern pleasure." - Aldous Huxley Link to Every Camaro photo I've taken in Hi-Resolution
Old 07-12-2011, 04:26 PM   #558
LOWDOWN
Downright Upright
Drives: Daily
Number 3, we'll find out the depth of our relationship @ Woodward this August... You DID say the first Michelob was "on you", didn't you?! The 2nd and 3rd...waiting for you!
Current Z06 vs. potential Z/28...and I predict 10,000+ LS7 ZEEs (which is several times current Z06 volume). Ford is "constrained" (their word) to a total of less than 5,000...4,000 "Base" and 750 LSs, according to "plan".
BTW, 1969 ZEE sales totalled 20,302 units. '69 BOSS 302 = less than 2,000...'70 BOSS 302 = 7,000
"If you build it, they will come..."
Old 07-12-2011, 04:41 PM   #559
JusticePete
Heat soak so I moved to Texas where it is 100 degrees everyday since my move but it is sunny
Old 07-12-2011, 04:44 PM   #560
LOWDOWN
Downright Upright
Drives: Daily
Pete, you mentioned heat-soak in your Pedder's S/C Camaro...it's WORSE with TT...and the Shelby just may find that out...
700 hp z/28 in 2014, the greatest camaro
BREAKING: 2012 CAMARO ZL1 - 6.2L LSA Supercharged - 6MT Revealed! Tran Camaro ZL1 Forum - ZL1 Specific Topics 756 05-01-2013 06:22 AM
Transcript of Camaro ZL1 Q&A Webchat with Chevrolet Tran Camaro ZL1 Forum - ZL1 Specific Topics 38 02-17-2012 12:45 AM
Installation Camaro Needed for Manual for a Justice Install Package in SF Bay Area Info@PeddersUSA.com USA - California 6 04-30-2010 08:02 PM
The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES Info@PeddersUSA.com Suspension / Brakes / Chassis 106 10-19-2009 06:08 PM
