SDTW Custom Wheels & Tires
Old 10-06-2011, 10:52 PM   #1205
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
I'm sorry Pete but thats a 9% loss, and I just can't believe that it will be that efficient. If you say it will be 680ish at the crank, then I'd expect it to be somewhere around 590 to the wheel.
I'd agree with that, the estimate most peole use is about 15% loss from crank to rear.
calbert1999 is offline   Reply With Quote
Old 10-06-2011, 10:54 PM   #1206
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
Oh did 2.99 say 680? I think Pete said 720.
2cnd chance is offline   Reply With Quote
Old 10-06-2011, 11:01 PM   #1207
calbert1999
Camaro SS Lover
I'm guessing that's a NA LSX engine.
As for 680rwhp. on the LS3, put forged internals, replace entire head assembly (including the cheap GM valves), put on a ProCharger and ta-da.
A little freebie for those of you who want to smoke the ZL1 without having to replace entire engine.
Old 10-06-2011, 11:17 PM   #1208
427camaro
Drives: 2011 HTR-454SS Camaro, 87 Buick GN
We should be close to 620 at the rears. The TQ is what I am really excited about. It comes on low , fat and flat. That will make the Project Z predictable. Predictable is fast. It will be a driver's dream.
Exciting stuff !! can't wait to see the car & learn more when it's announced at SEMA. Can I ask what color your SEMA car is ? & Any stripes, & what color stripes ?
427camaro is offline   Reply With Quote
Old 10-07-2011, 03:13 AM   #1209
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
so throw all your parts away but keep the block.
it won't be an LS3, and if you're going to all that trouble you might as well install an lsx454.
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline   Reply With Quote
Old 10-07-2011, 12:46 PM   #1210
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
I'm having an LSX-427 build in progress for my SS, it has forged internals, LSX heads, CAM, ProCharger and the upgraded fuel system.
We're estimating close to 800rwhp. and that's just scratching the surface. The same shop just completed a forged Z06 w/ LS7 a Vortech SC and it made 730rwhp.
I assure you the only ZL1 that will keep up to me will be the ZL1's that are modified with a stroker and SC that has more than a 1.9L capacity.
Old 10-07-2011, 01:39 PM   #1211
JusticePete
VIR Specialist
Chevrolet lists the ZR1 at 638 HP. There are base line dyno runs showing the OE ZR1 between 578 558 to the rear wheels or 9 to 12% loss. Some of this can be explained by variations in OE engine output and / or differences in dynos. Using the same range we would be 598 to 612 RWHP or 605 split down the middle . Now if our engine dyno readings are a bit on the conservative side the 620 could be a real number or not.
Old 10-07-2011, 01:40 PM   #1212
JusticePete
VIR Specialist
I thought he said LS7
Old 10-07-2011, 02:28 PM   #1213
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Oh please You have no proof of that whatsoever....
Seriously, I'd love to see both beastly NA and Blown Camaros kick'n booty on the streets... but with all the fuel economy crap... are we really going to ignore a TT V6 or a or a baby LS7???
lets use the Vete as a bench mark...
base vette = SS
Z06 or Grand sport = Z28
ZR1 = ZL1
Think about that for a minute. I would love to see a 600hp LS7 but that doesn't make sense if we are thinking the ZL1 will be top dog in the Camaro HP race...
Just throwing that out there...
Old 10-07-2011, 02:38 PM   #1214
ShnOmac
ShnOmac's Avatar
We are not talking factory here.... We are going way above and beyond GM!
JP special Z FTW!
ShnOmac is offline   Reply With Quote
Old 10-07-2011, 03:01 PM   #1215
LOWDOWN
Downright Upright
Drives: Daily
Vette as "benchmark":
Z06 @ 3199 Curb = 7:22 @ the 'Ring (-133 "rated" hp)
ZR1 @ 3353 Curb = 7:19 @ the 'Ring (+154 "rated" lb.)
I believe you'll find a greater weight difference between a ZL1 and a "wet" LS7'd ZEE, but NOT as much hp. differential...
Whether equipped with a lower weight-optimized MR, or a BOSS-type "mechanical-only" weight-conscious suspension (non-MR), with 305s fr-rr, a ZEE could be a match (or veryvery close) for the ZL1...just as the BOSS, minus 100+ hp, is to the GT 500 at places like VIR...
It's one thing to have gi-normous power but, as the Vette shows/proves, it's another thing altogether to use that power effectively at all times.
And, as good as MR may be, it's not likely to harness almost 600 hp in 4100 lbs effectively at all times...it doesn't in the 3353 lb. ZR1...
IF the ZL1 is street-ready @ 4100 lbs, with 580 hp, that = 7.07 lb/hp. For an LS7 weighing 3850 lb (1SS Curb), 7.07 = 545 hp...NOT "impossible"...
As to the PEDDERS et al ZEE-something, some serious power is capable, at a significant weight-savings, with a massaged LS7...or WARHAWK...well beyond the LSA's "rated" 580/556...without the added mass of FI... 2 or 300 lb. on a road course car is mammoth weight to carry...and very significant to delete...
I suspect what's coming for SEMA is NOT hampered by GM's production viability constraints. Weight-savings that Oshawa will not have to worry about will be included. And the power-to-weight will dwarf the ZL1...as will its performance capabilities...
LOWDOWN is offline   Reply With Quote
Old 10-07-2011, 04:47 PM   #1216
LOWDOWN
Downright Upright
Drives: Daily
There are very valid reasons why the "Corvette track-star" is considered to be the Z06/Z07. It takes an incredibly talented "shoe" to wring 100% (or close to it) out of a ZR1. The car IS a monster, and not for the short-of-talent in any way...shape...form. Not that a Z06 is soooo much easier to "handle"...but it's certainly easier to get near-10/10ths out of a 500 hp car, than it is a 638 hp car. As it would also be on the street...
And so would a "production LS7" ZEE vs. a ZL1...less weight, less dough, more "fun", more sense of accomplishment. And maybe...just maybe...just as quick around a track...
More smiles per mile!
Old 10-07-2011, 05:27 PM   #1217
JusticePete
VIR Specialist
base vette = SS
ZR1 = ZL1
GM never asked US (the Z/28 guys in this thread) what version of the Camaro should be Top Dog. More import is the Top Dog Camaro was the Pedders USA Camaro, you know, what the ZL1 used for a benchmark, the car that ran as fast as a Z06 TWO years ago. Now if you thought for a split second that have been sitting idly by waiting for GM match us us on track
Dear GM,
Don't be upset with Pedders. We are using GMPP Pedders parts to go faster than the ZL1 and several versions of the Vette
As for CAFE -- Note to GM: SELL MORE VOLTS, Sonics and Cruzes. A LOT more so no one feels the impact of a ground pounding LS7 V8 in the cars we love. Maybe package them. One 600 RWHP LS7 Camaro with one Sonic and a Diesel Cruze
Who is coming to SEMA?
Old 10-07-2011, 05:29 PM   #1218
JusticePete
VIR Specialist
Spot on as always.
700 hp z/28 in 2014, the greatest camaro
BREAKING: 2012 CAMARO ZL1 - 6.2L LSA Supercharged - 6MT Revealed! Tran Camaro ZL1 Forum - ZL1 Specific Topics 756 05-01-2013 07:22 AM
