Gen5DIY
Old 05-25-2011, 06:25 PM   #1
bmorecam
my dyno today(base for e85 tune)
UPDATED 6/9
The temp was 95*, car has a little over 5k miles, the only mod are exhaust and long tube with no cats, and the newest trifecta tune. The dyno was a dynojet 248x inertia 2000hp chassis dyno located in beltsville md@SRT home of the fastest lexus is300.
I do not have a baseline for my car, but others on the same dyno produced around 232rwhp stock in 90+ heat, and around 240rwhp in a cooler 50's.
I dynoed 264rwhp and 240rwtq.
The reason for today's dyno was to get a baseline established for trifecta's e85 tune I am currently testing. So far so good! With the proper timing, AFR, and control of valve timing VVT, we can manipulate the effective compression to take advantage of e85's 105 octane and its cooling nature to pump out more power than what a usual N/A car can do.
Old 05-25-2011, 06:30 PM   #2
Devryn17
Suffers Fools Poorly
Devryn17's Avatar
Drives: 2010 SS/RS, CGM w/ Silver Stripes.
Those numbers do seem a little low for your mods...That means you've only gained about 12-15 HP.
2010 2SS/RS, CGM w/ silver stripes. Hurst Shifter, long tube headers, full exhaust, CAI, tune. SAE 407 RWHP/402 RWTQ
Momma didn't bronze my shoes, but when I turned 16 I inherited a lead foot.
Devryn17 is offline   Reply With Quote
Old 05-25-2011, 06:34 PM   #3
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Did you do a stock dyno? If not, there is no way to know how well your mods have performed.
Old 05-25-2011, 06:37 PM   #4
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
you have no idea how pumped I am right now
Hope someone syphons out your gas lol
CAMARO
Old 05-25-2011, 06:43 PM   #5
bmorecam
Im with you.
no stock dyno so no way to really tell. you are right.
Lets just hope that vince can tweak our fuel to pump out sufficient e85. I cant wait either
Anyone with more dyno experience want to chime in? the owner of my dyno shop said that his dynojet is a bigger model that reads lower than the usual dynojet. whats your thought?
Oh.. and forgot to mention. today at 4pm when I got my car dynoed was 90 degrees on my radio before I went in. very very hot day.
Old 05-25-2011, 06:43 PM   #6
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
lolol.
Yeah, sounds cool bmorecam!
jagan323 is offline   Reply With Quote
Old 05-25-2011, 07:28 PM   #7
bmorecam
you know what, after doing some searching/researchin on this forum it look like most peoples with manual are putting down 260-270hp with added intake headers, exhaust, tune. Remember, I have no intake yet, I am still waiting for vararam.
Stock is usually seeing 245-250 manual. so if I did 270hp with stock intake than I actually think thats a ok number. Plus the owner told me that their dynojet is a bigger model and it read lower than the usual dynojet. So if thats true than that mean even my 270hp number is really conservative right?
and I think if I would of kept pulling I could of even got higher number. The dyno run went from 265-268-270, so I think I could of got higher figure because the power was just getting bigger with each pull.
Also, vince just got back to me and said this:
Vince Geglia (Trifecta Perf.) to me
show details 7:34 PM (2 minutes ago)
Those numbers are very good, I certainlywouldn’t be unhappy with them. Most guys were getting less than 260WHP withyour level of mods on the old tune.
- Vince Geglia
TrifectaPerformance, Inc.
Thats very interesting.
Well at least I have a base figure for e85 tune. Thats all it matter no more need for guessing.
Old 05-25-2011, 09:57 PM   #8
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
Originally Posted by bmorecam View Post
Im with you.
My shop that I go to says the same thing, lower reading dynojet. But probably more realistic instead of pumped up numbers.
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Ridetech coilovers And Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 05-25-2011, 10:06 PM   #9
J.L.TYCHE
Tampa Gulf Coast Family
J.L.TYCHE's Avatar
Drives: 2011 Corvette
The H.P. seems right on with others that have LT's and exhaust with no intake.Doesnt seem bad at all.
J.L.TYCHE is offline   Reply With Quote
Old 05-25-2011, 11:07 PM   #10
bmorecam
I actually think the numbers are good. Considering a stock v6 usually dyno 240-250hp the highest on a dynojet than that mean I could of gained anywhere from 20-30hp. The only thing that I could of got the extra power is from the long tube with no cats and the new tune. So if I look at it that way than I think 270hp on a 90 degree weather is actually good still with factory intake.
At this point the number really dont mean crap since I dont have my car's stock dyno to compare with. What matters now is that I can now almost correctly see the gain with e85 tune when I go backassuming that the e85 tune will work on our car.
Old 05-25-2011, 11:13 PM   #11
bmorecam
I was almost with you until I realized what stock v6's dyno on other similar dynojet. I think its more 20-30hp I gained considering stock see 240-250whp.
but again, I cant really take the numbers from today too seriously without having base numbers to compare to.
Old 05-25-2011, 11:14 PM   #12
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
My best was 270hp with all my mods, minus the nitrous. So you are good.
Old 05-25-2011, 11:16 PM   #13
PoorMansCamaro
Drives: Really Slow
That's with ss wheels as well, which effect the readings with heavier wheels.
Old 05-25-2011, 11:19 PM   #14
PoorMansCamaro
Drives: Really Slow
If it's at all possible, best scenario would be to run a baseline dyno when your low fuel light comes on, then run to the gas station and fill up e85, and run it again. Not sure if that's possible.
Dyno Tune in Sacramento - Force Fed Performance LS3-376 Tuning / Diagnostics -- engine and transmission 3 03-19-2012 01:32 PM
$150 OFF 21st Century Muscle Cars DYNO TUNE 21STCENTURY V8 Bolt-Ons & Tunes 0 01-08-2011 10:57 AM
SCT or Dyno Tune jwjw12 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 10-20-2010 03:28 PM
Trifecta tune or Dyno tune? cnjsanchez Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 18 05-14-2010 12:42 PM
L99 A6 Dyno Results (ARH, Roto-Fab CAI,Borla, Tune) rinerracing6 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 08-23-2009 06:09 PM
