SDTW Custom Wheels & Tires
Old 05-25-2011, 11:31 PM   #15
KMPrenger
KMPrenger's Avatar
Definitely DO NOT be unhappy with those numbers. Heck man, first off your right in there (pretty close) to what other guys with your mods are running (minus the fact that most of those guys are driving automatics), but you gotta keep in mind on top of that your dyno guy said that dyno typically reads a bit lower than other dynojets, AND it was hot as heck! So you factor all that in, and your doing well.
If your car was an auto, you would have probably dyno'd 10 HP less than that. Be proud, that your driving a V6 putting around 340HP/300TQ out at the crank (well maybe not that much on a HOT day lol)....maybe even a tad more.
If I was you I'd go back on a cool day or this fall when its about 50 degrees out and give it another go...of course if your E85 tune works, you'll be makin even more power.
Old 05-25-2011, 11:33 PM   #16
KMPrenger
KMPrenger's Avatar
Originally Posted by PoorMansCamaro View Post
If it's at all possible, best scenario would be to run a baseline dyno when your low fuel light comes on, then run to the gas station and fill up e85, and run it again. Not sure if that's possible.
But would the E85 tune need some drive time as well to achieve best results?? Iono
Old 05-25-2011, 11:35 PM   #17
OOLIE
OOLIE's Avatar
Drives: 2011 LS
Good question. I was with him on this for TRUE contrast results, but does the computer need time to adjust? One for Vince.
OOLIE is offline   Reply With Quote
Old 05-25-2011, 11:35 PM   #18
KMPrenger
KMPrenger's Avatar
Well, Vince has said it does need time for his normal tune.
Old 05-25-2011, 11:47 PM   #19
bmorecam
kmprenger you are right. For some reason I thought that our stock v6 dyno around 260hp. I dont know where I got that from. It must of been the heat boiling my thought process.
I didnt realize that my dyno numbers are actually really good until I started seeing past posts of other peoples stock and similar modded dynos.
Im not too worried about todays number anyway. After all todays dyno was just to setup a base number in prep for e85 tune. Im happy with my performance so far regardless of the number.
poorman, I have to empty out the 93 gas as much as I can and after that I have to at least go through a tank or two of e85 to effectively be converted.
I am just hoping the tune can compensate for the extra 30-40% e85 to give the same gasoline effect. Vince seem optimistic about it.
If this work than I am almost sure we can see 300whp - or + without going FI. I am just lucky to have plenty of e85 in my area.
Old 05-25-2011, 11:53 PM   #20
bmorecam
Also, I have to take into consideration that the e85 will have to be tweaked out with datalogging in between unless vince is just that good and can get it on one shot.
Old 05-26-2011, 08:02 AM   #21
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Don't worry so much about what the actual number is. Your right in the range you should expect and the dyno is just a tool. Your looks to see how this new mod (E85 tune) will improve over what you have now. The true test will come at the track.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 05-26-2011, 10:33 AM   #22
PieNsky
PieNsky's Avatar
Drives: Victory Red 1LS
With the stock intake you could have been pulling timing as the sensor really heats up.
PieNsky is offline   Reply With Quote
Old 05-26-2011, 11:46 AM   #23
bmorecam
Im not too worried gretchen. My main goal for this dyno was to get a base number for e85. Even if I was to take yesterdays dyno number seriously I think I could have seen up to 280whp and maybe even more if the weather was cooler and if infact what my dyno guy said was true that his dyno read lower(2000hp 248x)but what surprise me the most is that these numbers are with my factory intake.
After everything is setup and completed I will hit the track and get some numbers.
its always a possibility but I am def not getting the full effect of my header due to my restricted factory intake. Theres def more power to be had. 300whp does not look too far away
Old 05-26-2011, 12:54 PM   #24
KMPrenger
KMPrenger's Avatar
Aww heck, your even running the stock intake and still made that power? heck...your doing just fine!
Old 05-26-2011, 12:57 PM   #25
Devryn17
Suffers Fools Poorly
Devryn17's Avatar
Drives: 2010 SS/RS, CGM w/ Silver Stripes.
Originally Posted by bmorecam View Post
I was almost with you until I realized what stock v6's dyno on other similar dynojet. I think its more 20-30hp I gained considering stock see 240-250whp.
but again, I cant really take the numbers from today too seriously without having base numbers to compare to.
Silly me...I assumed you had a CAI to match the flow on the bottom end...
2010 2SS/RS, CGM w/ silver stripes. Hurst Shifter, long tube headers, full exhaust, CAI, tune. SAE 407 RWHP/402 RWTQ
Momma didn't bronze my shoes, but when I turned 16 I inherited a lead foot.
Devryn17 is offline   Reply With Quote
Old 05-26-2011, 01:06 PM   #26
bmorecam
and thats with 90 degree humid weather we had yesterday and almost all week. Today we are reaching 95. This hot weather is killing me.
Im sure 93 gas and running catless had alot to do with it too, and vince did say that adding long tube with his new tune can see bigger gains.
Old 05-26-2011, 01:10 PM   #27
GretchenGotGrowl
It would be fantastic if you were the first NA car to 300 RWHP, but I think you will still be a little shy even with the E85 and a CAI. However, PLEASE prove me wrong!
Good luck man, this is going to be very interesting.
Old 05-26-2011, 01:24 PM   #28
bmorecam
Very interesting indeed! vince stated that his vette got 20hp just with a tune. He think our LLT will be very interesting with e85 due to simple fact that we have direct injection on our side and we naturally have high compression which is a big plus for e85.
E85 love boost and high compression. Mix those two into factor and peoples are seeing numbers and timing that you will never see with regular gasoline.
Even if I can see minimum of 20hp like on vince car than I am positive that I can hit 300whp with vararam.
Who knows, we might see even more. It all depends how far it will go before knocking but with the natural octane rating of 105+ and its cooling nature of e85 I am very optimistic
Dyno Tune in Sacramento - Force Fed Performance LS3-376 Tuning / Diagnostics -- engine and transmission 3 03-19-2012 01:32 PM
$150 OFF 21st Century Muscle Cars DYNO TUNE 21STCENTURY V8 Bolt-Ons & Tunes 0 01-08-2011 10:57 AM
SCT or Dyno Tune jwjw12 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 10-20-2010 03:28 PM
Trifecta tune or Dyno tune? cnjsanchez Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 18 05-14-2010 12:42 PM
L99 A6 Dyno Results (ARH, Roto-Fab CAI,Borla, Tune) rinerracing6 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 08-23-2009 06:09 PM
