BeckyD @ James Martin Chevy
Old 05-25-2011, 10:46 PM   #1
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
What's the best way to fix chips/small scratches?
My car has chips and scratches . I bought the paint, primer and clear, but am too nervous to screw it up. What are your thoughts? Is there a step by step porocess or just leave it up to the auto body shops?
I show it off to much to just leave it.
What are estimates other have received to paint the whole car?
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
Old 05-25-2011, 10:55 PM   #2
bowtie628
Auto body and paint guy
bowtie628's Avatar
Drives: 2010 Camaro LS
depends how bad.. if there little, clean them well.. take a very small hobby brush.. fill the chip in a little at a time until its filled..
bowtie628 is offline   Reply With Quote
Old 05-25-2011, 10:56 PM   #3
DanCamm
DanCamm's Avatar
Drives: 2011 2SS/RS RY
I'd say if it's any more than a few minor stone chips, leave it to the professionals. Especially with IOM. Just curious, what kind of paint did you buy?
2011 2SS/RS, Rally Yellow, 6M
DanCamm is offline   Reply With Quote
Old 05-25-2011, 11:11 PM   #4
edog
edog's Avatar
Thanks for the responses..
I bought the paint from "paintscratch". Touch up paint. It is the same as what is listed on the threads in this site. M C 28/WA502? It is the correct listing per VIN#, just cant make out the last letter due to it being blended with other instructions.
I bought the primer, paint, and clear in pen, and the primer and paint in brush.
Old 05-25-2011, 11:22 PM   #5
DanCamm
DanCamm's Avatar
Depending on how big the chips are, that may be a little overkill... less is more! I had 2 small chips in my front fascia, and I used a toothpick to just touch a drop of paint to fill the chip. Again, I don't know what you're trying to fix, but don't over do it.
Old 05-25-2011, 11:25 PM   #6
DangerZL1
Drives: Future ZL1 Owner
I don't think you'll need to use anything but the color coat to repair the chips. Using the primer and clear is unnecessary for very small areas. As previously mentioned just take your time and build each chip up even with the surface.
DangerZL1 is offline   Reply With Quote
Old 05-25-2011, 11:28 PM   #7
DanCamm
DanCamm's Avatar
I'll second this also.
Old 05-25-2011, 11:34 PM   #8
edog
edog's Avatar
Ok, just a toothpick and touch it on, then go back and redo until it is level?
Old 05-25-2011, 11:42 PM   #9
CamaroFemme
CamaroFemme's Avatar
Drives: 2010 Black Camaro 2SS/RS
Keep in mind it seems to be the consensus that the paint on this car is the weak spot - I expect to repaint it in 5 or so years.
No complaints, though. Love ittt.
My boyfriend don't mind it.
CamaroFemme is offline   Reply With Quote
Old 05-25-2011, 11:45 PM   #10
DanCamm
DanCamm's Avatar
As long as the chips are small, you should be good. Mine were literally the size of a toothpick. One dab did mine. If you have bigger chips, you may need to build it with more than one "dab" to fill the chip. You could also over build it a little then block it smooth with 2000 once it's dry, and buff it... but that may take a little more than you may be comfortable with...
Old 05-25-2011, 11:50 PM   #11
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Here you go sir!
http://www.drcolorchip.com/select-co...maro&search=Go
They give step by step instructions and I can confirm amazing results!
Old 05-25-2011, 11:51 PM   #12
edog
edog's Avatar
Uh, yeah...LOL!
I have been wanting to try this for a while, but I feel like Don Knots in the "shakiest gun in the west"!
Ok, can't believe I pulled a movie from the year before I was born, but we all will get here.
I will give it a shot tomorrow. I will keep you guys posted. Thanks for the help.
Old 05-25-2011, 11:53 PM   #13
DanCamm
DanCamm's Avatar
Good luck!
Old 05-26-2011, 03:51 AM   #14
wildcatjake
Full of Shenanigans
wildcatjake's Avatar
Drives: The pedal through the floor pan...
Originally Posted by ihaveacamaro View Post
Here you go sir!
THIS . I have used their products on my last 3 vehicles, including a very small rock ship on my Camaro bumper.
IOM 2SS/RS M6 - "H1 OFCR"
GMPP 21" Wheels - Volant CAI - XS Power LT's and exhaust - Custom Tune - MGW Short Throw - IOM Heritage Grille - 25% Tint - AAC Amber LED Upgrade, Footwells, and DRL's - JL 10W7 in a ******** Box - Active Image Dynamics and Vifa Components - Kenwood Amps - Lots of Sound Deadener - Big Worm full tint kit and bowties
Future Plans: Vmax ported TB - More AAC goodies - Drop Springs/Sways/Bushings
Wish List: AirLift - Whipple - Cam
wildcatjake is offline   Reply With Quote
Scratches... OH NO! Bryan2230 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 19 03-16-2011 01:27 PM
Help, camaro scratches + no spare tire; Stolen! messi 5th Gen Camaro SS LS LT General Discussions 18 01-06-2011 12:57 PM
Scratches on Camaro from dealer Jus1dab Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 6 09-10-2010 02:34 PM
Fix scratches on radio glass panel grubber Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 18 08-27-2010 04:54 PM
What do you use to fix scratches? MRK III Z28 General Automotive + Other Cars Discussion 7 01-03-2009 03:12 AM
