AAC Style
Old 05-27-2011, 10:05 PM   #1
EndlessNight
EndlessNight's Avatar
Drives: CGM Camaro 1LT
Questions: Cleaning polish dust, etc.
Just looking for some advice.
So I have finished SHR, but I have a dilemma. Should I:
1. Waterless wash each panel to remove dust before FMP?
or
2. Just wash the car over?
Thanks in advance.
EndlessNight is offline   Reply With Quote
Old 05-27-2011, 10:24 PM   #2
jdenotter
jdenotter's Avatar
Drives: 2010 2SS/RS,M6,Black w/CGM Stripes
or
Thanks in advance.
I would just do a IPA wipe down. That should work just fine. If not just wipe it down with some detail spray.
Sent from my DROIDX using Tapatalk
3" RDP Motorsports aggressive cat-back exhaust w/ x-pipe, Vararam CAI, Hurst's short throw shifter, Gary's Customs painted bowties, Ofer's HID DRL/Fog Light wiring harness, Kelvin 8K HID DRL bulbs, ZL1 grille. Johnson's window tint film, LSR lowering springs, Metra dash kit with Pioneer In-Dash DVD head unit.
jdenotter is offline   Reply With Quote
Old 05-27-2011, 10:25 PM   #3
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
You don't need to do anything. You go SHR then FMP immediately.
[B]
Old 05-27-2011, 11:04 PM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
Correct. It says on the bottle to leave the SHR residue on the car and go directly to FMP
Click to view my build thread
Old 05-28-2011, 09:10 AM   #5
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '17 Corvette Z51 Coupe
this is correct......I talked to Dylan about this and he told me that very thing. and HE should know!
Old 05-28-2011, 10:34 AM   #6
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
or
Thanks in advance.
Are you letting the car sit for a long time between steps? Like overnight or something?
If not, no reason to do anything... just continue on with your polishing.
If you are doing SHR, then coming back the next day to do FMP them it would be in your best interest to clean the paint prior to starting to polish again.
Old 05-28-2011, 04:36 PM   #7
EndlessNight
The car has to sit overnight (garaged).
I am more concerned about the polish dust and whether waterless wash is the best alternative.
Old 05-28-2011, 04:51 PM   #8
Elykson
Custom One Off
Elykson's Avatar
Drives: 2010 Chicago Blackhawks Edition #1
If you haven't wiped off all the SHR and inspected your paint, then how do you know if you're ready for FMP?
Vararam Intake/SLP Loud Mouth II/BBK LT HFC/Magnaflow x-pipe/Pfadt Springs/Black Ice-olator/FE3 suspension/VMAX TB/RX catch can/Trifecta Tune
http://www.camaro5.com/forums/showthread.php?t=129416
Elykson is offline   Reply With Quote
Old 05-28-2011, 05:00 PM   #9
EndlessNight
I have wiped off the SHR and inspected.
I'm talking about the polish dust that comes from hitting the pad's edge on tape or a panel crease.
Old 05-28-2011, 05:04 PM   #10
Elykson
Custom One Off
Elykson's Avatar
Then I would follow Dylan's advice. He does this for a living.
Old 05-28-2011, 09:52 PM   #11
CamaroDreams07
Drives: Slow V6
The polish dust doesn't matter. Just go straight to FMP. If you are letting it sit overnight, then you need to wipe it down because you will get real dust on the car, which you don't want to drag around your paint at 5000 OPMs.
[B]
Old 05-29-2011, 07:03 PM   #12
EndlessNight
Thanks for all the help so far everyone. I ended up just washing the car down with water and foaming it...all dust gone. But now I have another question:
1. I have done FMP on every panel expect the bumpers, but have concerns about FMP. Can you use too little? When ever I worked the product it just seemed to go super thin really quick unlike SHR. I tried DS to rejuvenate the pad and it worked to an extent. Sometimes it just seemed like I was working greasy DS. My pad isn't clogged so I at least I didn't over use it.
Any thoughts?
Old 05-29-2011, 08:09 PM   #13
Adam's Polishes
You can always use too little, but that depends on the size of the area you're working.
How much are you using and what size area are you covering with that amount??
Old 05-29-2011, 09:27 PM   #14
EndlessNight
I usually do 1X1 or 2x2 area. For example, I broke the roof into about 9 sections. Used 3 pea-sized drops to start and then DS after that.
Got my Zaino today lordfriday2 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 261 05-31-2014 10:00 PM
V6 Questions I'd Like Answered The_Blur Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 36 07-14-2012 10:44 AM
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 09:17 PM
New Camaro Color- Brake Dust Black ravensjeff Wheels and Tires Talk Sponsored by The Tire Rack 28 08-13-2009 11:02 AM
QUESTIONS ABOUT CLEANING REAR SPOILER.... Matrix Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 6 03-27-2009 12:42 PM
