Emblempros
Old 05-27-2011, 11:52 PM   #1
chicagobulls
one car wolfpack
chicagobulls's Avatar
Drives: 2010 Camaro V6
sprayer for hose??????????
i was wondering where i can buy a cheap sprayer that mixes car wash with hose water so it is really easy to put on the car?
does anyone have something like this and how does it work?
thanks
something like this?
chicagobulls is offline   Reply With Quote
Old 05-28-2011, 12:44 AM   #2
baup5f
baup5f's Avatar
Drives: 2010 2SS/RS Coupe
kind of expensive, but this will do the job:
http://www.gpcperformance.com/Adams_Foam_Gun_p/483.htm
2010 CGM 2SS/RS
baup5f is offline   Reply With Quote
Old 05-28-2011, 01:02 AM   #3
Elykson
Custom One Off
Elykson's Avatar
Drives: 2010 Chicago Blackhawks Edition #1
Get on Ebay and look for a Foam master II. I got mine for $35 shipped.
Vararam Intake/SLP Loud Mouth II/BBK LT HFC/Magnaflow x-pipe/Pfadt Springs/Black Ice-olator/FE3 suspension/VMAX TB/RX catch can/Trifecta Tune
http://www.camaro5.com/forums/showthread.php?t=129416
Elykson is offline   Reply With Quote
Old 05-28-2011, 02:32 AM   #4
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Nearly the same price on Amazon as well. Gilmour Foam Master II is what you want.
[B]
Old 05-28-2011, 09:55 AM   #5
chicagobulls
one car wolfpack
yep thanks do you think this would do the trick?
http://www.acehardware.com/product/i...602612.1260285
Old 05-28-2011, 09:57 AM   #6
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
I've covered this a few times, but I can't find the thread, so here goes again
"Foam" is bubbles, you need 3 components to make bubbles:
1) Soap
2) Water
3) Air
A garden chemical sprayer only works with 2 of those 3 elements... its designed to take a liquid chemical, dilute it with water, and dispense using the pressure from the water feed. Without the properly METERED introduction of air, it won't make foam.
A foam gun does introduce air at a correctly metered amount to generate the foam. If you use a garden chemical sprayer you'll end up with soapy water, not foam.
Old 05-28-2011, 10:00 AM   #7
chicagobulls
one car wolfpack
so this would work
Old 05-28-2011, 10:33 AM   #8
Adam's Polishes
Yep... thats a foam fun.
Old 05-28-2011, 10:48 AM   #9
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
How does mine look?
Name:  My Foam Gun.jpg
I've yet to see any swirls on mine...except for paint overspray...
Old 05-28-2011, 11:03 AM   #10
chicagobulls
one car wolfpack
Originally Posted by Iwantone2 View Post
How does mine look?
Attachment 245644
what kind of sprayer is that?
where did you get it
Old 05-28-2011, 11:09 AM   #11
jdenotter
jdenotter's Avatar
Drives: 2010 2SS/RS,M6,Black w/CGM Stripes
I would buy the hyrofoamer as someone stated above. Much more superior then the gilmour II IMO.
Sent from my DROIDX using Tapatalk
3" RDP Motorsports aggressive cat-back exhaust w/ x-pipe, Vararam CAI, Hurst's short throw shifter, Gary's Customs painted bowties, Ofer's HID DRL/Fog Light wiring harness, Kelvin 8K HID DRL bulbs, ZL1 grille. Johnson's window tint film, LSR lowering springs, Metra dash kit with Pioneer In-Dash DVD head unit.
jdenotter is offline   Reply With Quote
Old 05-28-2011, 11:45 AM   #12
chicagobulls
one car wolfpack
ive found a griots one it looks just like the adams plus it 30$ shipped!
thanks for your help guys!!!
Old 05-28-2011, 09:12 PM   #13
Gene Culley
Drives: 2013 SS
Smile
Yes, I recently got mine from Amazon.com.
Gene Culley is offline   Reply With Quote
Old 05-28-2011, 10:26 PM   #14
chicagobulls
one car wolfpack
Should i get the foam master for 35 shipped or the griots for 30 shipped
which is better?
thanks
Kwazar Mercury Pro + Trigger Sprayer Promotion DetailersDomain Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 1 02-12-2011 10:15 PM
washer fluid sprayer? franknbeans 5th Gen Camaro SS LS LT General Discussions 45 12-18-2008 02:28 PM
