Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 05-30-2011, 08:00 AM   #1
GRASSHOPPER
Drives: 1987 z28
CAN'T CHECK ENGIN CODES
OK, SO MY CHECK ENGINE LIGHT IS ON WHEN THE CAR IS STARTED BUT WHEN I SHUT THE CAR OFF AND PLUG IN THE CODE READER, TURN ON THE IGNITION (BUT NOT START) THE LIGHT WON'T COME ON AT ALL LITTLE OWN FLASH ANY CODES. ANYONE ELSE HAVE THIS ISSUE AND SOLVED IT, OR ANY IDEAS WHAT IS GOING ON?
THANKS IN ADVANCE AND SORRY FOR THE CAPS
MIKE
GRASSHOPPER is offline   Reply With Quote
Old 05-30-2011, 08:21 AM   #2
vart
vart's Avatar
Drives: 2010 2SS
Not sure what the issue is, but next time it comes on you can call OnStar and have them run a diagnostic test for you.
Got: Volant CAI. Stealth splash guards. Stainless Works 1-7/8" long tube headers and cat back exhaust. Pfadt coilovers, sway bars, rear trailing arms, street differential mounts and solid subframe bushings. Custom tuned by Davenport Motorsports.
Want: Everything else!!!
<img src=http://www.camaro5.com/forums/image.php?type=sigpic&userid=34547&dateline=1309150494 border=0 alt= />
vart is offline   Reply With Quote
Old 05-30-2011, 08:28 AM   #3
G8GT721
G8GT721's Avatar
Drives: 2008 Pontiac G8 GT
If the code reader doesn't power up, then the obd port doesn't have power. Check fuses other than that can't follow your post
2008 White Hot G8 GT
(new)499RWHP/474RWTQ Mustang Dyno
(old)451RWHP / 498RWTQ Mustang Dyno
1/4=11.400@118.7 17" Drag Radials, stall, cam 1.77 60'
1/4=12.004@120.6 17" Drag Radials 2.03 60'
1/4=12.270 @118.3 on 18" All Seasons 2.08 60'
SLOWHAWK[/URL] Tuned
If you can't say anything intelligent, say something loud and stupid
G8GT721 is offline   Reply With Quote
Old 05-30-2011, 09:56 AM   #4
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
do you guys realize this is posted in the 3rd gen camaro section,, they do not have onstar and they do not have an obd2 diag port,,, they use an obd1 diag port that is not self powered,, also on most all obd1 gm cars you can get the diag trouble codes by jumping pin A to pin B:
http://www.obd-codes.com/faq/read-gm...codes-free.php
Old 05-30-2011, 10:36 AM   #5
GRASSHOPPER
Drives: 1987 z28
I WAS GOING TO TRY JUMPING THE PINS INSTEAD OF THE CODE READER I JUST BOUGHT, BUT THE SES LIGHT DOESN'T COME ON UNTIL THE MOTOR IS RUNNING, AND ALL MY BOOKS SAY TO PLUG IN THE READER OR JUMP THE WIRES BEFORE TURNING ON THE IGNITION TO THE RUN BUT NOT START
IF I START THE CAR AND PLUG IN THE READER IT JUST FLASHES STEADILY UNTIL I UNPLUG IT, THEN IT GOES BACK TO ALWAYS ON. I'M LOST HERE
Old 05-30-2011, 11:19 AM   #6
Mr Twisty
Mr Twisty's Avatar
Jump the pins. It's free to try.
What scanner do you have?
-- Benjamin Franklin
Old 05-30-2011, 11:51 AM   #7
GRASSHOPPER
Drives: 1987 z28
IT IS A CHEAP ONE FROM CANADIAN TIRE STORE,
http://www.canadiantire.ca/AST/brows....jsp?locale=en
THIS ONE, BASIC UNIT, ALL IT DOES IT JUMP THE 2 WIRES I THINK AND THEN START COUNTING THE FLASHS
Old 05-31-2011, 11:40 AM   #8
Mr Twisty
Mr Twisty's Avatar
So... did you ever jump the pins to see if it worked? that code reader may be defective.
Old 05-31-2011, 04:26 PM   #9
GRASSHOPPER
Drives: 1987 z28
I SINCE HAVE NOTICED THAT MY BATTERY KEEPS GOING DEAD, AND WHEN I HOOKED UP THE BATT. CHARGED I WIGGLED SOME WIRES NEAR THE BATTERY AND THE COOLING FAN CAME ON (THE CAR HAD NOT BEEN RUNNING OR HOT AT ALL) SO I FOLLOWED THE WIRES AND THEY GO TO WHAT LOOKS LIKE A RELAY OR FUSE BLOCK RIGHT BESDIE THE RAD AND IT IS LOOKING CRISPY SO I NEED TO REPLACE IT BEFORE DOING MUCH OF ANYTHING ELSE
Old 05-31-2011, 05:51 PM   #10
Mr Twisty
Mr Twisty's Avatar
25 year old cars can keep you busy LOL
Old 05-31-2011, 07:16 PM   #11
GRASSHOPPER
Drives: 1987 z28
keeping me pissed off right now, once i get things working right i hope to drive it more than repair it, but that is yet to be seen
Old 08-13-2011, 05:21 AM   #12
camarosource
Drives: 1992 Camaro Z28 Showcar
It's funny you say that.. My 1992 Camaro no longer will send the error codes to any readers.
1992 Camaro Z28. Blue/silver, Custom Blue/Silver Leather seats, Rebuilt Engine, Cammed, Headers, TT ][ Rims ...
NEW WWW.CAMAROSOURCE.CA
Camarosource.ca FACEBOOK PAGE - EXCLUSIVE INFO On upcoming Camarosource.ca V5.0 and More!!
camarosource is offline   Reply With Quote
Old 08-28-2011, 09:37 PM   #13
GRASSHOPPER
Drives: 1987 z28
does it still run alright?
any ideas as to why or have you figured it out yet?
mike
dipstick why check it hot? mike12345 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 5 11-06-2010 05:13 PM
Woke up....check engine...called onstar xshortd Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 19 10-02-2010 09:37 PM
LLT vs LT1 RedJewelSS Chevy Camaro vs... 5 05-23-2010 11:40 AM
