Cold Air Inductions
Old 05-30-2011, 10:40 PM   #1
poss
Drives: 94 Mazda RX-7
WTB: DBW pedal & Harness, Stock MT shifter & Bracket
As the title says, I'm looking for a drive by wire pedal and as much of the associated harness as I can get. I also need the whole shifter assembly from a 6-speed, including the section that directly mounts to the transmission.
Let me know what you have and what you want for them.
Thanks,
Ryan
poss is offline   Reply With Quote
Old 05-30-2011, 10:56 PM   #2
poss
My apologies for posting this in the wrong section.
Old 05-31-2011, 04:12 PM   #3
blake-b
blake-b's Avatar
Drives: Black 2010
I have a complete stock shifter minus boot/knob and a pin with 2 c clips. I put in an mgw and used those stock parts. I have the aftermarket mgw pin. You would only need 1 c clip for it. PM me if interested. Send an email address and i will send pics if you are interested.
dbw, pedal, shifter
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 09:17 PM
FS: Stock Clutch, shifter, rear axles, rear end gear CamaroFTW Transmission / Driveline 5 05-19-2012 08:47 AM
Can I switch the hurst shifter with the stock one? Fantasm 5th Gen Camaro SS LS LT General Discussions 11 12-11-2010 06:31 AM
Testing new Pfadt shifter Fast1 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 38 11-22-2010 04:01 PM
Unbeatble Prices on ACT / Fidanza / Hurst / Mishimoto / MTI / SLP / Spec / More maperformance Transmission / Driveline 18 10-26-2010 02:16 PM
