Old 05-31-2011, 01:09 PM   #1
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Chasing down an air leak........ could it be?
Ok, I have to pull the maggie off for a third time. Looking for the same thing.
Drove to Atlanta this weekend to have Vengeance Racing tune the car. We were pretty sure the mis and surge was in the tune, and so I went up to have it re-tuned to stop doing it.
Well, he couldn't get the missfire/surge to go away. Couldn't find a leak. But he says there is one and that's why I'm having the problem.
Made the same dyno numbers as original but added 10 in torque. (470 rwhp - 480 tq) pretty much.
So the leak must just be at low rpm???
At any rate; Somebody tell me what to look for. Most likely places to find a leak. Mike, at Vengeance, said the back side of the vacuum hose going into the heads (the one that goes into the rear of the driver side valve cover that the catch can connects to) is leaking. But that's not what the problem is because it didn't get better when we plug it off.
So I have a leak somewhere.
I've already done just about everything imagineable, but I'll just do it agian, again, again. I'm hesitant to spray carb cleaner by the headers, obviously, but I will.
So, any suggestions as I go through this again.
You post it, I'll do it.
List of things I'm going to do already, I'll proceed to the next unless I find it.
1. Cut a 10mm socket down to fit the bolt under the rear drive pulley and get better torque on it.
2. Remove hoses and plug the hose stems completely. (If the miss goes away I know it's in the hoses)
3. Carefully spray carb cleaner around the manifold.
4. Remove the bloser and replace the gaskets.
OH, ya. Car runs like a beast when it's up in the band. But it's died 7 or 8 times now. Twice pulling out into traffic. Pissed a guy off pretty bad. He was laying on his horn. lol
UPDATE: Turns out it was a header gasket leak. Go figure.
Old 05-31-2011, 01:16 PM   #2
anthonyj9h
"First There"
anthonyj9h's Avatar
Drives: 2010 camaro 2ss
water should help find it on a hose if its there, as far headers loosen and retighten and torque to spec...check the throttle body sometimes ppl miss things when tightening.... hmmmmmm the seals on your cai maybe?
Originally Posted by jewel25 View Post
No one wants to be like aytard. He is a douche for eggs.
it is written......
anthonyj9h is offline   Reply With Quote
Old 05-31-2011, 01:23 PM   #3
PQ
Booooosted.
PQ's Avatar
Hoses are vacuum. So I'm not sure I wnat to do water. Carb cleaner maybe?
Headers have never been off. Not sure I want to do that.
I'll spray the intake all over with carb cleaner.
I'll retorque the TB too. When I pull the blower. I know everything has been torqued to spec when I installed it the second time, but the second bolt to the rear on the passenger side.
Thanks. I'll make sure to check those things.
Old 05-31-2011, 01:26 PM   #4
anthonyj9h
"First There"
anthonyj9h's Avatar
lol yes i know they are vaccum remove them and dunk in water to see if any air bubbles come up like you would on a tire, as far as your headers since they havnt been off check the gaskets for exhaust leaks too and then retorque....lots of vibration going on in that engine bay
it is written......
Old 05-31-2011, 01:31 PM   #5
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
gotta be an exhaust leak.
I piss excellence
and fart awesomeness
Old 05-31-2011, 01:32 PM   #6
anthonyj9h
"First There"
anthonyj9h's Avatar
i dont know if you took the heads off or not so i would say check those gaskets as well
it is written......
Old 05-31-2011, 01:52 PM   #7
PQ
Booooosted.
PQ's Avatar
Heads never came off. But at this point, I guess I could spray them too.
I just don't want to mess around spraying too much around the headers. lol
Old 05-31-2011, 01:53 PM   #8
anthonyj9h
"First There"
anthonyj9h's Avatar
lol awwww come on dont be shy
it is written......
Old 05-31-2011, 02:02 PM   #9
Dave Coyle
Dave Coyle's Avatar
Drives: 2010 SS , 1970 Z-28, 2002 Avalanche
One thought that comes to mind for me is, have you thought about a "hair-line-crack" in the Maggie body? If you spray starter fluid around it you may find a crack but may not be able to "see" it. I you can not find the problem you may want to take the Maggie to a shop and have it magged for cracks, the mag process will find cracks where the eye can not! Good luck, sounds like you could use it!!!!
IF IT'S WORTH HAVING, IT'S WORTH WAITING FOR!!!! (AND IT WAS)
434RWHP/403RWTQ
Livernois Motorsports 2C Cam kit
Kooks 1 7/8 LT Headers/Hi-Flo Cats/Corsa Exhaust
Roto-Fab CAI / Port Intake
Precission 2400/2800 Converter/3.73 AAM gears
Livernois Motorsports Tune
Best time: 11.97 @ 117 MPH
Dave Coyle is offline   Reply With Quote
Old 05-31-2011, 02:05 PM   #10
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
Doesn't Vengeance have a smoke machine they could use to diagnose? It not then I would suggest you find a local tech that might have one and knows how to use it.
You will track the vacuum leak down in no time.
HufferSS is offline   Reply With Quote
Old 05-31-2011, 02:08 PM   #11
anthonyj9h
"First There"
anthonyj9h's Avatar
try this as well....
Do a visual inspection. Check all of the under hood vacuum hoses, connectors and plastic lines for softening, collapsing and cracking. Pay particular attention to the PCV and evaporative emissions systems. The vapors in these two systems attack rubber, and are a common source of vacuum leaks. Replace any softened, deteriorated, or collapsed hoses and connectors. Big leaks can be identified by a tell-tale hiss. If no visual leaks are detected, move to the next step.
Slowly spray carb/intake cleaner around the intake manifold and throttle body, with the engine running. If the vacuum leak is one of these gaskets, the spray will restore the air-fuel ratio momentarily and the engine speed will change as a result. Go slowly and allow the engine speed to stabilize before moving to the next area. Any place that the spray causes a change in engine speed is the source of a vacuum leak. Avoid spraying the cleaner directly into the intake tract. This will give a false indication of a leak. If no leaks are found during this test, move to the next step.
Pinch each vacuum hose closed until the one that changes engine speed is found. Begin at the throttle body and eliminate them one by one, then move to any remaining vacuum trees (these are multi-ported vacuum tees that supply vacuum to more than one device) located on the manifold, firewall or fender well. Pay particular attention to the large vacuum hose attached to the brake booster. A sticking valve or ruptured diaphragm in the booster is a common vacuum leak source.
If no vacuum leak is found during this test, there are no vacuum leaks.
it is written......
Old 05-31-2011, 02:39 PM   #12
PQ
Booooosted.
PQ's Avatar
That is my worst fear. We've breifly discussed that.
They might. I only dealt with the tuner. And they didn't have time to fool with it. Besides, I had just paid 600.00 to try with a tune.
But, if I end up pulling the maggie and doing all the work and I still have the leak, I'll go have that test done. Maybe I should try it before hand.
Discussed this too. Not sure how to test it. It encased so you can't really visually do it.
Old 05-31-2011, 02:42 PM   #13
anthonyj9h
"First There"
anthonyj9h's Avatar
the smoker idea you should really take time to do good advice
it is written......
Old 05-31-2011, 02:59 PM   #14
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
As simple as crimping shut the supply line to it at the manifold end...
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ AutoAgenda Exterior Parts & Accessories 14 02-06-2013 09:43 PM
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 05:34 AM
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 09:26 PM
Cold Air Intakes 2010 Camaro Blowout! K&N | AIRAID | SLP | Best Price Guaranteed! PM AutoAgenda V8 Bolt-Ons & Tunes 47 01-12-2011 01:35 PM
