JUICEDMOTORSPORTS
Old 06-04-2011, 11:25 AM   #141
anthonyj9h
"First There"
anthonyj9h's Avatar
Drives: 2010 camaro 2ss
and that would def throw your fuel trims off if the leak is there
Originally Posted by jewel25 View Post
No one wants to be like aytard. He is a douche for eggs.
it is written......
anthonyj9h is offline   Reply With Quote
Old 06-04-2011, 11:27 AM   #142
anthonyj9h
"First There"
anthonyj9h's Avatar
you should have a code p04xx
it is written......
Old 06-04-2011, 11:30 AM   #143
anthonyj9h
"First There"
anthonyj9h's Avatar
ur gas cap is on tight right
it is written......
Old 06-04-2011, 11:32 AM   #144
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I got no codes. I'm uploading a video now. The leak is UBER SMALL. VERY little leak. And since I plugged that line off and the car didn't change, I may have dismissed that as a possibility. The video will explain a little better.
It got late last night and I am going to do it again but spray soapy water all over anywhere it could or would leak and see that way as well.
If I can't figure it out then, I'll take it for a smoke test. And after that, it's off to a shop.
Old 06-04-2011, 11:34 AM   #145
PQ
Booooosted.
PQ's Avatar
lol, ya.
Damn, I wish I had a smoke machine. 700.00 is pretty steep.
Old 06-04-2011, 11:52 AM   #146
anthonyj9h
"First There"
anthonyj9h's Avatar
unplug the soleniod and see if the car changes.....
it is written......
Old 06-04-2011, 11:54 AM   #147
PQ
Booooosted.
PQ's Avatar
Actually did that. No change. Did it while it was running. And no change at all. Assuming you're talking about the elecric harness.
Old 06-04-2011, 11:58 AM   #148
anthonyj9h
"First There"
anthonyj9h's Avatar
this.....
it is written......
Old 06-04-2011, 12:21 PM   #149
PQ
Booooosted.
PQ's Avatar
this.....
Yup.
Old 06-04-2011, 12:27 PM   #150
anthonyj9h
"First There"
anthonyj9h's Avatar
here is a vacuum diagram to the blower too if this helps
it is written......
Old 06-04-2011, 12:32 PM   #151
anthonyj9h
"First There"
anthonyj9h's Avatar
im pretty sure if your evap was leaking or that solenoid was bad you would get a code.......have to go farther in the rabbit hole now......hmmmmmm time to see where that line goes
it is written......
Old 06-04-2011, 12:35 PM   #152
PQ
Booooosted.
PQ's Avatar
Goes into the charcoal canister and then into the gas tank.
Old 06-04-2011, 12:42 PM   #153
PQ
Booooosted.
PQ's Avatar
Actually, if I understand the system correctly, it takes the fumes from the gas tank that have evaporated and uses them when the charcoal canister is 'full' and when there are no significant fumes it's just blocked off. So a leak there would not cause a constant leak because it's not always passign through.
Old 06-04-2011, 12:45 PM   #154
anthonyj9h
"First There"
anthonyj9h's Avatar
thats true and that solenoid activates the valve to open
it is written......
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ AutoAgenda Exterior Parts & Accessories 14 02-06-2013 09:43 PM
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 05:34 AM
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 09:26 PM
Cold Air Intakes 2010 Camaro Blowout! K&N | AIRAID | SLP | Best Price Guaranteed! PM AutoAgenda V8 Bolt-Ons & Tunes 47 01-12-2011 01:35 PM
