Old 05-31-2011, 03:04 PM   #15
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
Smoke machines were invented to stop stumbling around in the dark when it comes to vacuum and emissions leaks. If you CAN find it with a visual inspection or carb clean...then a smoke machine can find it in about 1% of the time that you would spend doing it the 1984 way.
HufferSS is offline   Reply With Quote
Old 05-31-2011, 03:12 PM   #16
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Originally Posted by hypurone View Post
As simple as crimping shut the supply line to it at the manifold end...
But the vacuum comes from that end. Wouldn't I need to do that from the other end? And how could I do it. I'd have to get behind the firewall right?
I'll have to check that out. Any idea of a known shop?
Old 05-31-2011, 03:32 PM   #17
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Any shop worth a hoot will have a smoke machine.....look for one that has a reputation for working on more modern stuff or being a good diagnostic shop....but it's a pretty common tool for a commercial repair garage to have.
All it is a machine that literally creates smoke. You can plugin to your vacuum system and hit the button....watch for smoke. You can add dye and use lights etc to find tiny leaks....it's pretty cool tool.
Old 05-31-2011, 03:37 PM   #18
PQ
Booooosted.
PQ's Avatar
Maybe I should start smoking again and use a cigarrete?
Old 05-31-2011, 03:39 PM   #19
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
No, the vacuum is generated at the intake manifold/maggie and fed to the booster via the line. You want to crimp it shut at the manifold end to eliminate the booster, line and check valve. If that identifies the prob, then you can work your way down the line to see what component is the prob. Capiche?
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 05-31-2011, 03:40 PM   #20
anthonyj9h
"First There"
anthonyj9h's Avatar
Drives: 2010 camaro 2ss
what he said sorry got a lil busy
Originally Posted by jewel25 View Post
No one wants to be like aytard. He is a douche for eggs.
it is written......
anthonyj9h is offline   Reply With Quote
Old 05-31-2011, 03:42 PM   #21
PQ
Booooosted.
PQ's Avatar
So, if there is no change when I do that. Then it's NOT the check valve at the brake booster?
I took the hose OFF of the valve at the brake booster and plugged the hose with my finger. It was still missing. So I guess that's the same thing.
Old 05-31-2011, 03:46 PM   #22
hypurone
hypurone's Avatar
Sort of, you were downstream of the check valve so technically it could still be the problem... Crimp it upstream of the valve or remove the valve and plug the line to be sure.
Old 05-31-2011, 03:52 PM   #23
PQ
Booooosted.
PQ's Avatar
The L99 doesn't have the canister. Only the fitting that plugs straight into the firewall. I suppose I could pull it out and plugg it from there, with my finger. That would work, but since I still have the problem plugging the hose at the blower, I guess I'm ok?
Old 05-31-2011, 04:58 PM   #24
hypurone
hypurone's Avatar
Yeah, sorry. I misread your post. If you disconnected the hose on the intake side of the check valve you should be good at that area then...
Old 05-31-2011, 05:38 PM   #25
Speedy1975
FASTER!
Speedy1975's Avatar
Drives: Challenger Hellcat, 2SS Camaro
Are you seeing any CEL codes? Typically with any VAC leak you'll get a CEL especially if it's bad enough to cause the engine to idle erratically.
Is it just a bad idle (erratic) or are you sure it's a true miss of the engine?
Did you post up video?
-Speedy
2016 Go Mango Challenger Hellcat (PB E.T. in 1/4 Mile 10.51 @131.36)
2016 Hyper Blue 2SS Camaro (PB E.T. in 1/4 Mile 12.093 @114.43MPH bone stock)
Speedy1975 is offline   Reply With Quote
Old 05-31-2011, 06:20 PM   #26
Ltdodge
Ltdodge's Avatar
Drives: 2008 Z06
man this sucks Randy.....hope you figure it out
i think your new nickname is Schleprock from the flintstones... remember him?
Ltdodge is offline   Reply With Quote
Old 05-31-2011, 06:21 PM   #27
PQ
Booooosted.
PQ's Avatar
I did post a video. Let me go get it and post it here.
Old 05-31-2011, 06:25 PM   #28
PQ
Booooosted.
PQ's Avatar
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ AutoAgenda Exterior Parts & Accessories 14 02-06-2013 09:43 PM
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 05:34 AM
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 09:26 PM
Cold Air Intakes 2010 Camaro Blowout! K&N | AIRAID | SLP | Best Price Guaranteed! PM AutoAgenda V8 Bolt-Ons & Tunes 47 01-12-2011 01:35 PM
