SDTW Custom Wheels & Tires
Old 06-07-2011, 08:04 PM   #337
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Originally Posted by Speedy1975 View Post
You did SOLDER these connections right?
Crimped.
But if they weren't working it wouldn't dyno so high right?
Old 06-07-2011, 08:08 PM   #338
epstein
Drives: SS/RS
Send a message via AIM to epstein
Get to soldering!
epstein is offline   Reply With Quote
Old 06-07-2011, 08:08 PM   #339
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
Still have the original lifters. Haven't done a cam or heads.
noid light? oscilloscope?
Here in Alabama those are only learned about in rocket science school.
I don't know what those are. And considering these people down here can't even get a simple smoke test right. I'm going to say no.
Now if you weren't in such a dilemma with the car I would say that sh1t right there is FUNNY!! I don't care who ya are...
Yeah, the 'scope was a long shot. Man I used to use the sh1t outta the one we had....
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 06-07-2011, 08:12 PM   #340
PQ
Booooosted.
PQ's Avatar
Originally Posted by epstein View Post
Get to soldering!
But if the connections are working, what difference would soldering do? I used the same type of crimping coupler that comes with the blower.
What is it? What does it do?
Old 06-07-2011, 08:33 PM   #341
epstein
Drives: SS/RS
its way to easy for an intermittent loose connection in my eyes.... That and I dont want to think of what would happen if you lost one while under boost.....
Old 06-07-2011, 08:38 PM   #342
PQ
Booooosted.
PQ's Avatar
*gulp*
Old 06-08-2011, 08:22 AM   #343
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
Oh. I found another site that does the same thing.
I piss excellence
and fart awesomeness
Old 06-08-2011, 09:09 AM   #344
anthonyj9h
"First There"
anthonyj9h's Avatar
Drives: 2010 camaro 2ss
lol smartass, last time i help you out .......i talked to my mech at the dealer and they are going to see what they can come up with.......ill let you know
Originally Posted by jewel25 View Post
No one wants to be like aytard. He is a douche for eggs.
it is written......
anthonyj9h is offline   Reply With Quote
Old 06-08-2011, 09:20 AM   #345
Chris@HPS
Chris@HPS's Avatar
Drives: 2005corvette
Originally Posted by Chris@HPS View Post
You can use a noid light to check #8injector( I think I read # 8 somewhere you thought was misfire). Put it on the injector and let the car idle and see what the light will do when it misfires.
Chris
I suggested a noid light way back when.LOL
Honestly, with the scanner hooked up and watching the AFR and Timing and Fuel trims, as well as a few other sensors( cam,crank,map sensors), whenever it misfires or skips, it will show up on the scanner and show exactly what is happening.
Chris
Chris@HPS is offline   Reply With Quote
Old 06-08-2011, 09:41 AM   #346
anthonyj9h
"First There"
anthonyj9h's Avatar
Cool stuff in that PDF file about code 121 (page 11). Seems throttle position sensor, MAF and EGR valve are all linked. But we're back to your not throwing any codes, which it looks like it should have since you found an air leak there.
this is what is so perplexing.....and on the spreadsheet it tells you the perimeters for it to throw a light and yes i can get you the v6 one
it is written......
Old 06-08-2011, 09:46 AM   #347
anthonyj9h
"First There"
anthonyj9h's Avatar
Randy, were the injectors ever tested with a noid light? Know anyone that still knows how to use/has an oscilloscope? This will show if it is a secondary ignition breakdown. As an alternative you could obtain a new (loaner?) coil and swap it out in each position to rule an intermittent coil problem out?
Do you still have the AFM lifters in it? I can't remember and not goin' back thru the whole damn thread!
lol he doesnt like talking bout the lifters......its sensitive to him
it is written......
Old 06-08-2011, 10:14 AM   #348
Jessika
Drives: Anything Blown
Just for clarification, those two wires are *just* cut & crimped for the IAT relocation.
Jessika is offline   Reply With Quote
Old 06-08-2011, 10:16 AM   #349
anthonyj9h
"First There"
anthonyj9h's Avatar
http://www.repairprocedures.com/login/
you can get the service manual here
it is written......
Old 06-08-2011, 10:30 AM   #350
garcmol
garcmol's Avatar
Napa part #CRB 2282572 $34.99 ~or~ CRB 2282571 $41.99
Evap Canister Solenoid Purge Valve
Me, I would go this route first. Everything I'm reading about this solenoid says that if it's not working (always open) it will allow the exhaust gases to continually enter the intake. That, at idle, will basically cause misfire or stutter or die. However, at normal cruising speed you wouldn't have the misfire because the canister is doing what it's supposed to do and venting into the atmosphere.
I may be way off here, but that's where you found an air leak, it made some funny noises when you put 20 psi of compressed air in the system, and it's cheap.
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ AutoAgenda Exterior Parts & Accessories 14 02-06-2013 09:43 PM
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 05:34 AM
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 09:26 PM
Cold Air Intakes 2010 Camaro Blowout! K&N | AIRAID | SLP | Best Price Guaranteed! PM AutoAgenda V8 Bolt-Ons & Tunes 47 01-12-2011 01:35 PM
